[PATCH] bsps: Improve interrupt vector enable/disable API
Tue Jun 20 05:44:20 UTC 2017
On 20/06/17 02:51, Chris Johns wrote:
> On 19/06/2017 23:19, Sebastian Huber wrote:
>> Change bsp_interrupt_vector_enable() and bsp_interrupt_vector_disable()
>> to not return a status code.  Add bsp_interrupt_assert() and use it to
>> validate the vector number in the vector enable/disable implementations.
> Thank you for the quick turn around on the change. It is impressive.
> OK to push with Gedare's minor changes. I will build everything once pushed.
m68k no longer builds with this change due to:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=81132
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
