Building RISC-V BSP
Hesham Almatary
heshamelmatary at gmail.com
Thu Jun 1 23:22:06 UTC 2017
On Fri, Jun 2, 2017 at 9:12 AM, Denis Obrezkov <denisobrezkov at gmail.com> wrote:
> So, am I understand right, that I should make my repo, submit commits to it,
> produce patches and send them to your repo as pool requests?
> And should I make my repo by cloning yours?
Correct. Make sure your work with priv-1.10 (as a base) branch since
this is the one that should end up upstream. Ideally, you would
fork/clone my repo, checkout priv-1.10 branch, create your own branch
based on it, and submit pull requests to my priv-1.10 branch.
Regularly, you'd want to rebase against priv-1.10 when I make changes
to it.
> 2017-06-02 2:02 GMT+03:00 Hesham Almatary <heshamelmatary at gmail.com>:
>> Hi Denis,
>> On Fri, Jun 2, 2017 at 1:27 AM, Denis Obrezkov <denisobrezkov at gmail.com>
>> wrote:
>> > Hello Hesham,
>> > should I apply your patches? or should I paste all of them to
>> > some directory (rsb has several 'patches' folders).
>> You only need to apply this patch [1] to RSB and build the tools again.
>> [1] https://lists.rtems.org/pipermail/devel/2017-May/017951.html
>> > Also, could you describe our workflow? In the context of with what
>> > repository
>> > I should work and where I should direct my pull requests.
>> Since the port is not upstream yet, you can submit PRs to my GitHub
>> repo in the time being until we get it upstreamed. After this you can
>> submit patches for review to this mailing list.
>> > 2017-06-01 5:09 GMT+03:00 Hesham Almatary <heshamelmatary at gmail.com>:
>> >> Hi Denis,
>> >> I submitted two patches for the tools, please use the latest only and
>> >> rebuild the tools. This should avoid the newlib issues you had above
>> >> as it uses main riscv patches.
>> >> I'll look into the port this weekend and submit fixes unless you beat
>> >> me to it. Meanwhile, you can submit error messages and I'll see if I
>> >> can help.
>> >> Keep the good work.
>> >> Cheers,
>> >> Hesham
>> >> On Thu, Jun 1, 2017 at 12:04 AM, Denis Obrezkov
>> >> wrote:
>> >> > 2017-05-31 16:39 GMT+03:00 Denis Obrezkov <denisobrezkov at gmail.com>:
>> >> >> Thanks, I downloaded it.
>> >> >> There was a mistake also that _JBLEN wasn't defined in
>> >> >> machine/setjmp.h
>> >> >> I don't know the exact value, so I did the following:
>> >> >> #ifdef __riscv
>> >> >> /* TBD: not the exact number */
>> >> >> #define _JBLEN 16
>> >> >> #endif
>> >> >> Now, it compiles further. But then I get the error:
>> >> >> riscv32-rtems4.12-gcc --pipe -B../../../lib/
>> >> >> -B../../../riscv_generic/lib/
>> >> >> -specs bsp_specs -qrtems -DPACKAGE_NAME=\"rtems-c-src\"
>> >> >> -DPACKAGE_TARNAME=\"rtems-c-src\" -DPACKAGE_VERSION=\"4.11.99.0\"
>> >> >> -DPACKAGE_STRING=\"rtems-c-src\ 4.11.99.0\"
>> >> >> -DPACKAGE_BUGREPORT=\"https://devel.rtems.org/newticket\"
>> >> >> -DPACKAGE_URL=\"\"
>> >> >> -I.
>> >> >> -I/home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/libchip
>> >> >> -isystem ../../../riscv_generic/lib/include -O0 -g -Wall
>> >> >> -Wmissing-prototypes -Wimplicit-function-declaration
>> >> >> -Wstrict-prototypes
>> >> >> -Wnested-externs -MT display/libdisplay_a-disp_hcms29xx.o -MD -MP
>> >> >> -MF
>> >> >> display/.deps/libdisplay_a-disp_hcms29xx.Tpo -c -o
>> >> >> display/libdisplay_a-disp_hcms29xx.o `test -f
>> >> >> 'display/disp_hcms29xx.c'
>> >> >> echo
>> >> >> '/home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/libchip/'`display/disp_hcms29xx.c
>> >> >> riscv32-rtems4.12-gcc: error: bsp_specs: No such file or directory
>> >> >> So, I inserted it manually. But I can't figure out, why it wasn't
>> >> >> copied
>> >> >> automatically.
>> >> >> Now I have an error:
>> >> >> -DPACKAGE_URL=\"\"
>> >> >> -I.
>> >> >> -Wstrict-prototypes
>> >> >> -MF
>> >> >> echo
>> >> >> /home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/libchip/display/disp_hcms29xx.c:26:10:
>> >> >> fatal error: bsp.h: No such file or directory
>> >> >> #include <bsp.h>
>> >> >> It seems that configure scripts should be modified.
>> >> >> 2017-05-31 8:46 GMT+03:00 Hesham Almatary
>> >> >>> Hi Denis,
>> >> >>> Please use priv-1.10 branch. I rebased it (against master) and
>> >> >>> added
>> >> >>> some fixes to make the build progress. Still, there's more work
>> >> >>> needed. Your contributions are welcomed.
>> >> >>> Cheers,
>> >> >>> Hesham
>> >> >> Regards, Denis Obrezkov
>> >> > I think I worked it out. In a few days I will produce patches.
>> >> > Now I am trying to compile .S files. Seems that some instructions are
>> >> > missing.
>> >> Hesham
>> Hesham
Hesham
