RISC-V/HiFive memory limitations
Joel Sherrill
joel at rtems.org
Sun Jun 25 00:15:14 UTC 2017
They are supposed to use the installed linkcmds.
On Jun 24, 2017 6:04 PM, "Denis Obrezkov" <denisobrezkov at gmail.com> wrote:
> 2017-06-23 21:03 GMT+02:00 Denis Obrezkov <denisobrezkov at gmail.com>:
>> 2017-06-23 20:16 GMT+02:00 Denis Obrezkov <denisobrezkov at gmail.com>:
>>> 2017-06-23 16:39 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>>>> On Jun 23, 2017 9:29 AM, "Gedare Bloom" <gedare at rtems.org> wrote:
>>>> On Thu, Jun 22, 2017 at 8:32 PM, Denis Obrezkov <
>>>> >> Ok, then I will try to adapt the default linkcmd file today.
>>>> >> Regards, Denis Obrezkov
>>>> > Hello all,
>>>> > It seems that data section wasn't copied from ROM, so I've added the
>>>> > initialization code
>>>> > and now I have a proper value. Thus, I can proceed further to new
>>>> errors.
>>>> > I haven't started to develop new linkcmd file, general for the
>>>> architecture
>>>> > + specific
>>>> > for the BSP. Should I? Hesham?
>>>> You may want to just get it working first, and then refactor the
>>>> linkcmds.
>>>> +1 just make sure it is working when you start doing this. :)
>>>> > Also, I have a question:
>>>> > there is a section called 'rwbarrier' and it is placed in data.
>>>> Should it be
>>>> > also initialized?
>>>> > (copied from rom)
>>>> Everything up to the bss probably should be copied from ROM.
>>>> Agreed. Is there a crt0 in libgloss for this architecture to check
>>>> against?
>>>> Just remember that the order and layout of sections may have implicit
>>>> ties to the code in the startup.
>>>> > And is it possible to decrease a required memory amount by
>>>> restricting a
>>>> > user to C language usage?
>>>> > (no C++ sections in linkcmd)
>>>> I don't think so. They shouldn't really be having an impact anyway
>>>> except for C++ applications.
>>>> All you end up with is a loop to iterate over the list of empty global
>>>> constructors.
>>>> > _______________________________________________
>>>> > devel mailing list
>>>> > devel at rtems.org
>>>> > http://lists.rtems.org/mailman/listinfo/devel
>>>> I have a little question: is there any connection between RTEMS linker
> files
> and example-v2 applications' linker files?
> I think I have a similar mistake there: .data section is not initialized.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170624/7b5406a7/attachment.html>
