[PATCH 4/5] Port am335x usb driver to RTEMS.
Sichen Zhao zsc19940506 at outlook.com
Mon Jun 26 06:15:39 UTC 2017
Yes, i will discuss it with my mentor, and do my best.
Best Regards
Sichen Zhao
________________________________________
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
Sent: Saturday, June 24, 2017 17:07
To: Sichen Zhao
Cc: Sichen Zhao; devel; punitvara at gmail.com; christian mauderer
Subject: Re: [PATCH 4/5] Port am335x usb driver to RTEMS.
----- Am 23. Jun 2017 um 16:08 schrieb Sichen Zhao zsc19940506 at outlook.com:
> Because my board is Beaglebone Black, It seems the BBB bsp currently
> doesn't support simplebus. Chrisian told me that currently only one BSP
> supports FDT, it's the quoriq.
> And i do boot via U-Boot.
>> Why can't you use the FDT support in libbsd on this board? I guess you
>> boot via U-Boot?
Ok, no problem. Then we simply have to make the BBB the second BSP that uses the FDT. Its good that it works now with the primitive table based Nexus, but the next step should be to use the FDT with unmodified FreeBSD driver sources.
