Common practice of interrupt implementation in RTEMS
Fri Jun 30 18:48:54 UTC 2017
https://docs.rtems.org/branches/master/cpu-supplement/port.html#interrupt-processing
https://docs.rtems.org/branches/master/bsp-howto.html#set-vector-install-an-interrupt-vector
On Fri, Jun 30, 2017 at 10:49 AM, Denis Obrezkov
<denisobrezkov at gmail.com> wrote:
> Hello all,
> what is the common practice of interrupt implementation in RTEMS?
> I wasn't able to find much information in RTEMS BSP manual.
> My platform RISC-V has vectored interrupts and exceptions.
> A cause of an exception or of an interrupt is always available in 'mcause'
> register.
> But for interrupts an address of a handlers' table can also be dynamically
> provided.
> So, what should I do in order to implement interrupt handlers?
> What is the consequence of steps when interrupt appears (save stack, make a
> routine...)?
> Also, what is a good example of a BSP which implements ISR in a proper way?
> Regards, Denis Obrezkov
> devel mailing list
> devel at rtems.org
