Valid interrupt vectors and the interrupt server
Christian Mauderer christian.mauderer at embedded-brains.de
Sun Jun 18 07:45:52 UTC 2017
----- Ursprüngliche Mail -----
> Von: "Chris Johns" <chrisj at rtems.org>
> An: "Christian Mauderer" <christian.mauderer at embedded-brains.de>, devel at rtems.org
> Gesendet: Sonntag, 18. Juni 2017 04:31:22
> Betreff: Re: Valid interrupt vectors and the interrupt server
> On 18/6/17 2:17 am, Christian Mauderer wrote:
>> Hello,
>> I had a problem recently, that the interrupt server (for example used in libbsd)
>> caused some odd behaviour on an ARM Cortex BSP. That was solved by the
>> following patch:
>> https://git.rtems.org/rtems/commit/?id=ce3ac00c
>> Just today Sichen Zhao had a similar problem on the BBB:
>> https://lists.rtems.org/pipermail/devel/2017-June/018158.html
>> I took a look and it seems that there are a lot of BSPs which don't check for
>> the valid interrupt vector range in their bsp_interrupt_vector_disable/enable
>> functions. Every one of them will most likely have a problems if someone tries
>> to use libbsd or the interrupt server.
> I seem to be missing something. Is the interrupt server and libbsd attempting to
> use interrupts that are no valid for these board and this is causing a problem?
> Chris
Hello Chris,
yes the interrupt server uses an pseudo interrupt on _every_ target:
https://git.rtems.org/rtems/tree/c/src/lib/libbsp/shared/src/irq-server.c?id=ae359a9df#n31
That has nothing to do with the libbsd. The only connection is that libbsd uses the interrupt server for some interrupt processing.
Kind regards
Christian
embedded brains GmbH
Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
