[PATCH] bsps: Improve interrupt vector enable/disable API
Tue Jun 20 00:51:15 UTC 2017
On 19/06/2017 23:19, Sebastian Huber wrote:
> Change bsp_interrupt_vector_enable() and bsp_interrupt_vector_disable()
> to not return a status code.  Add bsp_interrupt_assert() and use it to
> validate the vector number in the vector enable/disable implementations.
Thank you for the quick turn around on the change. It is impressive.
OK to push with Gedare's minor changes. I will build everything once pushed.
