RISC-V/HiFive memory limitations
Denis Obrezkov denisobrezkov at gmail.com
Fri Jun 23 00:32:10 UTC 2017
> Ok, then I will try to adapt the default linkcmd file today.
> Regards, Denis Obrezkov
Hello all,
It seems that data section wasn't copied from ROM, so I've added the
initialization code
and now I have a proper value. Thus, I can proceed further to new errors.
I haven't started to develop new linkcmd file, general for the architecture
+ specific
for the BSP. Should I? Hesham?
Also, I have a question:
there is a section called 'rwbarrier' and it is placed in data. Should it
be also initialized?
(copied from rom)
And is it possible to decrease a required memory amount by restricting a
user to C language usage?
(no C++ sections in linkcmd)
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170623/405777bc/attachment-0002.html>
