[rtems-source-builder commit] sb: Bail out only if hash definitions conflict
Chris Johns
chrisj at rtems.org
Wed Mar 1 23:11:59 UTC 2017
[ correct list this time ]
On 01/03/2017 23:33, Sebastian Huber wrote:
> Module: rtems-source-builder
> Branch: master
> Commit: 4f72b95e60eedca772994f740a1fd0c973608632
> Changeset: http://git.rtems.org/rtems-source-builder/commit/?id=4f72b95e60eedca772994f740a1fd0c973608632
> Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date: Wed Mar 1 08:18:07 2017 +0100
Can all future commits to the RSB please be posted to the devel list for
review? This is changes to packages and changes to the code. Thanks.
This patch is wrong and should raise an exception if it is an error.
> source-builder/sb/sources.py | 18 +++++++++++-------
> 1 file changed, 11 insertions(+), 7 deletions(-)
> diff --git a/source-builder/sb/sources.py b/source-builder/sb/sources.py
> index fb6d819..967becc 100644
> --- a/source-builder/sb/sources.py
> +++ b/source-builder/sb/sources.py
> @@ -97,13 +97,17 @@ def hash(args, macros, error):
> return
> _map = 'hashes'
> _file = macros.expand(args[1])
> - if _file in macros.map_keys(_map):
> - error('hash already set: %s' % (args[1]))
> - return
This looks wrong (I know it is existing :)) ...
> - macros.create_map(_map)
> - macros.set_write_map(_map)
> - macros.define(_file, '%s %s' % (args[0], args[2]))
> - macros.unset_write_map()
> + new_value = '%s %s' % (args[0], args[2])
> + existing_value = get_hash(_file, macros)
> + if existing_value is not None:
> + if existing_value != new_value:
> + error('conflicting hash definitions for: %s' % (args[1]))
> + return
... and the same with this ...
> + else:
> + macros.create_map(_map)
> + macros.set_write_map(_map)
> + macros.define(_file, new_value)
> + macros.unset_write_map()
> return None
... cause None is returned.
vc mailing list
vc at rtems.org
http://lists.rtems.org/mailman/listinfo/vc
