[PATCH v4 1/2] posix/mmap: Add support for file handler and MAP_ANON
Kevin Kirspel
kevin-kirspel at idexx.com
Wed Jun 28 15:57:07 UTC 2017
Added a mmap file handler to struct _rtems_filesystem_file_handlers_r.
Updated each file handler object to support the default mmap handler.
Updated mmap() to call the mmap handler for MAP_SHARED.
Added a mmap file handler for shm
Added support for MAP_ANON in mmap().
Updates #2859
cpukit/dev/i2c/i2c-bus.c | 1 +
cpukit/dev/i2c/i2c-dev.c | 1 +
cpukit/dev/spi/spi-bus.c | 1 +
cpukit/libblock/src/blkdev-imfs.c | 1 +
cpukit/libcsupport/include/rtems/libio.h | 38 ++++
cpukit/libcsupport/include/rtems/termiostypes.h | 13 ++
cpukit/libcsupport/src/__usrenv.c | 1 +
cpukit/libcsupport/src/termios.c | 1 +
cpukit/libfs/Makefile.am | 1 +
cpukit/libfs/src/defaults/default_handlers.c | 1 +
cpukit/libfs/src/defaults/default_mmap.c | 40 ++++
cpukit/libfs/src/devfs/devfs_init.c | 1 +
cpukit/libfs/src/dosfs/msdos_handlers_dir.c | 1 +
cpukit/libfs/src/dosfs/msdos_handlers_file.c | 1 +
cpukit/libfs/src/imfs/imfs_dir_default.c | 1 +
cpukit/libfs/src/imfs/imfs_dir_minimal.c | 1 +
cpukit/libfs/src/imfs/imfs_fifo.c | 1 +
cpukit/libfs/src/imfs/imfs_handlers_device.c | 1 +
cpukit/libfs/src/imfs/imfs_linfile.c | 1 +
cpukit/libfs/src/imfs/imfs_link.c | 1 +
cpukit/libfs/src/imfs/imfs_memfile.c | 1 +
cpukit/libfs/src/imfs/imfs_symlink.c | 1 +
cpukit/libfs/src/jffs2/src/fs-rtems.c | 3 +
cpukit/libfs/src/nfsclient/src/nfs.c | 3 +
cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c | 1 +
cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c | 1 +
cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c | 1 +
cpukit/libfs/src/rfs/rtems-rfs-rtems.c | 1 +
cpukit/libnetworking/lib/ftpfs.c | 2 +
cpukit/libnetworking/lib/tftpDriver.c | 1 +
cpukit/libnetworking/rtems/rtems_syscall.c | 1 +
cpukit/posix/src/mmap.c | 257 ++++++++++++++----------
cpukit/posix/src/munmap.c | 14 +-
cpukit/posix/src/shmopen.c | 30 +++
34 files changed, 312 insertions(+), 113 deletions(-)
create mode 100644 cpukit/libfs/src/defaults/default_mmap.c
diff --git a/cpukit/dev/i2c/i2c-bus.c b/cpukit/dev/i2c/i2c-bus.c
index 0f27d06..1297b1e 100644
--- a/cpukit/dev/i2c/i2c-bus.c
+++ b/cpukit/dev/i2c/i2c-bus.c
@@ -218,6 +218,7 @@ static const rtems_filesystem_file_handlers_r i2c_bus_handler = {
.fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
.fcntl_h = rtems_filesystem_default_fcntl,
.kqfilter_h = rtems_filesystem_default_kqfilter,
+ .mmap_h = rtems_filesystem_default_mmap,
.poll_h = rtems_filesystem_default_poll,
.readv_h = rtems_filesystem_default_readv,
.writev_h = rtems_filesystem_default_writev
diff --git a/cpukit/dev/i2c/i2c-dev.c b/cpukit/dev/i2c/i2c-dev.c
index b00a9bd..680732f 100644
--- a/cpukit/dev/i2c/i2c-dev.c
+++ b/cpukit/dev/i2c/i2c-dev.c
@@ -115,6 +115,7 @@ static const rtems_filesystem_file_handlers_r i2c_dev_handler = {
diff --git a/cpukit/dev/spi/spi-bus.c b/cpukit/dev/spi/spi-bus.c
index dd84b02..343e203 100644
--- a/cpukit/dev/spi/spi-bus.c
+++ b/cpukit/dev/spi/spi-bus.c
@@ -235,6 +235,7 @@ static const rtems_filesystem_file_handlers_r spi_bus_handler = {
diff --git a/cpukit/libblock/src/blkdev-imfs.c b/cpukit/libblock/src/blkdev-imfs.c
index 7a2d00b..f2008aa 100644
--- a/cpukit/libblock/src/blkdev-imfs.c
+++ b/cpukit/libblock/src/blkdev-imfs.c
@@ -222,6 +222,7 @@ static const rtems_filesystem_file_handlers_r rtems_blkdev_imfs_node = {
.fdatasync_h = rtems_blkdev_imfs_fsync_or_fdatasync,
diff --git a/cpukit/libcsupport/include/rtems/libio.h b/cpukit/libcsupport/include/rtems/libio.h
index 4669cb5..8226d18 100644
--- a/cpukit/libcsupport/include/rtems/libio.h
+++ b/cpukit/libcsupport/include/rtems/libio.h
@@ -977,6 +977,28 @@ typedef int (*rtems_filesystem_kqfilter_t)(
+ * @brief MMAP support.
+ * @param[in, out] iop The IO pointer.
+ * @param[in, out] addr The starting address of the mapped memory.
+ * @param[in] len The maximum number of bytes to map.
+ * @param[in] prot The desired memory protection.
+ * @param[in] off The offset within the file descriptor to map.
+ * @retval 0 Successful operation.
+ * @retval error An error occurred. This is usually EINVAL.
+ * @see rtems_filesystem_default_mmap().
+typedef int (*rtems_filesystem_mmap_t)(
+ rtems_libio_t *iop,
+ void **addr,
+ size_t len,
+ int prot,
+ off_t off
* @brief File system node operations table.
struct _rtems_filesystem_file_handlers_r {
@@ -995,6 +1017,7 @@ struct _rtems_filesystem_file_handlers_r {
rtems_filesystem_kqfilter_t kqfilter_h;
rtems_filesystem_readv_t readv_h;
rtems_filesystem_writev_t writev_h;
+ rtems_filesystem_mmap_t mmap_h;
@@ -1216,6 +1239,21 @@ int rtems_filesystem_default_kqfilter(
struct knote *kn
+ * @brief Default MMAP handler.
+ * @retval ENOTSUP Always.
+ * @see rtems_filesystem_mmap_t.
+int rtems_filesystem_default_mmap(
+ void **addr,
+ size_t len,
+ int prot,
+ off_t off
diff --git a/cpukit/libcsupport/include/rtems/termiostypes.h b/cpukit/libcsupport/include/rtems/termiostypes.h
index e91faa7..b3cac66 100644
--- a/cpukit/libcsupport/include/rtems/termiostypes.h
+++ b/cpukit/libcsupport/include/rtems/termiostypes.h
@@ -565,6 +565,19 @@ int rtems_termios_kqfilter(
+ * @brief Termios mmap() filter filesystem node handler
+ * Real implementation is provided by libbsd.
+int rtems_termios_mmap(
+ void **addr,
+ size_t len,
+ int prot,
+ off_t off
* @brief Termios poll() filesystem node handler.
diff --git a/cpukit/libcsupport/src/__usrenv.c b/cpukit/libcsupport/src/__usrenv.c
index a05295d..611e0d7 100644
--- a/cpukit/libcsupport/src/__usrenv.c
+++ b/cpukit/libcsupport/src/__usrenv.c
@@ -56,6 +56,7 @@ const rtems_filesystem_file_handlers_r rtems_filesystem_null_handlers = {
diff --git a/cpukit/libcsupport/src/termios.c b/cpukit/libcsupport/src/termios.c
index a22ae95..7d84349 100644
--- a/cpukit/libcsupport/src/termios.c
+++ b/cpukit/libcsupport/src/termios.c
@@ -2212,6 +2212,7 @@ static const rtems_filesystem_file_handlers_r rtems_termios_imfs_handler = {
.kqfilter_h = rtems_termios_kqfilter,
+ .mmap_h = rtems_termios_mmap,
.poll_h = rtems_termios_poll,
diff --git a/cpukit/libfs/Makefile.am b/cpukit/libfs/Makefile.am
index 2a09aaa..0985b2f 100644
--- a/cpukit/libfs/Makefile.am
+++ b/cpukit/libfs/Makefile.am
@@ -33,6 +33,7 @@ libdefaultfs_a_SOURCES = \
src/defaults/default_ftruncate_directory.c \
src/defaults/default_handlers.c src/defaults/default_ops.c
libdefaultfs_a_SOURCES += src/defaults/default_kqfilter.c
+libdefaultfs_a_SOURCES += src/defaults/default_mmap.c
libdefaultfs_a_SOURCES += src/defaults/default_poll.c
libdefaultfs_a_SOURCES += src/defaults/default_readv.c
libdefaultfs_a_SOURCES += src/defaults/default_writev.c
diff --git a/cpukit/libfs/src/defaults/default_handlers.c b/cpukit/libfs/src/defaults/default_handlers.c
index 903cddc..3730f6c 100644
--- a/cpukit/libfs/src/defaults/default_handlers.c
+++ b/cpukit/libfs/src/defaults/default_handlers.c
@@ -34,6 +34,7 @@ const rtems_filesystem_file_handlers_r rtems_filesystem_handlers_default = {
diff --git a/cpukit/libfs/src/defaults/default_mmap.c b/cpukit/libfs/src/defaults/default_mmap.c
new file mode 100644
index 0000000..08534ee
--- /dev/null
+++ b/cpukit/libfs/src/defaults/default_mmap.c
@@ -0,0 +1,40 @@
+ * @file
+ * @brief Default MMAP Handler
+ * @ingroup LibIOFSHandler
+ * Copyright (c) 2017 Kevin Kirspel (kirspkt at gmail.com)
+#if HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <rtems/libio_.h>
+ void **addr,
+ size_t len,
+ int prot,
+ off_t off
+ rtems_set_errno_and_return_minus_one( ENOTSUP );
+ void **addr,
+ size_t len,
+ int prot,
+ off_t off
+) RTEMS_WEAK_ALIAS( rtems_filesystem_default_mmap );
diff --git a/cpukit/libfs/src/devfs/devfs_init.c b/cpukit/libfs/src/devfs/devfs_init.c
index cb5099c..1e960d2 100644
--- a/cpukit/libfs/src/devfs/devfs_init.c
+++ b/cpukit/libfs/src/devfs/devfs_init.c
@@ -52,6 +52,7 @@ const rtems_filesystem_file_handlers_r devFS_file_handlers = {
diff --git a/cpukit/libfs/src/dosfs/msdos_handlers_dir.c b/cpukit/libfs/src/dosfs/msdos_handlers_dir.c
index 1365ca1..bc2d896 100644
--- a/cpukit/libfs/src/dosfs/msdos_handlers_dir.c
+++ b/cpukit/libfs/src/dosfs/msdos_handlers_dir.c
@@ -34,6 +34,7 @@ const rtems_filesystem_file_handlers_r msdos_dir_handlers = {
.fdatasync_h = msdos_sync,
diff --git a/cpukit/libfs/src/dosfs/msdos_handlers_file.c b/cpukit/libfs/src/dosfs/msdos_handlers_file.c
index 0bea6e1..ed72fb6 100644
--- a/cpukit/libfs/src/dosfs/msdos_handlers_file.c
+++ b/cpukit/libfs/src/dosfs/msdos_handlers_file.c
@@ -34,6 +34,7 @@ const rtems_filesystem_file_handlers_r msdos_file_handlers = {
diff --git a/cpukit/libfs/src/imfs/imfs_dir_default.c b/cpukit/libfs/src/imfs/imfs_dir_default.c
index b31a50e..a1fc243 100644
--- a/cpukit/libfs/src/imfs/imfs_dir_default.c
+++ b/cpukit/libfs/src/imfs/imfs_dir_default.c
@@ -130,6 +130,7 @@ static const rtems_filesystem_file_handlers_r IMFS_dir_default_handlers = {
.fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync_success,
diff --git a/cpukit/libfs/src/imfs/imfs_dir_minimal.c b/cpukit/libfs/src/imfs/imfs_dir_minimal.c
index 3ef5173..e97468d 100644
--- a/cpukit/libfs/src/imfs/imfs_dir_minimal.c
+++ b/cpukit/libfs/src/imfs/imfs_dir_minimal.c
@@ -32,6 +32,7 @@ static const rtems_filesystem_file_handlers_r IMFS_dir_minimal_handlers = {
diff --git a/cpukit/libfs/src/imfs/imfs_fifo.c b/cpukit/libfs/src/imfs/imfs_fifo.c
index d6c2187..b97694e 100644
--- a/cpukit/libfs/src/imfs/imfs_fifo.c
+++ b/cpukit/libfs/src/imfs/imfs_fifo.c
@@ -127,6 +127,7 @@ static const rtems_filesystem_file_handlers_r IMFS_fifo_handlers = {
diff --git a/cpukit/libfs/src/imfs/imfs_handlers_device.c b/cpukit/libfs/src/imfs/imfs_handlers_device.c
index 0a7cb5f..df9f6fc 100644
--- a/cpukit/libfs/src/imfs/imfs_handlers_device.c
+++ b/cpukit/libfs/src/imfs/imfs_handlers_device.c
@@ -45,6 +45,7 @@ static const rtems_filesystem_file_handlers_r IMFS_device_handlers = {
diff --git a/cpukit/libfs/src/imfs/imfs_linfile.c b/cpukit/libfs/src/imfs/imfs_linfile.c
index 5840c16..57e106d 100644
--- a/cpukit/libfs/src/imfs/imfs_linfile.c
+++ b/cpukit/libfs/src/imfs/imfs_linfile.c
@@ -87,6 +87,7 @@ static const rtems_filesystem_file_handlers_r IMFS_linfile_handlers = {
diff --git a/cpukit/libfs/src/imfs/imfs_link.c b/cpukit/libfs/src/imfs/imfs_link.c
index 06794af..add93e4 100644
--- a/cpukit/libfs/src/imfs/imfs_link.c
+++ b/cpukit/libfs/src/imfs/imfs_link.c
@@ -93,6 +93,7 @@ static const rtems_filesystem_file_handlers_r IMFS_link_handlers = {
diff --git a/cpukit/libfs/src/imfs/imfs_memfile.c b/cpukit/libfs/src/imfs/imfs_memfile.c
index 2b6a496..2227bba 100644
--- a/cpukit/libfs/src/imfs/imfs_memfile.c
+++ b/cpukit/libfs/src/imfs/imfs_memfile.c
@@ -844,6 +844,7 @@ static const rtems_filesystem_file_handlers_r IMFS_memfile_handlers = {
diff --git a/cpukit/libfs/src/imfs/imfs_symlink.c b/cpukit/libfs/src/imfs/imfs_symlink.c
index 0f06446..4358ad6 100644
--- a/cpukit/libfs/src/imfs/imfs_symlink.c
+++ b/cpukit/libfs/src/imfs/imfs_symlink.c
@@ -95,6 +95,7 @@ static const rtems_filesystem_file_handlers_r IMFS_link_handlers = {
diff --git a/cpukit/libfs/src/jffs2/src/fs-rtems.c b/cpukit/libfs/src/jffs2/src/fs-rtems.c
index 8084776..5e702ce 100644
--- a/cpukit/libfs/src/jffs2/src/fs-rtems.c
+++ b/cpukit/libfs/src/jffs2/src/fs-rtems.c
@@ -606,6 +606,7 @@ static const rtems_filesystem_file_handlers_r rtems_jffs2_directory_handlers = {
@@ -748,6 +749,7 @@ static const rtems_filesystem_file_handlers_r rtems_jffs2_file_handlers = {
@@ -766,6 +768,7 @@ static const rtems_filesystem_file_handlers_r rtems_jffs2_link_handlers = {
diff --git a/cpukit/libfs/src/nfsclient/src/nfs.c b/cpukit/libfs/src/nfsclient/src/nfs.c
index 5673a24..87fef54 100644
--- a/cpukit/libfs/src/nfsclient/src/nfs.c
+++ b/cpukit/libfs/src/nfsclient/src/nfs.c
@@ -2884,6 +2884,7 @@ struct _rtems_filesystem_file_handlers_r nfs_file_file_handlers = {
@@ -2904,6 +2905,7 @@ struct _rtems_filesystem_file_handlers_r nfs_dir_file_handlers = {
@@ -2924,6 +2926,7 @@ struct _rtems_filesystem_file_handlers_r nfs_link_file_handlers = {
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
index a8ba126..3c69eaa 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
@@ -195,6 +195,7 @@ const rtems_filesystem_file_handlers_r rtems_rfs_rtems_device_handlers = {
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
index df0e639..ab4e56f 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
@@ -164,6 +164,7 @@ const rtems_filesystem_file_handlers_r rtems_rfs_rtems_dir_handlers = {
.fdatasync_h = rtems_rfs_rtems_fdatasync,
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
index 31df78a..99782db 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
@@ -348,6 +348,7 @@ const rtems_filesystem_file_handlers_r rtems_rfs_rtems_file_handlers = {
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
index 5ce526a..45455eb 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
@@ -701,6 +701,7 @@ const rtems_filesystem_file_handlers_r rtems_rfs_rtems_link_handlers =
diff --git a/cpukit/libnetworking/lib/ftpfs.c b/cpukit/libnetworking/lib/ftpfs.c
index e016cae..912ec82 100644
--- a/cpukit/libnetworking/lib/ftpfs.c
+++ b/cpukit/libnetworking/lib/ftpfs.c
@@ -1404,6 +1404,7 @@ static const rtems_filesystem_file_handlers_r rtems_ftpfs_handlers = {
@@ -1422,6 +1423,7 @@ static const rtems_filesystem_file_handlers_r rtems_ftpfs_root_handlers = {
diff --git a/cpukit/libnetworking/lib/tftpDriver.c b/cpukit/libnetworking/lib/tftpDriver.c
index 52236be..1a5823b 100644
--- a/cpukit/libnetworking/lib/tftpDriver.c
+++ b/cpukit/libnetworking/lib/tftpDriver.c
@@ -1053,6 +1053,7 @@ static const rtems_filesystem_file_handlers_r rtems_tftp_handlers = {
diff --git a/cpukit/libnetworking/rtems/rtems_syscall.c b/cpukit/libnetworking/rtems/rtems_syscall.c
index 6bef21a..29b2b4c 100644
--- a/cpukit/libnetworking/rtems/rtems_syscall.c
+++ b/cpukit/libnetworking/rtems/rtems_syscall.c
@@ -822,6 +822,7 @@ static const rtems_filesystem_file_handlers_r socket_handlers = {
.fcntl_h = rtems_bsdnet_fcntl,
diff --git a/cpukit/posix/src/mmap.c b/cpukit/posix/src/mmap.c
index 5b6ac2e..d9b663d 100644
--- a/cpukit/posix/src/mmap.c
+++ b/cpukit/posix/src/mmap.c
@@ -5,6 +5,7 @@
* Copyright (c) 2012 Chris Johns (chrisj at rtems.org)
* Copyright (c) 2017 Gedare Bloom (gedare at rtems.org)
+ * Copyright (c) 2017 Kevin kirspel (kirspkt at gmail.com)
@@ -107,30 +108,6 @@ bool mmap_mappings_lock_release(
return true;
-/* Helper function only gets called for mmap mappings of shared memory objects
- * with the MAP_SHARED flag.
-static void *shm_mmap( rtems_libio_t *iop, size_t len, int prot, off_t off)
- POSIX_Shm_Control *shm = iop_to_shm( iop );
- void *m;
- _Objects_Allocator_lock();
- m = (*shm->shm_object.ops->object_mmap)( &shm->shm_object, len, prot, off);
- if ( m != NULL ) {
- /* Keep a reference in the shared memory to prevent its removal. */
- ++shm->reference_count;
- /* Update atime */
- _POSIX_Shm_Update_atime(shm);
- _Objects_Allocator_unlock();
- return m;
void *mmap(
void *addr, size_t len, int prot, int flags, int fildes, off_t off
@@ -140,37 +117,25 @@ void *mmap(
ssize_t r;
rtems_libio_t *iop;
bool map_fixed;
+ bool map_anonymous;
+ bool map_shared;
+ bool map_private;
+ int err;
map_fixed = (flags & MAP_FIXED) == MAP_FIXED;
+ map_anonymous = (flags & MAP_ANON) == MAP_ANON;
+ map_shared = (flags & MAP_SHARED) == MAP_SHARED;
+ map_private = (flags & MAP_PRIVATE) == MAP_PRIVATE;
/* Clear errno. */
errno = 0;
- * Get a stat of the file to get the dev + inode number and to make sure the
- * fd is ok. The normal libio calls cannot be used because we need to return
- * MAP_FAILED on error and they return -1 directly without coming back to
- * here.
- if ( fstat( fildes, &sb ) < 0 ) {
- errno = EBADF;
- return MAP_FAILED;
- /* fstat ensures we have a good file descriptor. Hold on to iop. */
- iop = rtems_libio_iop( fildes );
+ iop = NULL;
if ( len == 0 ) {
errno = EINVAL;
return MAP_FAILED;
- /* Check the type of file we have and make sure it is supported. */
- if ( S_ISDIR( sb.st_mode ) || S_ISLNK( sb.st_mode )) {
- errno = ENODEV;
* We can provide read, write and execute because the memory in RTEMS does
* not normally have protections but we cannot hide access to memory.
@@ -180,17 +145,6 @@ void *mmap(
return MAP_FAILED;
- /* Either MAP_SHARED or MAP_PRIVATE must be defined, but not both */
- if ( (flags & MAP_SHARED) == MAP_SHARED ) {
- if ( (flags & MAP_PRIVATE) == MAP_PRIVATE ) {
- errno = EINVAL;
- } else if ( (flags & MAP_PRIVATE) != MAP_PRIVATE ) {
- errno = EINVAL;
* We can not normally provide restriction of write access. Reject any
* attempt to map without write permission, since we are not able to
@@ -201,27 +155,104 @@ void *mmap(
return MAP_FAILED;
- /* Check to see if the mapping is valid for a regular file. */
- if ( S_ISREG( sb.st_mode )
- /* FIXME: Should this be using strict inequality (>) comparisons? It would
- * be valid to map a region exactly equal to the st_size, e.g. see below. */
- && (( off >= sb.st_size ) || (( off + len ) >= sb.st_size ))) {
- errno = EOVERFLOW;
+ * Anonymous mappings must have file descriptor set to -1 and the offset
+ * set to 0. Shared mappings are not supported with Anonymous mappings at
+ * this time
+ if ( map_anonymous && (fildes != -1 || off != 0 || map_shared) ) {
+ errno = EINVAL;
return MAP_FAILED;
- * Check to see if the mapping is valid for other file/object types.
- * Does this satisfy for devices?
+ * If MAP_ANON is declared without MAP_PRIVATE or MAP_SHARED,
+ * force MAP_PRIVATE
- if ( sb.st_size < off + len ) {
- errno = ENXIO;
+ if ( map_anonymous && !map_private && !map_shared ) {
+ flags |= MAP_PRIVATE;
+ map_private = true;
+ /* Check for supported flags */
+ if ((flags & ~(MAP_SHARED | MAP_PRIVATE | MAP_FIXED | MAP_ANON)) != 0) {
+ errno = EINVAL;
return MAP_FAILED;
- /* Do not seek on character devices, pipes, sockets, or memory objects. */
- if ( S_ISREG( sb.st_mode ) || S_ISBLK( sb.st_mode ) ) {
- if ( lseek( fildes, off, SEEK_SET ) < 0 ) {
+ /* Either MAP_SHARED or MAP_PRIVATE must be defined, but not both */
+ if ( map_shared ) {
+ if ( map_private ) {
+ errno = EINVAL;
+ return MAP_FAILED;
+ } else if ( !map_private ) {
+ errno = EINVAL;
+ /* Check for illegal addresses. Watch out for address wrap. */
+ if ( map_fixed ) {
+ if ((uintptr_t)addr & PAGE_MASK) {
+ errno = EINVAL;
+ if ( addr == NULL ) {
+ errno = EINVAL;
+ if (addr + len < addr) {
+ errno = EINVAL;
+ if ( !map_anonymous ) {
+ * Get a stat of the file to get the dev + inode number and to make sure the
+ * fd is ok. The normal libio calls cannot be used because we need to return
+ * MAP_FAILED on error and they return -1 directly without coming back to
+ * here.
+ if ( fstat( fildes, &sb ) < 0 ) {
+ errno = EBADF;
+ /* fstat ensures we have a good file descriptor. Hold on to iop. */
+ iop = rtems_libio_iop( fildes );
+ /* Check the type of file we have and make sure it is supported. */
+ if ( S_ISDIR( sb.st_mode ) || S_ISLNK( sb.st_mode )) {
+ errno = ENODEV;
+ /* Check to see if the mapping is valid for a regular file. */
+ if ( S_ISREG( sb.st_mode )
+ /* FIXME: Should this be using strict inequality (>) comparisons? It would
+ * be valid to map a region exactly equal to the st_size, e.g. see below. */
+ && (( off >= sb.st_size ) || (( off + len ) >= sb.st_size ))) {
+ errno = EOVERFLOW;
+ /* Check to see if the mapping is valid for other file/object types. */
+ if ( !S_ISCHR( sb.st_mode ) && sb.st_size < off + len ) {
+ errno = ENXIO;
+ /* Do not seek on character devices, pipes, sockets, or memory objects. */
+ if ( S_ISREG( sb.st_mode ) || S_ISBLK( sb.st_mode ) ) {
+ if ( lseek( fildes, off, SEEK_SET ) < 0 ) {
+ /* cdevs do not provide private mappings of any kind. */
+ if ( S_ISCHR( sb.st_mode ) && map_private ) {
+ errno = EINVAL;
return MAP_FAILED;
@@ -230,42 +261,37 @@ void *mmap(
mapping = malloc( sizeof( mmap_mapping ));
if ( !mapping ) {
errno = ENOMEM;
- return NULL;
memset( mapping, 0, sizeof( mmap_mapping ));
mapping->len = len;
mapping->flags = flags;
mapping->iop = iop;
- * HACK: We should have a better generic way to distinguish between
- * shm objects and other mmap'd files. We need to know at munmap time
- * if the mapping is to a shared memory object in order to refcnt shms.
- * We could do this by providing mmap in the file operations if needed.
- if ( S_ISREG( sb.st_mode ) || S_ISBLK( sb.st_mode ) ||
- S_ISCHR( sb.st_mode ) || S_ISFIFO( sb.st_mode ) ||
- S_ISSOCK( sb.st_mode ) ) {
- mapping->is_shared_shm = false;
+ * HACK: We should have a better generic way to distinguish between
+ * shm objects and other mmap'd files. We need to know at munmap time
+ * if the mapping is to a shared memory object in order to refcnt shms.
+ * We could do this by providing mmap in the file operations if needed.
+ if ( S_ISREG( sb.st_mode ) || S_ISBLK( sb.st_mode ) ||
+ S_ISCHR( sb.st_mode ) || S_ISFIFO( sb.st_mode ) ||
+ S_ISSOCK( sb.st_mode ) ) {
+ mapping->is_shared_shm = false;
+ } else {
+ mapping->is_shared_shm = true;
} else {
- mapping->is_shared_shm = true;
- * MAP_SHARED currently is only supported for shared memory objects.
- if ( (MAP_SHARED == (flags & MAP_SHARED)) && (mapping->is_shared_shm == false) ) {
- free( mapping );
- errno = ENOTSUP;
if ( map_fixed ) {
mapping->addr = addr;
- } else if ( MAP_PRIVATE == (flags & MAP_PRIVATE) ) {
+ } else if ( map_private ) {
/* private mappings of shared memory do not need special treatment. */
- mapping->addr = malloc( len );
+ posix_memalign( &mapping->addr, PAGE_SIZE, len );
if ( !mapping->addr ) {
free( mapping );
errno = ENOMEM;
@@ -306,32 +332,43 @@ void *mmap(
/* Populate the data */
- if ( MAP_PRIVATE == (flags & MAP_PRIVATE) ) {
- * Use read() for private mappings. This updates atime as needed.
- * Changes to the underlying object will NOT be reflected in the mapping.
- * The underlying object can be removed while the mapping exists.
- r = read( fildes, mapping->addr, len );
+ * Use read() for private mappings. This updates atime as needed.
+ * Changes to the underlying object will NOT be reflected in the mapping.
+ * The underlying object can be removed while the mapping exists.
+ r = read( fildes, mapping->addr, len );
- if ( r != len ) {
- mmap_mappings_lock_release( );
- if ( !map_fixed ) {
- free( mapping->addr );
+ if ( r != len ) {
+ mmap_mappings_lock_release( );
+ if ( !map_fixed ) {
+ free( mapping->addr );
+ free( mapping );
+ errno = ENXIO;
+ } else if ( !map_fixed ) {
+ memset( mapping->addr, 0, len );
+ } else if ( map_shared ) {
+ err = (*iop->pathinfo.handlers->mmap_h)(
+ iop, &mapping->addr, len, prot, off );
+ if ( err != 0 ) {
free( mapping );
- errno = ENXIO;
return MAP_FAILED;
- } else if ( MAP_SHARED == (flags & MAP_SHARED) ) {
- /* Currently only shm objects can be MAP_SHARED. */
- mapping->addr = shm_mmap(iop, len, prot, off);
- /* add an extra reference to the file associated with fildes that
- * is not removed by a subsequent close(). This reference shall be removed
- * when there are no more mappings to the file. */
- rtems_libio_increment_mapping_refcnt(iop);
+ if ( iop != NULL ) {
+ /* add an extra reference to the file associated with fildes that
+ * is not removed by a subsequent close(). This reference shall be removed
+ * when there are no more mappings to the file. */
+ rtems_libio_increment_mapping_refcnt(iop);
rtems_chain_append( &mmap_mappings, &mapping->node );
diff --git a/cpukit/posix/src/munmap.c b/cpukit/posix/src/munmap.c
index 323a24e..2d812ae 100644
--- a/cpukit/posix/src/munmap.c
+++ b/cpukit/posix/src/munmap.c
@@ -46,6 +46,12 @@ int munmap(void *addr, size_t len)
return -1;
+ errno = EINVAL;
+ return -1;
* Obtain the mmap lock. Sets errno on failure.
@@ -63,9 +69,11 @@ int munmap(void *addr, size_t len)
if ( mapping->is_shared_shm == true ) {
shm_munmap(mapping->iop);
- refcnt = rtems_libio_decrement_mapping_refcnt(mapping->iop);
- if ( refcnt == 0 ) {
- rtems_libio_check_deferred_free(mapping->iop);
+ if ( mapping->iop != NULL ) {
+ refcnt = rtems_libio_decrement_mapping_refcnt(mapping->iop);
+ if ( refcnt == 0 ) {
+ rtems_libio_check_deferred_free(mapping->iop);
/* only free the mapping address for non-fixed mapping */
if (( mapping->flags & MAP_FIXED ) != MAP_FIXED ) {
diff --git a/cpukit/posix/src/shmopen.c b/cpukit/posix/src/shmopen.c
index fa1027e..e729f9b 100644
--- a/cpukit/posix/src/shmopen.c
+++ b/cpukit/posix/src/shmopen.c
@@ -106,6 +106,35 @@ static int shm_close( rtems_libio_t *iop )
return 0;
+static int shm_mmap(
+ void** addr,
+ size_t len,
+ int prot,
+ off_t off
+ POSIX_Shm_Control *shm = iop_to_shm( iop );
+ _Objects_Allocator_lock();
+ *addr = (*shm->shm_object.ops->object_mmap)( &shm->shm_object, len, prot, off);
+ if ( *addr != NULL ) {
+ /* Keep a reference in the shared memory to prevent its removal. */
+ ++shm->reference_count;
+ /* Update atime */
+ _POSIX_Shm_Update_atime(shm);
+ } else {
+ _Objects_Allocator_unlock();
+ rtems_set_errno_and_return_minus_one( ENOMEM );
+ return 0;
static inline POSIX_Shm_Control *shm_allocate(
const char *name_arg,
size_t name_len,
@@ -275,6 +304,7 @@ static const rtems_filesystem_file_handlers_r shm_handlers = {
+ .mmap_h = shm_mmap,
1.9.1
