[PATCH 04/10] malloctest/init.c: Disable check maximum size warning to allow error test case
Wed Jun 21 17:52:11 UTC 2017
 testsuites/libtests/malloctest/init.c | 3 +++
 1 file changed, 3 insertions(+)
diff --git a/testsuites/libtests/malloctest/init.c b/testsuites/libtests/malloctest/init.c
index fb22e4d..6be6c1c 100644
--- a/testsuites/libtests/malloctest/init.c
+++ b/testsuites/libtests/malloctest/init.c
@@ -1260,7 +1260,10 @@ rtems_task Init(
    * Verify case where block is too large to calloc.
+#pragma GCC diagnostic push
+#pragma GCC diagnostic ignored "-Walloc-size-larger-than=N"
   p1 = calloc( 1, SIZE_MAX );
+#pragma GCC diagnostic pop
   if (p1) {
     printf("ERROR on attempt to calloc SIZE_MAX block expected failure.");
     free( p1 );
1.8.3.1
