Generation of ccoshl.o file
Joel Sherrill
joel at rtems.org
Sat Jun 17 19:47:59 UTC 2017
On Jun 17, 2017 2:28 PM, "aditya upadhyay" <aadit0402 at gmail.com> wrote:
Hello All,
I have ported ccoshl.c from freebsd and trying to check whether the
lib-a-w_ccoshl.o file has generated or not.
When i executed this command :
aditya at aditya-Lenovo-ideapad-110-15ACL:~/development/b-
sparc-rtems4.12-newlib$
sparc-rtems4.12-nm
/home/aditya/development/b-sparc-rtems4.12-newlib/sparc-
rtems4.12/newlib/libm.a
I am not seeing the file like lib_a-w_ccoshl.o. However i have used
j-newlib script to build newlib for sparc and arm bsp.
These are the commands i have to build the newlib :
aditya at aditya-Lenovo-ideapad-110-15ACL:~$ cd development/newlib/
aditya at aditya-Lenovo-ideapad-110-15ACL:~/development/newlib$ ../j-newlib
Then these two files has been generated : b-sparc-rtems4.12-newlib and
b-arm-rtems4.12-newlib.
make
make install.
I am attaching the script by which i am trying to build newlib.
I do not know where i am making mistake.
Is this a new file or just checking the previous commit was ok? I checked
that the last method was in the library after the commit.
--joel
Thanks & Regards,
Aditya Upadhyay
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170617/23b95053/attachment.html>
