Generation of ccoshl.o file
aditya upadhyay aadit0402 at gmail.com
Sat Jun 17 20:00:51 UTC 2017
I am just checking the previous file. it is not a new file.
When i make changes in Makefile.am and trying to execute the j-newlib,
 the Makefile.in is not generating. Is there another method for
generating Makefile.in file in newlib.
Regards,
Aditya
On Sun, Jun 18, 2017 at 1:17 AM, Joel Sherrill <joel at rtems.org> wrote:
> On Jun 17, 2017 2:28 PM, "aditya upadhyay" <aadit0402 at gmail.com> wrote:
> Hello All,
> I have ported ccoshl.c from freebsd and trying to check whether the
> lib-a-w_ccoshl.o file has generated or not.
> When i executed this command :
> aditya at aditya-Lenovo-ideapad-110-15ACL:~/development/b-sparc-rtems4.12-newlib$
> sparc-rtems4.12-nm
> /home/aditya/development/b-sparc-rtems4.12-newlib/sparc-rtems4.12/newlib/libm.a
> I am not seeing the file like lib_a-w_ccoshl.o. However i have used
> j-newlib script to build newlib for sparc and arm bsp.
> These are the commands i have to build the newlib :
> aditya at aditya-Lenovo-ideapad-110-15ACL:~$ cd development/newlib/
> aditya at aditya-Lenovo-ideapad-110-15ACL:~/development/newlib$ ../j-newlib
> Then these two files has been generated : b-sparc-rtems4.12-newlib and
> b-arm-rtems4.12-newlib.
> make
> make install.
> I am attaching the script by which i am trying to build newlib.
> I do not know where i am making mistake.
> Is this a new file or just checking the previous commit was ok? I checked
> that the last method was in the library after the commit.
> --joel
> Thanks & Regards,
> Aditya Upadhyay
> devel mailing list
> devel at rtems.org
