Are you happy with how the project is going?
Denis Obrezkov
denisobrezkov at gmail.com
Sat Jun 17 22:31:15 UTC 2017
2017-06-17 22:11 GMT+03:00 Denis Obrezkov <denisobrezkov at gmail.com>:
>>> Can you run RTEMS hello world? Or does printf make that too large? If
>> that is
>> too large, you need to force the tests to switch to printk(). There is
>> some magic
>> in testsuites/configure.ac for that.
>> The low ticker examples (especially the last one) will show configure
>> options
>> to cut memory use.
>> But these are hacks on individual tests. If there is a simulator which
>> has interrupts,
>> I would be testing on it since you will be battling the architecture not
>> a RAM limit.
>> Your project is the port not to put RTEMS into a tiny memory space. :)
>> --joel
>>> Regards, Denis Obrezkov
>> I was able to run the low ticker example further than in my earlier
> attempts.
> But now I have a problem with it:
> #0 memset (m=0xb98a0641, c=0, n=102) at ../../../../../gcc-7.1.0/
> newlib/libc/string/memset.c:62
> #1 0x20403168 in _Heap_Initialize (heap=0xb98a0641, heap_area_begin_ptr=0x80002456,
> heap_area_size=7082, page_size=8)
> at /home/reprofy/Projects/riscv/rtems/development/rtems/
> kernel/rtems-riscv/c/src/../../cpukit/score/src/heap.c:230
> #2 0x20400954 in RTEMS_Malloc_Initialize (areas=0x80003f78, area_count=1,
> extend=0x0)
> kernel/rtems-riscv/c/src/../../cpukit/libcsupport/src/
> malloc_initialize.c:40
> #3 0x20400378 in bsp_work_area_initialize_default
> (area_begin=0x80000e10, area_size=12784) at ../../../../../.././hifive1/
> lib/include/bsp/bootcard.h:158
> #4 0x204003c0 in bsp_work_area_initialize () at
> kernel/rtems-riscv/c/src/lib/libbsp/riscv32/hifive1/../../
> shared/bspgetworkarea.c:61
> #5 0x204021bc in rtems_initialize_executive () at
> kernel/rtems-riscv/c/src/../../cpukit/sapi/src/exinit.c:95
> #6 0x2040031c in boot_card (cmdline=0x0) at /home/reprofy/Projects/riscv/
> rtems/development/rtems/kernel/rtems-riscv/c/src/lib/
> libbsp/riscv32/hifive1/../../shared/bootcard.c:76
> #7 0x20400064 in _end_clear_bss () at /home/reprofy/Projects/riscv/
> libbsp/riscv32/hifive1/start/start.S:116
> I want to figure out, why it wants to use memset on these addresses,
> because 0x80004000 is the maximum available address.
I was able to proceed further after adding
#define CONFIGURE_UNIFIED_WORK_AREAS
to init.c of low_ticker example.
Now I get an error:
#0 0x2040d940 in _Chain_Initialize_node (the_node=0x80003ec0) at
../../cpukit/../../../hifive1/lib/include/rtems/score/chainimpl.h:127
#1 0x2040da82 in _Chain_Iterator_initialize (the_chain=0x80000320
<_User_extensions_List>, the_registry=0x8000032c
<_User_extensions_List+12>, the_iterator=0x80003ec0,
direction=CHAIN_ITERATOR_FORWARD) at
../../cpukit/../../../hifive1/lib/include/rtems/score/chainimpl.h:1049
#2 0x2040de90 in _User_extensions_Iterate (arg=0x80003f18,
visitor=0x2040dd48 <_User_extensions_Fatal_visitor>,
at
/home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/../../cpukit/score/src/userextiterate.c:174
#3 0x204036c4 in _User_extensions_Fatal (source=INTERNAL_ERROR_CORE,
error=4) at
../../cpukit/../../../hifive1/lib/include/rtems/score/userextimpl.h:307
#4 0x204036e8 in _Terminate (the_source=INTERNAL_ERROR_CORE, the_error=4)
at
/home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/../../cpukit/score/src/interr.c:35
#5 0x20403730 in _Internal_error
(core_error=INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL)
at
/home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/../../cpukit/score/src/interr.c:44
#6 0x20403824 in _ISR_Handler_initialization () at
/home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/../../cpukit/score/src/isr.c:51
#7 0x20402170 in rtems_initialize_data_structures () at
/home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/../../cpukit/sapi/src/exinit.c:82
#8 0x204021bc in rtems_initialize_executive () at
/home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/../../cpukit/sapi/src/exinit.c:95
#9 0x2040031c in boot_card (cmdline=0x0) at
/home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/lib/libbsp/riscv32/hifive1/../../shared/bootcard.c:76
#10 0xffffcd98 in ?? ()
And I found out that rtems_minimum_stack_size variable is 0xab817bb3.
And I don't know why - in the low ticker example it is set to 512.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170618/d4c2c57f/attachment.html>
