RTEMS-libbsd copyright question
punit vara punitvara at gmail.com
Wed Jun 21 07:05:45 UTC 2017
Hi Sichen
On Wed, Jun 21, 2017 at 11:05 AM, Sebastian Huber
> On 19/06/17 15:45, Sichen Zhao wrote:
>> Ok, so i think most of my ported file shouldn't add copyright.
>> But some file in the rtemsbsd folder , i think i modified some new
>> code.  The link is below:
>> https://github.com/hahchenchen/rtems-libbsd/blob/usb2.0/rtemsbsd/include/bsp/nexus-devices.h#L49
>> https://github.com/hahchenchen/rtems-libbsd/blob/usb2.0/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h#L260
> It would be easier to look at patches, so that you can see what is actually
> changed.
> In general, changes in the "freebsd" subdirectory should be as small and
> mechanical as possible. There should be simply nothing to do that deserves a
> copyright.
Don't add copy right as of now. You can always show off your commits
if someone ask you to show your work. Any way once it is merged with
rtems , it will be represented as green dot ;)
