[PATCH] bsps: Improve interrupt vector enable/disable API
Christian Mauderer christian.mauderer at embedded-brains.de
Mon Jun 19 18:45:43 UTC 2017
----- Ursprüngliche Mail -----
> Von: "Gedare Bloom" <gedare at rtems.org>
> An: "Sebastian Huber" <sebastian.huber at embedded-brains.de>
> CC: "RTEMS Devel" <rtems-devel at rtems.org>
> Gesendet: Montag, 19. Juni 2017 16:34:00
> Betreff: Re: [PATCH] bsps: Improve interrupt vector enable/disable API
> On Mon, Jun 19, 2017 at 9:19 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> Change bsp_interrupt_vector_enable() and bsp_interrupt_vector_disable()
>> to not return a status code.  Add bsp_interrupt_assert() and use it to
>> validate the vector number in the vector enable/disable implementations.
>>  c/src/lib/libbsp/arm/beagle/irq.c                  | 12 +++---
>>  c/src/lib/libbsp/arm/edb7312/irq/irq.c             | 12 +++---
>>  c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c           |  8 ++--
>>  c/src/lib/libbsp/arm/lpc24xx/irq/irq.c             | 10 ++---
>>  c/src/lib/libbsp/arm/lpc32xx/irq/irq.c             | 49 +++++++++-------------
>>  c/src/lib/libbsp/arm/raspberrypi/irq/irq.c         | 16 ++-----
>>  c/src/lib/libbsp/arm/shared/arm-gic-irq.c          | 28 ++++---------
>>  .../lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c  | 18 +++-----
>>  c/src/lib/libbsp/arm/tms570/irq/irq.c              | 40 +++---------------
>>  c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c   |  8 ++--
>>  c/src/lib/libbsp/i386/pc386/timer/timer.c          |  7 +---
>>  c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c |  6 ---
>>  c/src/lib/libbsp/i386/shared/irq/irq.c             | 14 +++----
>>  c/src/lib/libbsp/lm32/shared/irq/irq.c             |  8 ++--
>>  c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c         | 44 +++++++------------
>>  c/src/lib/libbsp/mips/shared/irq/irq.c             |  8 ++--
>>  c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c       |  8 ++--
>>  c/src/lib/libbsp/powerpc/gen5200/irq/irq.c         | 32 +++++++-------
>>  c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c         | 16 +++----
>>  c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c      | 12 +++---
>>  c/src/lib/libbsp/powerpc/psim/irq/irq_init.c       |  8 ++--
>>  c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c    |  8 ++--
>>  c/src/lib/libbsp/powerpc/qoriq/irq/irq.c           | 24 +++++------
>>  c/src/lib/libbsp/powerpc/t32mppc/irq/irq.c         |  8 ++--
>>  c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c          | 32 +++++++-------
>>  c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c     | 32 +++++---------
>>  c/src/lib/libbsp/shared/include/irq-generic.h      | 30 +++++++------
>>  c/src/lib/libbsp/shared/src/irq-generic.c          | 16 +------
>>  c/src/lib/libbsp/shared/src/irq-server.c           |  8 +++-
>>  c/src/lib/libbsp/sparc/shared/irq/irq-shared.c     | 10 ++---
>>  c/src/lib/libcpu/arm/at91rm9200/irq/irq.c          | 10 ++---
>>  c/src/lib/libcpu/arm/lpc22xx/irq/irq.c             | 10 ++---
>>  c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c           | 20 ++++-----
>>  c/src/lib/libcpu/arm/pxa255/irq/irq.c              | 10 ++---
>>  c/src/lib/libcpu/arm/s3c24xx/irq/irq.c             |  8 ++--
>>  c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c         | 18 +++-----
>>  36 files changed, 238 insertions(+), 370 deletions(-)
>> diff --git a/c/src/lib/libbsp/arm/beagle/irq.c
>> b/c/src/lib/libbsp/arm/beagle/irq.c
>> index d080a5e851..2fa1a5b0f0 100644
>> --- a/c/src/lib/libbsp/arm/beagle/irq.c
>> +++ b/c/src/lib/libbsp/arm/beagle/irq.c
>> @@ -95,28 +95,28 @@ static uint32_t omap_get_mir_reg(rtems_vector_number vector,
>> uint32_t *const mas
>>    return mir_reg;
>> -rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
>> +void bsp_interrupt_vector_enable(rtems_vector_number vector)
>>    uint32_t mask, cur;
>>    uint32_t mir_reg = omap_get_mir_reg(vector, &mask);
>> +  bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
>>    cur = mmio_read(omap_intr.base + mir_reg);
>>    mmio_write(omap_intr.base + mir_reg, cur & ~mask);
>>    flush_data_cache();
>> -  return RTEMS_SUCCESSFUL;
>> -rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
>> +void bsp_interrupt_vector_disable(rtems_vector_number vector)
>>    uint32_t mask, cur;
>>    mmio_write(omap_intr.base + mir_reg, cur | mask);
>>    flush_data_cache();
>>  rtems_status_code bsp_interrupt_facility_initialize(void)
>> diff --git a/c/src/lib/libbsp/arm/edb7312/irq/irq.c
>> b/c/src/lib/libbsp/arm/edb7312/irq/irq.c
>> index 8c18ea7abd..1d9151a1bd 100644
>> --- a/c/src/lib/libbsp/arm/edb7312/irq/irq.c
>> +++ b/c/src/lib/libbsp/arm/edb7312/irq/irq.c
>> @@ -27,8 +27,10 @@ void edb7312_interrupt_dispatch(rtems_vector_number vector)
>>    bsp_interrupt_handler_dispatch(vector);
>>      if(vector >= BSP_EXTFIQ && vector <= BSP_SSEOTI)
>>          /* interrupt managed by INTMR1 and INTSR1 */
>> @@ -49,12 +51,12 @@ rtems_status_code
>>          /* interrupt managed by INTMR3 and INTSR3 */
>>          *EP7312_INTMR3 |= (1 << (vector - 21));
>> @@ -75,8 +77,6 @@ rtems_status_code
>>          *EP7312_INTMR3 &= ~(1 << (vector - 21));
>> diff --git a/c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c
>> b/c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c
>> index 79665b46fd..886f928d2d 100644
>> --- a/c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c
>> +++ b/c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c
>> @@ -50,14 +50,14 @@ unsigned lpc24xx_irq_get_priority(rtems_vector_number
>> vector)
>>  #ifdef ARM_MULTILIB_ARCH_V4
>> diff --git a/c/src/lib/libbsp/arm/lpc24xx/irq/irq.c
>> b/c/src/lib/libbsp/arm/lpc24xx/irq/irq.c
>> index 408f20db4f..7801c37843 100644
>> --- a/c/src/lib/libbsp/arm/lpc24xx/irq/irq.c
>> +++ b/c/src/lib/libbsp/arm/lpc24xx/irq/irq.c
>> @@ -64,18 +64,16 @@ unsigned lpc24xx_irq_get_priority(rtems_vector_number
>> vector)
>>    VICIntEnable = 1U << vector;
>>    VICIntEnClear = 1U << vector;
>> diff --git a/c/src/lib/libbsp/arm/lpc32xx/irq/irq.c
>> b/c/src/lib/libbsp/arm/lpc32xx/irq/irq.c
>> index 37080f4de2..eac320000b 100755
>> --- a/c/src/lib/libbsp/arm/lpc32xx/irq/irq.c
>> +++ b/c/src/lib/libbsp/arm/lpc32xx/irq/irq.c
>> @@ -50,11 +50,6 @@ static lpc32xx_irq_fields lpc32xx_irq_priority_masks
>> [LPC32XX_IRQ_PRIORITY_COUNT
>>  static lpc32xx_irq_fields lpc32xx_irq_enable;
>> -static inline bool lpc32xx_irq_is_valid(rtems_vector_number vector)
>> -  return vector <= BSP_INTERRUPT_VECTOR_MAX;
>>  static inline bool lpc32xx_irq_priority_is_valid(unsigned priority)
>>    return priority <= LPC32XX_IRQ_PRIORITY_LOWEST;
>> @@ -130,7 +125,7 @@ static inline unsigned lpc32xx_irq_get_index(uint32_t val)
>>  void lpc32xx_irq_set_priority(rtems_vector_number vector, unsigned priority)
>> -  if (lpc32xx_irq_is_valid(vector)) {
>> +  if (bsp_interrupt_is_valid_vector(vector)) {
>>      rtems_interrupt_level level;
>>      unsigned i = 0;
>> @@ -156,7 +151,7 @@ void lpc32xx_irq_set_priority(rtems_vector_number vector,
>> unsigned priority)
>>  unsigned lpc32xx_irq_get_priority(rtems_vector_number vector)
>>      return lpc32xx_irq_priority_table [vector];
>>    } else {
>>      return LPC32XX_IRQ_PRIORITY_LOWEST;
>> @@ -165,7 +160,7 @@ unsigned lpc32xx_irq_get_priority(rtems_vector_number
>> vector)
>>  void lpc32xx_irq_set_activation_polarity(rtems_vector_number vector,
>>  lpc32xx_irq_activation_polarity activation_polarity)
>>      rtems_interrupt_disable(level);
>> @@ -180,7 +175,7 @@ void lpc32xx_irq_set_activation_polarity(rtems_vector_number
>> vector, lpc32xx_irq
>>  lpc32xx_irq_get_activation_polarity(rtems_vector_number vector)
>>      if (lpc32xx_irq_is_bit_set_in_register(vector, LPC32XX_IRQ_OFFSET_APR)) {
>>        return LPC32XX_IRQ_ACTIVE_HIGH_OR_RISING_EDGE;
>>      } else {
>> @@ -193,7 +188,7 @@ lpc32xx_irq_activation_polarity
>>  void lpc32xx_irq_set_activation_type(rtems_vector_number vector,
>>  lpc32xx_irq_activation_type activation_type)
>> @@ -208,7 +203,7 @@ void lpc32xx_irq_set_activation_type(rtems_vector_number
>> vector, lpc32xx_irq_act
>>  lpc32xx_irq_activation_type lpc32xx_irq_get_activation_type(rtems_vector_number
>>  vector)
>>      if (lpc32xx_irq_is_bit_set_in_register(vector, LPC32XX_IRQ_OFFSET_ATR)) {
>>        return LPC32XX_IRQ_EDGE_SENSITIVE;
>>      } else {
>> @@ -265,32 +260,28 @@ void bsp_interrupt_dispatch(void)
>>    lpc32xx.sic_2.er = er_sic_2 & lpc32xx_irq_enable.field.sic_2;
>> -    rtems_interrupt_level level;
>> +  rtems_interrupt_level level;
>> -    rtems_interrupt_disable(level);
>> -    lpc32xx_irq_set_bit_in_register(vector, LPC32XX_IRQ_OFFSET_ER);
>> -    lpc32xx_irq_set_bit_in_field(vector, &lpc32xx_irq_enable);
>> -    rtems_interrupt_enable(level);
>> +  rtems_interrupt_disable(level);
>> +  lpc32xx_irq_set_bit_in_register(vector, LPC32XX_IRQ_OFFSET_ER);
>> +  lpc32xx_irq_set_bit_in_field(vector, &lpc32xx_irq_enable);
>> +  rtems_interrupt_enable(level);
>> -    lpc32xx_irq_clear_bit_in_field(vector, &lpc32xx_irq_enable);
>> -    lpc32xx_irq_clear_bit_in_register(vector, LPC32XX_IRQ_OFFSET_ER);
>> +  lpc32xx_irq_clear_bit_in_field(vector, &lpc32xx_irq_enable);
>> +  lpc32xx_irq_clear_bit_in_register(vector, LPC32XX_IRQ_OFFSET_ER);
>>  void lpc32xx_set_exception_handler(
>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
>> b/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
>> index 48f781075b..5b10385bfe 100644
>> --- a/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
>> +++ b/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
>> @@ -139,26 +139,18 @@ void bsp_interrupt_dispatch(void)
>> -  if ( vector > BSP_INTERRUPT_VECTOR_MAX )
>> -    return RTEMS_INVALID_ID;
>>    BCM2835_REG(bsp_vector_to_reg(vector)->enable_reg_addr) =
>>                bsp_vector_to_mask(vector);
>>    BCM2835_REG(bsp_vector_to_reg(vector)->disable_reg_addr) =
>>  void bsp_interrupt_handler_default(rtems_vector_number vector)
>> diff --git a/c/src/lib/libbsp/arm/shared/arm-gic-irq.c
>> b/c/src/lib/libbsp/arm/shared/arm-gic-irq.c
>> index 487ee16f72..5a4a998bfb 100644
>> --- a/c/src/lib/libbsp/arm/shared/arm-gic-irq.c
>> +++ b/c/src/lib/libbsp/arm/shared/arm-gic-irq.c
>> @@ -44,34 +44,22 @@ void bsp_interrupt_dispatch(void)
>> -  rtems_status_code sc = RTEMS_SUCCESSFUL;
>> +  volatile gic_dist *dist = ARM_GIC_DIST;
>> -  if (bsp_interrupt_is_valid_vector(vector)) {
>> -    volatile gic_dist *dist = ARM_GIC_DIST;
>> -    gic_id_enable(dist, vector);
>> -  } else {
>> -    sc = RTEMS_INVALID_ID;
>> -  return sc;
>> +  gic_id_enable(dist, vector);
>> -    gic_id_disable(dist, vector);
>> -  } else {
>> -  return sc;
>> +  gic_id_disable(dist, vector);
>>  static inline uint32_t get_id_count(volatile gic_dist *dist)
>> diff --git a/c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c
>> b/c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c
>> index df17c26cdd..1d930a4591 100644
>> --- a/c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c
>> +++ b/c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c
>> @@ -22,22 +22,16 @@
>>  #ifdef ARM_MULTILIB_ARCH_V7M
>> -    _ARMV7M_NVIC_Set_enable((int) vector);
>> +  _ARMV7M_NVIC_Set_enable((int) vector);
>> -    _ARMV7M_NVIC_Clear_enable((int) vector);
>> +  _ARMV7M_NVIC_Clear_enable((int) vector);
>> diff --git a/c/src/lib/libbsp/arm/tms570/irq/irq.c
>> b/c/src/lib/libbsp/arm/tms570/irq/irq.c
>> index 7a2a55fff5..579c11ed2a 100644
>> --- a/c/src/lib/libbsp/arm/tms570/irq/irq.c
>> +++ b/c/src/lib/libbsp/arm/tms570/irq/irq.c
>> @@ -28,24 +28,6 @@
>>  #include <bsp/irq.h>
>>  #include <rtems/score/armv4.h>
>> - * @brief Check if isr vector is valid
>> - * Check if isr vector is valid by using BSP_INTERRUPT_VECTOR_MAX and
>> - * BSP_INTERRUPT_VECTOR_MIN defined in irq.h
>> - * @param[in] vector interrupt vector to be checked.
>> - * @retval TRUE vector is valid.
>> - * @retval FALSE vector is invalid
>> -static inline bool tms570_irq_is_valid(
>> -  rtems_vector_number vector
>> -  return (vector <= BSP_INTERRUPT_VECTOR_MAX) &&
>> -         (vector > BSP_INTERRUPT_VECTOR_MIN);
>>  unsigned int priorityTable[BSP_INTERRUPT_VECTOR_MAX+1];
>> @@ -64,7 +46,7 @@ void tms570_irq_set_priority(
>>    unsigned priority
>> -  if ( tms570_irq_is_valid(vector) ) {
>> +  if ( bsp_interrupt_is_valid_vector(vector) ) {
>>      priorityTable[vector] = priority;
>> @@ -84,7 +66,7 @@ unsigned tms570_irq_get_priority(
>>     return priorityTable[vector];
>>   return 0;
>> @@ -114,17 +96,12 @@ void bsp_interrupt_dispatch(void)
>>   * @retval RTEMS_INVALID_ID vector is invalid.
>>   * @retval RTEMS_SUCCESSFUL interrupt source enabled.
>> -  if( !tms570_irq_is_valid(vector) ) {
>>    TMS570_VIM.REQENASET[vector >> 5] = 1 << (vector & 0x1f);
>> @@ -136,17 +113,12 @@ rtems_status_code bsp_interrupt_vector_enable(
>>   * @retval RTEMS_SUCCESSFUL interrupt source disabled.
>>    TMS570_VIM.REQENACLR[vector >> 5] = 1 << (vector & 0x1f);
>> diff --git a/c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c
>> b/c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c
>> index 057a0f7e81..994e25bf0e 100644
>> --- a/c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c
>> +++ b/c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c
>> @@ -53,12 +53,12 @@ rtems_status_code bsp_interrupt_facility_initialize()
>>    return 0;
>> -  return 0;
>> -  return 0;
>> diff --git a/c/src/lib/libbsp/i386/pc386/timer/timer.c
>> b/c/src/lib/libbsp/i386/pc386/timer/timer.c
>> index 5bef139d38..16d3d66176 100644
>> --- a/c/src/lib/libbsp/i386/pc386/timer/timer.c
>> +++ b/c/src/lib/libbsp/i386/pc386/timer/timer.c
>> @@ -153,17 +153,12 @@ static void timerOn(const rtems_raw_irq_connect_data*
>> used)
>>    bsp_interrupt_vector_enable(used->idtIndex - BSP_IRQ_VECTOR_BASE);
>> -static int timerIsOn(const rtems_raw_irq_connect_data *used)
>> -  return bsp_interrupt_vector_enable(used->idtIndex - BSP_IRQ_VECTOR_BASE);
>>  static rtems_raw_irq_connect_data timer_raw_irq_data = {
>>    BSP_PERIODIC_TIMER + BSP_IRQ_VECTOR_BASE,
>>    timerisr,
>>    timerOn,
>>    timerOff,
>> -  timerIsOn
>> +  NULL
>> diff --git a/c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c
>> b/c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c
>> index 7802270140..d47d057860 100644
>> --- a/c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c
>> +++ b/c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c
>> @@ -173,11 +173,6 @@ static void BSP_uart_off(const rtems_raw_irq_connect_data*
>> used)
>>    bsp_interrupt_vector_disable(used->idtIndex - BSP_IRQ_VECTOR_BASE);
>> -static int BSP_uart_isOn(const rtems_raw_irq_connect_data* used)
>>   * In order to have a possibility to break into
>>   * running program, one has to call this function
>> @@ -210,7 +205,6 @@ void i386_stub_glue_init_breakin(void)
>>      uart_raw_irq_data.on  = BSP_uart_on;
>>      uart_raw_irq_data.off = BSP_uart_off;
>> -    uart_raw_irq_data.isOn= BSP_uart_isOn;
>>      /* Install ISR  */
>>      uart_raw_irq_data.idtIndex = port_current->ulIntVector + BSP_IRQ_VECTOR_BASE;
>> diff --git a/c/src/lib/libbsp/i386/shared/irq/irq.c
>> b/c/src/lib/libbsp/i386/shared/irq/irq.c
>> index f4ffd8c0e4..ac08f1f7be 100644
>> --- a/c/src/lib/libbsp/i386/shared/irq/irq.c
>> +++ b/c/src/lib/libbsp/i386/shared/irq/irq.c
>> @@ -270,18 +270,16 @@ static inline bool
>> bsp_interrupt_vector_is_valid(rtems_vector_number vector)
>>    return BSP_i8259a_irq_valid((const rtems_irq_number) vector);
>> -  if (bsp_interrupt_vector_is_valid(vector))
>> -    BSP_irq_enable_at_i8259a(vector);
>> +  BSP_irq_enable_at_i8259a(vector);
>> -    BSP_irq_disable_at_i8259a(vector);
>> +  BSP_irq_disable_at_i8259a(vector);
>> diff --git a/c/src/lib/libbsp/lm32/shared/irq/irq.c
>> b/c/src/lib/libbsp/lm32/shared/irq/irq.c
>> index 8f9bfaf1ac..79626ee449 100644
>> --- a/c/src/lib/libbsp/lm32/shared/irq/irq.c
>> +++ b/c/src/lib/libbsp/lm32/shared/irq/irq.c
>> @@ -17,14 +17,14 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
>>    lm32_interrupt_unmask(1 << vector);
>>    lm32_interrupt_mask(1 << vector);
>> diff --git a/c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c
>> b/c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c
>> index 58e904426a..f02231b67c 100644
>> --- a/c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c
>> +++ b/c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c
>> @@ -59,42 +59,30 @@ static rtems_vector_number vector_to_exception_vector(
>>    return vector + 64U;
>> +  volatile uint32_t *imr = vector_to_imr(vector);
>> +  uint32_t bit = vector_to_bit(vector);
>> -    volatile uint32_t *imr = vector_to_imr(vector);
>> -    uint32_t bit = vector_to_bit(vector);
>> -    *imr &= ~bit;
>> -  } else {
>> -  return sc;
>> +  *imr &= ~bit;
>> -    *imr |= bit;
>> -  } else {
>> -  return sc;
>> +  *imr |= bit;
>>  static void_func get_exception_handler(rtems_vector_number vector)
>> diff --git a/c/src/lib/libbsp/mips/shared/irq/irq.c
>> b/c/src/lib/libbsp/mips/shared/irq/irq.c
>> index d4941763bc..1c2d3b8c5b 100644
>> --- a/c/src/lib/libbsp/mips/shared/irq/irq.c
>> +++ b/c/src/lib/libbsp/mips/shared/irq/irq.c
>> @@ -67,14 +67,14 @@ static inline bool bsp_irq_is_valid(rtems_vector_number
>> vector)
>> diff --git a/c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c
>> b/c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c
>> index 00d53d7409..f9a7b6426d 100644
>> --- a/c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c
>> +++ b/c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c
>> @@ -32,12 +32,12 @@ rtems_status_code bsp_interrupt_facility_initialize()
>>    return 0;
>> -  return 0;
>> -  return 0;
>> diff --git a/c/src/lib/libbsp/powerpc/gen5200/irq/irq.c
>> b/c/src/lib/libbsp/powerpc/gen5200/irq/irq.c
>> index 029ed3182e..58e2f2a987 100644
>> --- a/c/src/lib/libbsp/powerpc/gen5200/irq/irq.c
>> +++ b/c/src/lib/libbsp/powerpc/gen5200/irq/irq.c
>> @@ -359,24 +359,26 @@ static inline void BSP_disable_crit_irq_at_siu(
>> rtems_vector_number
>>   * This function enables a given siu interrupt
>> -rtems_status_code bsp_interrupt_vector_enable( rtems_vector_number irqLine)
>> +void bsp_interrupt_vector_enable( rtems_vector_number vector)
>> -  int base_index = get_siu_irq_base_index( irqLine);
>> +  int base_index = get_siu_irq_base_index( vector);
>> -  if (is_siu_irq( irqLine)) {
>> +  if (is_siu_irq( vector)) {
>>      rtems_interrupt_disable( level);
>>      switch (base_index) {
>>        case BSP_PER_IRQ_LOWEST_OFFSET:
>> -        BSP_enable_per_irq_at_siu( irqLine);
>> +        BSP_enable_per_irq_at_siu( vector);
>>          break;
>>        case BSP_MAIN_IRQ_LOWEST_OFFSET:
>> -        BSP_enable_main_irq_at_siu( irqLine);
>> +        BSP_enable_main_irq_at_siu( vector);
>>          break;
>>        case BSP_CRIT_IRQ_LOWEST_OFFSET:
>> -        BSP_enable_crit_irq_at_siu( irqLine);
>> +        BSP_enable_crit_irq_at_siu( vector);
>>          break;
>>        default:
>>          rtems_interrupt_enable( level);
>> @@ -386,31 +388,31 @@ rtems_status_code bsp_interrupt_vector_enable(
>>   * This function disables a given siu interrupt
>> -rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number irqLine)
>> +void bsp_interrupt_vector_disable( rtems_vector_number vector)
>> -        BSP_disable_per_irq_at_siu( irqLine);
>> +        BSP_disable_per_irq_at_siu( vector);
>>          break;
>> -        BSP_disable_main_irq_at_siu( irqLine);
>> +        BSP_disable_main_irq_at_siu( vector);
>>          break;
>> -        BSP_disable_crit_irq_at_siu( irqLine);
>> +        BSP_disable_crit_irq_at_siu( vector);
>>          break;
>>        default:
>> @@ -420,8 +422,6 @@ rtems_status_code bsp_interrupt_vector_disable(
>>  #if (BENCHMARK_IRQ_PROCESSING == 0)
>> diff --git a/c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c
>> b/c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c
>> index 2d89cfa137..7a8ce3cc0b 100644
>> --- a/c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c
>> +++ b/c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c
>> @@ -376,11 +376,13 @@ rtems_status_code
>> mpc83xx_ipic_set_highest_priority_interrupt(
>>   * functions to enable/disable a source at the ipic
>> -rtems_status_code bsp_interrupt_vector_enable( rtems_vector_number irqnum)
>> -  rtems_vector_number vecnum = irqnum - BSP_IPIC_IRQ_LOWEST_OFFSET;
>> +  rtems_vector_number vecnum = vector - BSP_IPIC_IRQ_LOWEST_OFFSET;
>>    const BSP_isrc_rsc_t *rsc_ptr;
>>    if (MPC83XX_IPIC_IS_VALID_VECTOR( vecnum)) {
>>      rsc_ptr = &mpc83xx_ipic_isrc_rsc [vecnum];
>>      if (rsc_ptr->mask_reg != NULL) {
>> @@ -392,15 +394,15 @@ rtems_status_code bsp_interrupt_vector_enable(
>> -rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number irqnum)
>> @@ -412,8 +414,6 @@ rtems_status_code bsp_interrupt_vector_disable(
>> diff --git a/c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c
>> b/c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c
>> index 52465ec2a7..c145186a52 100644
>> --- a/c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c
>> +++ b/c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c
>> @@ -328,28 +328,28 @@ BSP_CPM_irq_init(void)
>> +void bsp_interrupt_vector_enable( rtems_vector_number irqnum)
>>    if (is_cpm_irq(irqnum)) {
>>       * Enable interrupt at PIC level
>>      BSP_irq_enable_at_cpm (irqnum);
>> +void bsp_interrupt_vector_disable( rtems_vector_number irqnum)
>>       * disable interrupt at PIC level
>>      BSP_irq_disable_at_cpm (irqnum);
>> diff --git a/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c
>> b/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c
>> index 59f0e1dcea..61600a9d62 100644
>> --- a/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c
>> +++ b/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c
>> @@ -102,16 +102,16 @@ static int psim_exception_handler(
>>    /* FIXME: do something */
>> diff --git a/c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c
>> b/c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c
>> index f4592a375f..b5533e0872 100644
>> --- a/c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c
>> +++ b/c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c
>> @@ -38,16 +38,16 @@ static int qemuppc_exception_handler(
>> diff --git a/c/src/lib/libbsp/powerpc/qoriq/irq/irq.c
>> b/c/src/lib/libbsp/powerpc/qoriq/irq/irq.c
>> index da7def3913..ea086215fc 100644
>> --- a/c/src/lib/libbsp/powerpc/qoriq/irq/irq.c
>> +++ b/c/src/lib/libbsp/powerpc/qoriq/irq/irq.c
>> @@ -175,28 +175,24 @@ rtems_status_code qoriq_pic_set_affinity(
>>  static rtems_status_code pic_vector_enable(rtems_vector_number vector, uint32_t
>>  msk)
>> -               volatile qoriq_pic_src_cfg *src_cfg = get_src_cfg(vector);
>> -               rtems_interrupt_lock_context lock_context;
>> +       volatile qoriq_pic_src_cfg *src_cfg = get_src_cfg(vector);
>> +       rtems_interrupt_lock_context lock_context;
>> -               rtems_interrupt_lock_acquire(&lock, &lock_context);
>> -               src_cfg->vpr = (src_cfg->vpr & ~VPR_MSK) | msk;
>> -               rtems_interrupt_lock_release(&lock, &lock_context);
>> -       return sc;
>> +       rtems_interrupt_lock_acquire(&lock, &lock_context);
>> +       src_cfg->vpr = (src_cfg->vpr & ~VPR_MSK) | msk;
>> +       rtems_interrupt_lock_release(&lock, &lock_context);
>> -       return pic_vector_enable(vector, 0);
>> +       pic_vector_enable(vector, 0);
>> -       return pic_vector_enable(vector, VPR_MSK);
>> +       pic_vector_enable(vector, VPR_MSK);
>>  static void qoriq_interrupt_dispatch(void)
>> diff --git a/c/src/lib/libbsp/powerpc/t32mppc/irq/irq.c
>> b/c/src/lib/libbsp/powerpc/t32mppc/irq/irq.c
>> index 3cabcdef35..0c98c3a27d 100644
>> --- a/c/src/lib/libbsp/powerpc/t32mppc/irq/irq.c
>> +++ b/c/src/lib/libbsp/powerpc/t32mppc/irq/irq.c
>> @@ -14,14 +14,14 @@
>>  #include <bsp/irq-generic.h>
>> diff --git a/c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c
>> b/c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c
>> index 8066a7f43b..2a94c27d1b 100644
>> --- a/c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c
>> +++ b/c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c
>> @@ -63,30 +63,26 @@ static rtems_status_code
>> bsp_irq_enable_at_CPM(rtems_vector_number irqnum)
>> -  if (BSP_IS_CPM_IRQ(irqnum)) {
>> -    bsp_irq_enable_at_CPM(irqnum);
>> -  else if (BSP_IS_SIU_IRQ(irqnum)) {
>> -    bsp_irq_enable_at_SIU(irqnum);
>> +  if (BSP_IS_CPM_IRQ(vector)) {
>> +    bsp_irq_enable_at_CPM(vector);
>> +  } else if (BSP_IS_SIU_IRQ(vector)) {
>> +    bsp_irq_enable_at_SIU(vector);
>> -    bsp_irq_disable_at_CPM(irqnum);
>> -    bsp_irq_disable_at_SIU(irqnum);
>> +    bsp_irq_disable_at_CPM(vector);
>> +    bsp_irq_disable_at_SIU(vector);
>> diff --git a/c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c
>> b/c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c
>> index a9fe7066bc..55194cb1e6 100644
>> --- a/c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c
>> +++ b/c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c
>> @@ -132,34 +132,22 @@ static void opb_intc_init(void)
>>      (OPB_INTC_MER_HIE | OPB_INTC_MER_ME);
>> -    if (BSP_IS_OPBINTC_IRQ(vector)) {
>> -      BSP_irq_enable_at_opbintc(vector);
>> -  } else {
>> -  return sc;
>> +  if (BSP_IS_OPBINTC_IRQ(vector)) {
>> +    BSP_irq_enable_at_opbintc(vector);
>> -      BSP_irq_disable_at_opbintc(vector);
>> -  } else {
>> -  return sc;
>> +    BSP_irq_disable_at_opbintc(vector);
>>  static int C_dispatch_irq_handler(BSP_Exception_frame *frame, unsigned int
>>  excNum)
>> diff --git a/c/src/lib/libbsp/shared/include/irq-generic.h
>> b/c/src/lib/libbsp/shared/include/irq-generic.h
>> index 4e89d74ab3..187aea84d1 100644
>> --- a/c/src/lib/libbsp/shared/include/irq-generic.h
>> +++ b/c/src/lib/libbsp/shared/include/irq-generic.h
>> @@ -9,7 +9,7 @@
>>   * Based on concepts of Pavel Pisa, Till Straumann and Eric Valette.
>> - * Copyright (c) 2008-2014 embedded brains GmbH.
>> + * Copyright (c) 2008, 2017 embedded brains GmbH.
>>   *  embedded brains GmbH
>>   *  Dornierstr. 4
>> @@ -30,6 +30,7 @@
>>  #include <stdbool.h>
>>  #include <rtems/irq-extension.h>
>> +#include <rtems/score/assert.h>
>>  #ifdef RTEMS_SMP
>>    #include <rtems/score/atomic.h>
>> @@ -71,6 +72,8 @@ extern "C" {
>>    #define bsp_interrupt_fence(order) do { } while (0)
>>  #endif
>> +#define bsp_interrupt_assert(e) _Assert(e)
> doxygen?
> I don't quite see how using an assert fixes the problem being faced by
> the use of the pseudo-isr, since this vector number would trip the
> assert? Maybe I missed something.
Maybe you missed the change in c/src/lib/libbsp/shared/src/irq-server.c? Sebastian has moved the check for a valid interrupt vector into the interrupt server. So the bsp functions are no longer called with an invalid interrupt vector. I think the assert is based on Chris Johns suggestion from the other thread: "I would suggest the enable/disable calls return 'void' to indicate they can never fail and an invalid vector should be a fatal error with debugging on."
>>  struct bsp_interrupt_handler_entry {
>>    rtems_interrupt_handler handler;
>>    void *arg;
>> @@ -215,32 +218,33 @@ rtems_status_code bsp_interrupt_facility_initialize(void);
>>   * This function shall enable the vector at the corresponding facility (in most
>>   * cases the interrupt controller).  It will be called then the first handler
> s/then/when
>> - * is installed for the vector in bsp_interrupt_handler_install().  It is
>> - * guaranteed that the vector number is within the BSP_INTERRUPT_VECTOR_MIN and
>> - * BSP_INTERRUPT_VECTOR_MAX range.
>> + * is installed for the vector in bsp_interrupt_handler_install() for example.
>> + * @note The implementation should use
>> + * bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector)) to valdiate the
> typo: validate
>> + * vector number.
>>   * @note You must not install or remove an interrupt handler in this function.
>>   * This may result in a deadlock.
>> - * @return On success RTEMS_SUCCESSFUL shall be returned.
>> -rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector);
>> +void bsp_interrupt_vector_enable(rtems_vector_number vector);
>>   * @brief Disables the interrupt vector with number @a vector.
>>   * This function shall disable the vector at the corresponding facility (in
>>   * most cases the interrupt controller).  It will be called then the last
>> - * handler is removed for the vector in bsp_interrupt_handler_remove().  It is
>> + * handler is removed for the vector in bsp_interrupt_handler_remove() for
>> + * example.
> ditto
>> + * vector number.
>> -rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector);
>> +void bsp_interrupt_vector_disable(rtems_vector_number vector);
>>   * @brief Sequencially calls all interrupt handlers for the vector number @a
>> diff --git a/c/src/lib/libbsp/shared/src/irq-generic.c
>> b/c/src/lib/libbsp/shared/src/irq-generic.c
>> index b2a7ced64c..7f943d96cb 100755
>> --- a/c/src/lib/libbsp/shared/src/irq-generic.c
>> +++ b/c/src/lib/libbsp/shared/src/irq-generic.c
>> @@ -207,7 +207,6 @@ static rtems_status_code bsp_interrupt_handler_install(
>>    void *arg
>>    rtems_vector_number index = 0;
>>    bsp_interrupt_handler_entry *head = NULL;
>> @@ -346,11 +345,7 @@ static rtems_status_code bsp_interrupt_handler_install(
>>    /* Enable the vector if necessary */
>>    if (enable_vector) {
>> -    sc = bsp_interrupt_vector_enable(vector);
>> -    if (sc != RTEMS_SUCCESSFUL) {
>> -      bsp_interrupt_unlock();
>> -      return sc;
>> +    bsp_interrupt_vector_enable(vector);
>>    /* Unlock */
>> @@ -375,7 +370,6 @@ static rtems_status_code bsp_interrupt_handler_remove(
>>    void *arg
>> @@ -446,7 +440,7 @@ static rtems_status_code bsp_interrupt_handler_remove(
>>        /* Disable the vector */
>> -      sc = bsp_interrupt_vector_disable(vector);
>> +      bsp_interrupt_vector_disable(vector);
>>        /* Clear entry */
>>        bsp_interrupt_disable(level);
>> @@ -458,12 +452,6 @@ static rtems_status_code bsp_interrupt_handler_remove(
>>        /* Allow shared handlers */
>>        bsp_interrupt_set_handler_unique(index, false);
>> -      /* Check status code */
>> -        return sc;
>>      } else {
>>         * The match is the list tail and has a predecessor.
>> diff --git a/c/src/lib/libbsp/shared/src/irq-server.c
>> b/c/src/lib/libbsp/shared/src/irq-server.c
>> index 905c26198b..9a3ca9abf1 100644
>> --- a/c/src/lib/libbsp/shared/src/irq-server.c
>> +++ b/c/src/lib/libbsp/shared/src/irq-server.c
>> @@ -56,7 +56,9 @@ static void bsp_interrupt_server_trigger(void *arg)
>>    rtems_interrupt_server_entry *e = arg;
>> -  bsp_interrupt_vector_disable(e->vector);
>> +  if (bsp_interrupt_is_valid_vector(e->vector)) {
>> +    bsp_interrupt_vector_disable(e->vector);
>>    rtems_interrupt_lock_acquire(&bsp_interrupt_server_lock, &lock_context);
>> @@ -324,7 +326,9 @@ static void bsp_interrupt_server_task(rtems_task_argument
>> arg)
>>          (*current->handler)(current->arg);
>>        } while (action != NULL);
>> -      bsp_interrupt_vector_enable(vector);
>> diff --git a/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
>> b/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
>> index f219e49f45..344ed71a34 100644
>> --- a/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
>> +++ b/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
>> @@ -70,20 +70,18 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
>>    int irq = (int)vector;
>>    BSP_Cpu_Unmask_interrupt(irq, bsp_irq_cpu(irq));
>>    BSP_Cpu_Mask_interrupt(irq, bsp_irq_cpu(irq));
>>  void BSP_shared_interrupt_mask(int irq)
>> diff --git a/c/src/lib/libcpu/arm/at91rm9200/irq/irq.c
>> b/c/src/lib/libcpu/arm/at91rm9200/irq/irq.c
>> index 9ecdacfbb7..95e93845b9 100644
>> --- a/c/src/lib/libcpu/arm/at91rm9200/irq/irq.c
>> +++ b/c/src/lib/libcpu/arm/at91rm9200/irq/irq.c
>> @@ -27,18 +27,16 @@ void bsp_interrupt_dispatch(void)
>>    AIC_CTL_REG(AIC_EOICR) = 0;
>>    AIC_CTL_REG(AIC_IECR) = 1 << vector;
>>    AIC_CTL_REG(AIC_IDCR) = 1 << vector;
>> diff --git a/c/src/lib/libcpu/arm/lpc22xx/irq/irq.c
>> b/c/src/lib/libcpu/arm/lpc22xx/irq/irq.c
>> index 851705bee2..83e140bd7b 100644
>> --- a/c/src/lib/libcpu/arm/lpc22xx/irq/irq.c
>> +++ b/c/src/lib/libcpu/arm/lpc22xx/irq/irq.c
>> @@ -26,18 +26,16 @@ void bsp_interrupt_dispatch(void)
>>    VICVectAddr = 0;
>>    VICIntEnable |= 1 << vector;
>>    VICIntEnClr = 1 << vector;
>> diff --git a/c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c
>> b/c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c
>> index 2d6e34d274..e5887b9717 100644
>> --- a/c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c
>> +++ b/c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c
>> @@ -26,24 +26,20 @@ void bsp_interrupt_dispatch(void)
>> -  if (vector >= MC9328MXL_NUM_INTS)
>> -  MC9328MXL_AITC_INTENNUM = vector;
>> +  if (vector < MC9328MXL_NUM_INTS)
>> +    MC9328MXL_AITC_INTENNUM = vector;
>> -  MC9328MXL_AITC_INTDISNUM = vector;
>> +    MC9328MXL_AITC_INTDISNUM = vector;
>> diff --git a/c/src/lib/libcpu/arm/pxa255/irq/irq.c
>> b/c/src/lib/libcpu/arm/pxa255/irq/irq.c
>> index 8b46ce149c..425795b165 100644
>> --- a/c/src/lib/libcpu/arm/pxa255/irq/irq.c
>> +++ b/c/src/lib/libcpu/arm/pxa255/irq/irq.c
>> @@ -24,18 +24,16 @@ void bsp_interrupt_dispatch(void)
>>    XSCALE_INT_ICMR |= 1 << vector;
>>    XSCALE_INT_ICMR  &= ~(1 << vector);
>> diff --git a/c/src/lib/libcpu/arm/s3c24xx/irq/irq.c
>> b/c/src/lib/libcpu/arm/s3c24xx/irq/irq.c
>> index dce6c383b9..ea8f610353 100644
>> --- a/c/src/lib/libcpu/arm/s3c24xx/irq/irq.c
>> +++ b/c/src/lib/libcpu/arm/s3c24xx/irq/irq.c
>> @@ -27,14 +27,14 @@ void bsp_interrupt_dispatch(void)
>> diff --git a/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c
>> b/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c
>> index 59b2c39c59..789a19a490 100644
>> --- a/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c
>> +++ b/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c
>> @@ -180,20 +180,14 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
>> -rtems_status_code bsp_interrupt_vector_enable( rtems_vector_number vector)
>> -       if (MPC55XX_IRQ_IS_VALID( vector)) {
>> -               return mpc55xx_intc_set_priority( vector,
>> MPC55XX_INTC_DEFAULT_PRIORITY);
>> -       } else {
>> +       mpc55xx_intc_set_priority( vector, MPC55XX_INTC_DEFAULT_PRIORITY);
>> -rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number vector)
>> MPC55XX_INTC_DISABLED_PRIORITY);
>> -       } else {
>> +       mpc55xx_intc_set_priority( vector, MPC55XX_INTC_DISABLED_PRIORITY);
>> 2.12.3
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
