[PATCH] Fix beagle i2c file bbb-i2c.c comment issues
Sichen Zhao
1473996754 at qq.com
Thu Jun 15 11:35:20 UTC 2017
c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c | 42 +++++++++++++++++--------------
1 file changed, 23 insertions(+), 19 deletions(-)
diff --git a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
index 3d7d820..26bae52 100644
--- a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
+++ b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
@@ -7,6 +7,7 @@
+ * Copyright (c) 2016 Punit Vara <punitvara at gmail.com>
* Copyright (c) 2017 Sichen Zhao <zsc19940506 at gmail.com>
* The license and distribution terms for this file may be
@@ -48,27 +49,26 @@ static void I2C0ModuleClkConfig( void )
AM335X_CM_WKUP_I2C0_CLKCTRL_MODULEMODE ) ) ;
- ** Waiting for IDLEST field in AM335X_CM_WKUP_CONTROL_CLKCTRL
- ** register to attain
- ** desired value.
+ * Waiting for IDLEST field in AM335X_CM_WKUP_CONTROL_CLKCTRL
+ * register to attain desired value.
while ( ( AM335X_CM_WKUP_CONTROL_CLKCTRL_IDLEST_FUNC <<
AM335X_CM_WKUP_CONTROL_CLKCTRL_IDLEST_SHIFT ) !=
( REG( AM335X_SOC_CM_WKUP_REGS + AM335X_CM_WKUP_CONTROL_CLKCTRL ) &
AM335X_CM_WKUP_CONTROL_CLKCTRL_IDLEST ) ) ;
- ** Waiting for CLKACTIVITY_I2C0_GFCLK field in AM335X_CM_WKUP_CLKSTCTRL
- ** register to attain desired value.
+ * Waiting for CLKACTIVITY_I2C0_GFCLK field in AM335X_CM_WKUP_CLKSTCTRL
while ( AM335X_CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK !=
( REG( AM335X_SOC_CM_WKUP_REGS + AM335X_CM_WKUP_CLKSTCTRL ) &
AM335X_CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK ) ) ;
- ** Waiting for IDLEST field in AM335X_CM_WKUP_I2C0_CLKCTRL register to attain
- ** desired value.
+ * Waiting for IDLEST field in AM335X_CM_WKUP_I2C0_CLKCTRL register to attain
+ * desired value.
while ( ( AM335X_CM_WKUP_I2C0_CLKCTRL_IDLEST_FUNC <<
AM335X_CM_WKUP_I2C0_CLKCTRL_IDLEST_SHIFT ) !=
( REG( AM335X_SOC_CM_WKUP_REGS + AM335X_CM_WKUP_I2C0_CLKCTRL ) &
@@ -100,7 +100,7 @@ static void am335x_i2c_reset( bbb_i2c_bus *bus )
- Possible values for msg->flag
+ * Possible values for msg->flag
* - @ref I2C_M_TEN,
* - @ref I2C_M_RD,
* - @ref I2C_M_STOP,
@@ -116,13 +116,15 @@ static void am335x_i2c_set_address_size(
volatile bbb_i2c_regs *regs
- /*can be configured multiple modes here.
- **Need to think about own address modes*/
+ * Can be configured multiple modes here.
+ * Need to think about own address modes
if ( ( msgs->flags & I2C_M_TEN ) == 0 ) {
- /* 7-bit mode slave address mode*/
+ /* 7-bit mode slave address mode */
REG( ®s->BBB_I2C_CON ) = AM335X_I2C_CFG_7BIT_SLAVE_ADDR;
} else {
- /* 10-bit slave address mode*/
+ /* 10-bit slave address mode */
REG( ®s->BBB_I2C_CON ) = AM335X_I2C_CFG_10BIT_SLAVE_ADDR;
@@ -282,12 +284,14 @@ static void am335x_i2c_interrupt( void *arg )
bbb_i2c_bus *bus = arg;
volatile bbb_i2c_regs *regs = bus->regs;
- /* get status of enabled interrupts */
+ /* Get status of enabled interrupts */
uint32_t irqstatus = REG( ®s->BBB_I2C_IRQSTATUS );
bool done = false;
- /* Clear all enabled interrupt except receive ready
- and transmit ready interrupt in status register */
+ * Clear all enabled interrupt except receive ready
+ * and transmit ready interrupt in status register
REG( ®s->BBB_I2C_IRQSTATUS ) =
( irqstatus & ~( AM335X_I2C_IRQSTATUS_RRDY |
AM335X_I2C_IRQSTATUS_XRDY ) );
@@ -417,7 +421,7 @@ int am335x_i2c_bus_register(
rtems_status_code sc;
int err;
- /*check bus number is >0 & <MAX*/
+ /* Check bus number is >0 & <MAX */
bus = (bbb_i2c_bus *) i2c_bus_alloc_and_init( sizeof( *bus ) );
if ( bus == NULL ) {
2.7.4
