[PATCH] Fix beagle bsp irq issue
Sichen Zhao zsc19940506 at outlook.com
Sun Jun 18 13:04:33 UTC 2017
No, i don't think it should return an error.
The interrupt server uses one pseudo interrupt number. It only works if these functions don't do anything odd and don't return an error for a vector that is out of range.
Christian has the same issue, and he explained it:
https://lists.rtems.org/pipermail/devel/2017-June/018162.html
Best Regards
Sichen Zhao
________________________________________
From: devel <devel-bounces at rtems.org> on behalf of Gedare Bloom <gedare at rtems.org>
Sent: Sunday, June 18, 2017 19:54
To: Sichen Zhao
Cc: punit vara; Christian Mauderer; devel at rtems.org
Subject: Re: [PATCH] Fix beagle bsp irq issue
On Sat, Jun 17, 2017 at 10:31 AM, Sichen Zhao <1473996754 at qq.com> wrote:
> Enable/disable vector routines now check for a valid vector.
> Without these guards, the enable/disable vector routines
> will not work with the interrupt server.
>  c/src/lib/libbsp/arm/beagle/irq.c | 22 ++++++++++++++--------
>  1 file changed, 14 insertions(+), 8 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/beagle/irq.c b/c/src/lib/libbsp/arm/beagle/irq.c
> index d080a5e..35750ba 100644
> --- a/c/src/lib/libbsp/arm/beagle/irq.c
> +++ b/c/src/lib/libbsp/arm/beagle/irq.c
> @@ -98,11 +98,14 @@ static uint32_t omap_get_mir_reg(rtems_vector_number vector, uint32_t *const mas
>  rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
>    uint32_t mask, cur;
> -  uint32_t mir_reg = omap_get_mir_reg(vector, &mask);
> -  cur = mmio_read(omap_intr.base + mir_reg);
> -  mmio_write(omap_intr.base + mir_reg, cur & ~mask);
> -  flush_data_cache();
> +  if (bsp_interrupt_is_valid_vector(vector)) {
> +    uint32_t mir_reg = omap_get_mir_reg(vector, &mask);
> +    cur = mmio_read(omap_intr.base + mir_reg);
> +    mmio_write(omap_intr.base + mir_reg, cur & ~mask);
> +    flush_data_cache();
>    return RTEMS_SUCCESSFUL;
Should this return an error in case vector is not valid?
> @@ -110,11 +113,14 @@ rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
>  rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
>    uint32_t mask, cur;
> -  mmio_write(omap_intr.base + mir_reg, cur | mask);
> +    mmio_write(omap_intr.base + mir_reg, cur | mask);
ditto
> 2.7.4
> devel mailing list
> devel at rtems.org
devel mailing list
devel at rtems.org
