LIBBSD
Kirspel, Kevin
Kevin-Kirspel at idexx.com
Thu Jun 29 18:02:22 UTC 2017
For those who run a RTEMS 4.12 single processor application with LIBBSD, what percentage of time does your application spend in the timer server task? My NXP LPC3250 application spends about 13% of the processor time processing the timer server. Most of that time is spent processing LIBBSD's kernel callouts. I am wondering if there is an advantage to only call the FreeBSD's callout_process() function when we know a callout needs to be processed. This would reduce the number of RTEMS timer fires (which currently fire every tick).
Kevin Kirspel
Electrical Engineer - Sr. Staff
Idexx Roswell
235 Hembree Park Drive
Roswell GA 30076
Tel: (770)-510-4444 ext. 81642
Direct: (770)-688-1642
Fax: (770)-510-4445
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170629/4c7044ea/attachment.html>
