[PATCH] bsps: Improve interrupt vector enable/disable API
Tue Jun 20 12:39:08 UTC 2017
On 20/06/17 07:44, Sebastian Huber wrote:
> On 20/06/17 02:51, Chris Johns wrote:
>> On 19/06/2017 23:19, Sebastian Huber wrote:
>>> Change bsp_interrupt_vector_enable() and bsp_interrupt_vector_disable()
>>> to not return a status code.  Add bsp_interrupt_assert() and use it to
>>> validate the vector number in the vector enable/disable
>>> implementations.
>> Thank you for the quick turn around on the change. It is impressive.
>> OK to push with Gedare's minor changes. I will build everything once
>> pushed.
> m68k no longer builds with this change due to:
> https://gcc.gnu.org/bugzilla/show_bug.cgi?id=81132
https://git.rtems.org/rtems-source-builder/commit/?id=34a310344cd357afbb236c55b748392ce3f1cbdb
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
