[PATCH] Use a hash file for GCC only
Thu Mar 2 21:38:53 UTC 2017
On 03/03/2017 02:37, Gedare Bloom wrote:
> On Thu, Mar 2, 2017 at 10:26 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> On 02/03/17 16:23, Gedare Bloom wrote:
>>> In a way, I do like that this shows the different gcc-newlib versions
>>> we use. It might be nice to add a bit of organization to this hashes
>>> file and/or documentation of the procedure for adding/removing
>>> entries.
>>> Maybe it makes more sense to have a separate file for each version
>>> being used, e.g. a gcc-4.8.3 hash file, gcc-4.9.3, gcc-6.0.1, etc?
>>> That should make it easier to maintain the hashes.
>>> I'll leave it to Chris to decide if this is a suitable compromise.
>> I don't know why this hash stuff caused such an uproar. The hashes are
>> invariants of the files. If they ever change something is seriously wrong.
>> Things that never change should be defined exactly once in a system.
> It seems that you stumbled over an unwritten design philosophy.
Yes this is true and given the limited doco and time to create it I
apologize for this not being clearer. I feel reviews will help avoid
this situation.
This is an architectural change and my experience with the RSB is
changes like this always end up having 2 side. I have been caught before
implementing what I thought was a good and spending lots of time
cleaning it up or fixing side effects. For example hashes was a simple
addition to add a hash next to the specified file, what could be simpler.
> I'm
> not picking sides on this, but I do think it is a good idea to
> organize the hashes into include files to reduce the copy-paste.
The configurations need to be self contained and adding unrelated
information in a single place makes it harder to remove and clean up.
Yes the hashes are invariant as Sebastian points out and adding them is
easy however removing them is awkward and time consuming when you need
to determine where they may be used. Removing a configuration needs to
be simple and specific to the configuration and spreading fingers into
global lists would not help.
> I
> also think my suggestion of putting them in version-based files
> alleviates the "horizontal integration" concern.
What would you call the hashes file? Is it any different to the actual
configuration file?
Should we split newlib out from gcc and have the higher level include
each file to create the pair?
