Are you happy with how the project is going?
Denis Obrezkov denisobrezkov at gmail.com
Mon Jun 19 00:07:59 UTC 2017
Hesham, could you check what is the value of rtems_minimum_stack_size in
your SPIKE executable?
2017-06-18 22:10 GMT+03:00 Denis Obrezkov <denisobrezkov at gmail.com>:
> Hello all,
> I was able to proceed further via setting rtems_minimum_stack_size
> manually to 0x200.
> Now I have another error, my backtrace:
> #0  0x20403728 in _Internal_error (core_error=INTERNAL_ERROR_
> WORKSPACE_ALLOCATION)
>     at /home/reprofy/Projects/riscv/rtems/development/rtems/
> kernel/rtems-riscv/c/src/../../cpukit/score/src/interr.c:44
> #1  0x2040ec40 in _Workspace_Allocate_or_fatal_error (size=2976696) at
> kernel/rtems-riscv/c/src/../../cpukit/score/src/wkspace.c:163
> #2  0x2040f0e6 in _Freechain_Initialize (freechain=0x80000c3c
> <_RTEMS_tasks_Information+60>, allocator=0x2040ec16
> <_Workspace_Allocate_or_fatal_error>, number_nodes=41343, node_size=72)
> kernel/rtems-riscv/c/src/../../cpukit/score/src/freechain.c:31
> #3  0x20409346 in _Thread_Initialize_information (information=0x80000c00
> <_RTEMS_tasks_Information>, the_api=OBJECTS_CLASSIC_API, the_class=1,
> maximum=3908149631, is_string=false,
>     maximum_name_length=4) at /home/reprofy/Projects/riscv/
> rtems/development/rtems/kernel/rtems-riscv/c/src/../..
> /cpukit/score/src/thread.c:68
> #4  0x20401dac in _RTEMS_tasks_Manager_initialization () at
> kernel/rtems-riscv/c/src/../../cpukit/rtems/src/tasks.c:72
> #5  0x204021bc in rtems_initialize_executive () at
> kernel/rtems-riscv/c/src/../../cpukit/sapi/src/exinit.c:95
> #6  0x2040031c in boot_card (cmdline=0x0) at /home/reprofy/Projects/riscv/
> rtems/development/rtems/kernel/rtems-riscv/c/src/lib/
> libbsp/riscv32/hifive1/../../shared/bootcard.c:76
> #7  0xffffcd98 in ?? ()
> Is RTEMS trying to allocate 2976696 bytes?
> It seems to me, that .data region is not properly initialized. What do you
> think about this?
> 2017-06-18 1:31 GMT+03:00 Denis Obrezkov <denisobrezkov at gmail.com>:
>> 2017-06-17 22:11 GMT+03:00 Denis Obrezkov <denisobrezkov at gmail.com>:
>>>>> Can you run RTEMS hello world? Or does printf make that too large? If
>>>> that is
>>>> too large, you need to force the tests to switch to printk(). There is
>>>> some magic
>>>> in testsuites/configure.ac for that.
>>>> The low ticker examples (especially the last one) will show configure
>>>> options
>>>> to cut memory use.
>>>> But these are hacks on individual tests. If there is a simulator which
>>>> has interrupts,
>>>> I would be testing on it since you will be battling the architecture
>>>> not a RAM limit.
>>>> Your project is the port not to put RTEMS into a tiny memory space. :)
>>>> --joel
>>>>> Regards, Denis Obrezkov
>>>> I was able to run the low ticker example further than in my earlier
>>> attempts.
>>> But now I have a problem with it:
>>> #0  memset (m=0xb98a0641, c=0, n=102) at ../../../../../gcc-7.1.0/newli
>>> b/libc/string/memset.c:62
>>> #1  0x20403168 in _Heap_Initialize (heap=0xb98a0641,
>>> heap_area_begin_ptr=0x80002456, heap_area_size=7082, page_size=8)
>>>     at /home/reprofy/Projects/riscv/rtems/development/rtems/kernel/
>>> rtems-riscv/c/src/../../cpukit/score/src/heap.c:230
>>> #2  0x20400954 in RTEMS_Malloc_Initialize (areas=0x80003f78,
>>> area_count=1, extend=0x0)
>>> rtems-riscv/c/src/../../cpukit/libcsupport/src/malloc_initialize.c:40
>>> #3  0x20400378 in bsp_work_area_initialize_default
>>> (area_begin=0x80000e10, area_size=12784) at ../../../../../.././hifive1/li
>>> b/include/bsp/bootcard.h:158
>>> #4  0x204003c0 in bsp_work_area_initialize () at
>>> rtems-riscv/c/src/lib/libbsp/riscv32/hifive1/../../shared/bs
>>> pgetworkarea.c:61
>>> rtems-riscv/c/src/lib/libbsp/riscv32/hifive1/../../shared/bootcard.c:76
>>> #7  0x20400064 in _end_clear_bss () at /home/reprofy/Projects/riscv/r
>>> tems/development/rtems/kernel/rtems-riscv/c/src/lib/libbsp/r
>>> iscv32/hifive1/start/start.S:116
>>> I want to figure out, why it wants to use memset on these addresses,
>>> because 0x80004000 is the maximum available address.
>> I was able to proceed further after adding
>> #define CONFIGURE_UNIFIED_WORK_AREAS
>> to init.c of low_ticker example.
>> Now I get an error:
>> #0  0x2040d940 in _Chain_Initialize_node (the_node=0x80003ec0) at
>> ../../cpukit/../../../hifive1/lib/include/rtems/score/chainimpl.h:127
>> #1  0x2040da82 in _Chain_Iterator_initialize (the_chain=0x80000320
>> <_User_extensions_List>, the_registry=0x8000032c
>> <_User_extensions_List+12>, the_iterator=0x80003ec0,
>>     direction=CHAIN_ITERATOR_FORWARD) at ../../cpukit/../../../hifive1/
>> lib/include/rtems/score/chainimpl.h:1049
>> #2  0x2040de90 in _User_extensions_Iterate (arg=0x80003f18,
>> visitor=0x2040dd48 <_User_extensions_Fatal_visitor>,
>> rtems-riscv/c/src/../../cpukit/score/src/userextiterate.c:174
>> #3  0x204036c4 in _User_extensions_Fatal (source=INTERNAL_ERROR_CORE,
>> error=4) at ../../cpukit/../../../hifive1/lib/include/rtems/score/userex
>> timpl.h:307
>> #4  0x204036e8 in _Terminate (the_source=INTERNAL_ERROR_CORE,
>> the_error=4) at /home/reprofy/Projects/riscv/r
>> tems/development/rtems/kernel/rtems-riscv/c/src/../../
>> cpukit/score/src/interr.c:35
>> #5  0x20403730 in _Internal_error (core_error=INTERNAL_ERROR_INT
>> ERRUPT_STACK_TOO_SMALL)
>> #6  0x20403824 in _ISR_Handler_initialization () at
>> rtems-riscv/c/src/../../cpukit/score/src/isr.c:51
>> #7  0x20402170 in rtems_initialize_data_structures () at
>> rtems-riscv/c/src/../../cpukit/sapi/src/exinit.c:82
>> #8  0x204021bc in rtems_initialize_executive () at
>> #9  0x2040031c in boot_card (cmdline=0x0) at
>> #10 0xffffcd98 in ?? ()
>> And I found out that rtems_minimum_stack_size variable is 0xab817bb3.
>> And I don't know why - in the low ticker example it is set to 512.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170619/99b19f2e/attachment-0002.html>
