RISC-V/HiFive memory limitations
    Denis Obrezkov
    denisobrezkov at gmail.com
    Sun Jun 25 11:24:38 UTC 2017
2017-06-25 2:50 GMT+02:00 Denis Obrezkov <denisobrezkov at gmail.com>:
> 2017-06-25 2:15 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>> They are supposed to use the installed linkcmds.
>> On Jun 24, 2017 6:04 PM, "Denis Obrezkov" <denisobrezkov at gmail.com>
>> wrote:
>>> 2017-06-23 21:03 GMT+02:00 Denis Obrezkov <denisobrezkov at gmail.com>:
>>>> 2017-06-23 20:16 GMT+02:00 Denis Obrezkov <denisobrezkov at gmail.com>:
>>>>> 2017-06-23 16:39 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>>>>>> On Jun 23, 2017 9:29 AM, "Gedare Bloom" <gedare at rtems.org> wrote:
>>>>>> On Thu, Jun 22, 2017 at 8:32 PM, Denis Obrezkov <
>>>>>> denisobrezkov at gmail.com> wrote:
>>>>>> >> Ok, then I will try to adapt the default linkcmd file today.
>>>>>> >> Regards, Denis Obrezkov
>>>>>> > Hello all,
>>>>>> > It seems that data section wasn't copied from ROM, so I've added the
>>>>>> > initialization code
>>>>>> > and now I have a proper value. Thus, I can proceed further to new
>>>>>> errors.
>>>>>> > I haven't started to develop new linkcmd file, general for the
>>>>>> architecture
>>>>>> > + specific
>>>>>> > for the BSP. Should I? Hesham?
>>>>>> You may want to just get it working first, and then refactor the
>>>>>> linkcmds.
>>>>>> +1 just make sure it is working when you start doing this. :)
>>>>>> > Also, I have a question:
>>>>>> > there is a section called 'rwbarrier' and it is placed in data.
>>>>>> Should it be
>>>>>> > also initialized?
>>>>>> > (copied from rom)
>>>>>> Everything up to the bss probably should be copied from ROM.
>>>>>> Agreed. Is there a crt0 in libgloss for this architecture to check
>>>>>> against?
>>>>>> Just remember that the order and layout of sections may have implicit
>>>>>> ties to the code in the startup.
>>>>>> > And is it possible to decrease a required memory amount by
>>>>>> restricting a
>>>>>> > user to C language usage?
>>>>>> > (no C++ sections in linkcmd)
>>>>>> I don't think so. They shouldn't really be having an impact anyway
>>>>>> except for C++ applications.
>>>>>> All you end up with is a loop to iterate over the list of empty
>>>>>> global constructors.
>>>>>> > _______________________________________________
>>>>>> > devel mailing list
>>>>>> > devel at rtems.org
>>>>>> > http://lists.rtems.org/mailman/listinfo/devel
>>>>>> I have a little question: is there any connection between RTEMS
>>> linker files
>>> and example-v2 applications' linker files?
>>> I think I have a similar mistake there: .data section is not initialized.
>> Ok, I will investigate this and libgloss question.
> Since, I was a bit lazy, I moved the low_ticker example into the rtems
> testsuite folder and built it
> Now, I have no mistakes with uninitialized data section and I was able to
> proceed till the rtems_io_initialize function.
There is a crt0.s for RISC-V architecture.
https://github.com/riscv/riscv-newlib/blob/riscv-newlib-2.5.0/libgloss/riscv/crt0.S
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170625/0e2261e0/attachment-0002.html>
