[PATCH 4/5] Port am335x usb driver to RTEMS.
Sat Jun 24 09:07:57 UTC 2017
----- Am 23. Jun 2017 um 16:08 schrieb Sichen Zhao zsc19940506 at outlook.com:
> Because my board is Beaglebone Black, It seems the BBB bsp currently
> doesn't support simplebus. Chrisian told me that currently only one BSP
> supports FDT, it's the quoriq.
> And i do boot via U-Boot.
>> Why can't you use the FDT support in libbsd on this board? I guess you
>> boot via U-Boot?
Ok, no problem. Then we simply have to make the BBB the second BSP that uses the FDT. Its good that it works now with the primitive table based Nexus, but the next step should be to use the FDT with unmodified FreeBSD driver sources.
