Adding new arch/bsp to rtems tools
Joel Sherrill
joel at rtems.org
Sat Jun 17 18:13:40 UTC 2017
On Jun 17, 2017 12:55 PM, "Denis Obrezkov" <denisobrezkov at gmail.com> wrote:
I don't think that the tester subdirectory has anything to do with this
> Confirm that you can successfully 'waf configure' for the sparc/erc32.
> If not, the problem is somewhere in your command line or install
> point. Note that rtems-tools should point to the installed toolchain,
> and --rtems should point to the installed build of your BSP/rtems.
> Check that your 'make install' succeeded.
> > Regards, Denis Obrezkov
> > devel mailing list
> > devel at rtems.org
Thank you, I really forgot to "make install" after rtems building.
I wonder if this is such a common user issue that the waf error message
should offer guidance.
Similarly for the tools.
--joel
devel mailing list
devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170617/078d6a4d/attachment-0002.html>
