RISC-V interrupts
Denis Obrezkov
denisobrezkov at gmail.com
Thu Jun 8 14:49:12 UTC 2017
2017-06-08 12:24 GMT+03:00 Denis Obrezkov <denisobrezkov at gmail.com>:
> 2017-06-07 22:41 GMT+03:00 Hesham Almatary <heshamelmatary at gmail.com>:
>> On Thu, Jun 8, 2017 at 2:26 AM, Denis Obrezkov <denisobrezkov at gmail.com>
>> wrote:
>> > 2017-06-07 14:44 GMT+03:00 Sebastian Huber
>> > <sebastian.huber at embedded-brains.de>:
>> >> On 06/06/17 18:58, Hesham Almatary wrote:
>> >>> Originally RTEMS had a one big linkcmd for each platform, which
>> >>> defines linker symbols (used in C code) and required sections. This
>> >>> has been improved with current BSPs (like ARM-based ones), by
>> >>> splitting up shared linkcmd parts (linkcmd base) and BSP specific ones
>> >>> that include the shared one. riscv_generic, given that it's old,
>> >>> follows the old way of having a single big linkcmd. You can change
>> >>> this for your new BSP.
>> >> New ports/BSPs should definitely use a shared linkcmds.base (see ARM).
>> Use
>> >> "riscv-rtems4.12-ld --verbose" to get the default linker script.
>> > Ok.
>> > Now I have a problem:
>> > https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/
>> src/lib/libbsp/riscv32/hifive1/start/start.S#L117
>> > When I step to that line, gdb hangs with a message:
>> > (gdb) step
>> > Note: automatically using hardware breakpoints for read-only addresses.
>> How do you run/attach simulator (and which one do you use)? Do GDB and
>> the simulator support 0x20400000 > addresses (where your text section
>> is loaded to)? AFAIK, that's not the case. Spike's default machine
>> only works with addresses >= 0x80000000. You've to look up if Spike,
>> Qemu [1] or GDB target sim model your board.
> I use openOCD from FreeStudio kit:
https://github.com/sifive/freedom-e-sdk/blob/master/FreedomStudio/HiFive1/hello/openocd.cfg
I was able to run code in ROM region, after I made this:
MEMORY
ROM : ORIGIN = 0x20400000, LENGTH = 128M
RAM : ORIGIN = 0x80000000, LENGTH = 64K
REGION_ALIAS ("REGION_VECTOR", RAM);
REGION_ALIAS ("REGION_START", ROM);
REGION_ALIAS ("REGION_TEXT", ROM);
REGION_ALIAS ("REGION_TEXT_LOAD", ROM);
REGION_ALIAS ("REGION_RODATA", ROM);
REGION_ALIAS ("REGION_RODATA_LOAD", ROM);
REGION_ALIAS ("REGION_DATA", RAM);
REGION_ALIAS ("REGION_DATA_LOAD", ROM);
REGION_ALIAS ("REGION_FAST_DATA", RAM);
REGION_ALIAS ("REGION_FAST_DATA_LOAD", ROM);
REGION_ALIAS ("REGION_BSS", RAM);
REGION_ALIAS ("REGION_WORK", RAM);
REGION_ALIAS ("REGION_STACK", RAM);
And gdb can step till the "call boot_card" instruction,
but I can't proceed any further due to the error:
gdb hands after stepping into "call boot_card"
At the same time openocd shows:
halted at 0x20400202 due to step
halted at 0x20400262 due to hardware trigger
halted at 0x204010c2 due to step
The last line appears after attempt to make the step.
Links to my linkcmd and start.S files:
https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/src/lib/libbsp/riscv32/hifive1/startup/linkcmds
https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/src/lib/libbsp/riscv32/hifive1/start/start.S
Regards, Denis Obrezkov
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170608/cdf0d4ed/attachment-0002.html>
