Valid interrupt vectors and the interrupt server
Sat Jun 17 18:16:00 UTC 2017
On Jun 17, 2017 11:17 AM, "Christian Mauderer" <
christian.mauderer at embedded-brains.de> wrote:
Hello,
I had a problem recently, that the interrupt server (for example used in
libbsd) caused some odd behaviour on an ARM Cortex BSP. That was solved by
the following patch:
https://git.rtems.org/rtems/commit/?id=ce3ac00c
Just today Sichen Zhao had a similar problem on the BBB:
https://lists.rtems.org/pipermail/devel/2017-June/018158.html
I took a look and it seems that there are a lot of BSPs which don't check
for the valid interrupt vector range in their
bsp_interrupt_vector_disable/enable
functions. Every one of them will most likely have a problems if someone
tries to use libbsd or the interrupt server.
It also seems that there is no test for the interrupt server. As far as I
know, not all targets are able to support the interrupt server depending on
the interrupt controller (I'm not exactly sure which ones have support and
which doesn't). So if a test for the server would be added, that test will
most likely fail on a lot of targets.
Has someone an idea how a test for the interrupt server could look like? We
would need an interrupt that can be used on every target.
Should we mass-change all BSPs to add the check for a valid interrupt? A
mass-change could be problematic because it is nearly impossible to test on
all targets and it's in a quite critical location.
Is there anyway a timer method could be used to fake out the interrupt
occurrence?
There is no single interrupt source or interface to get to one.
Kind regards
Christian Mauderer
embedded brains GmbH
Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170617/d2c6b319/attachment-0002.html>
