Newlib Update for RTEMS 4.12
Joel Sherrill
joel at rtems.org
Thu Mar 2 17:15:04 UTC 2017
The failure appears to be that you did not install the rtems BSP for Zynq.
Did you do a make install after you built RTEMS?
What was your waf configure line?
--joel
On Mar 2, 2017 4:57 PM, "Sebastian Huber" <
> On 02/03/17 17:40, yao0718 wrote:
>> when I update the rsb on github ,rebuild my toolchain,use the master of
>> rtems and the master of rtems-libbsd on github, I got a error when I
>> compile libbsd.
> I don't get this error. Did you install the latest tool chain into a
> prefix which contained already an older tool chain?
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170302/3d161d82/attachment.html>
