LIBBSD
Kirspel, Kevin Kevin-Kirspel at idexx.com
Fri Jun 30 11:48:39 UTC 2017
I'm not sure but I'll look into it today.  I'll need to quantify each callout handler's processing time to see which one is causing the problem.  I know the USB and Ethernet stacks/drivers use callouts but maybe there is something else.
Kevin Kirspel
Electrical Engineer - Sr. Staff
Idexx Roswell
235 Hembree Park Drive
Roswell GA 30076
Tel: (770)-510-4444 ext. 81642
Direct: (770)-688-1642
Fax: (770)-510-4445
-----Original Message-----
From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Sebastian Huber
Sent: Friday, June 30, 2017 1:15 AM
To: devel at rtems.org
Subject: Re: LIBBSD
On 29/06/17 20:02, Kirspel, Kevin wrote:
> For those who run a RTEMS 4.12 single processor application with
> LIBBSD, what percentage of time does your application spend in the
> timer server task?  My NXP LPC3250 application spends about 13% of the
> processor time processing the timer server.  Most of that time is
> spent processing LIBBSD's kernel callouts.  I am wondering if there is
> an advantage to only call the FreeBSD's callout_process() function
> when we know a callout needs to be processed.  This would reduce the
> number of RTEMS timer fires (which currently fire every tick).
Normally, the timer server should be in the range of 0.x% of CPU time.
If you have 13%, then you have a lot of timeout processing. What is the reason for this?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
devel mailing list
devel at rtems.org
https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_devel&d=DwIF-g&c=2do6VJGs3LvEOe4OFFM1bA&r=HDiJ93ANMEQ32G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=wi6q2gTnD-FidfbEqMhvlESvqYn-Fmg-tXnNg62S3BY&s=8pSzson7fylkfTRzYKIMlQnFgvwpY8lpExFHqEEapbc&e=
