[PATCH 08/44] leon: Fix ambapp_bus OCCAN device registeration order
Daniel Hellstrom daniel at gaisler.com
Fri Mar 3 14:56:41 UTC 2017
NOTE that this will change the association of /dev/occanN
with OCCAN[N] device to the same order as in hardware. This means
that if you have been useing /dev/occan0 before you have to use
/dev/occan1 on a dual OCCAN device system (this affects GR712RC).
 c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c | 28 +++++++++++++++--------
 1 file changed, 18 insertions(+), 10 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c b/c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c
index 922c43b..02aeda0 100644
--- a/c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c
+++ b/c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c
@@ -453,7 +453,11 @@ void ambapp_dev_info(
 #endif
-/* Fix device in last stage */
+/* Fix device in last stage and/or register additional devices.
+ * Function returns:
+ *  0  Register device as normal
+ *  1  Fixup function handles registration
 static int ambapp_dev_fixup(struct drvmgr_dev *dev, struct amba_dev_info *pnp)
 	/* OCCAN speciality:
@@ -464,12 +468,14 @@ static int ambapp_dev_fixup(struct drvmgr_dev *dev, struct amba_dev_info *pnp)
 	 *  Now, lets detect sub cores.
-	if ( (pnp->info.device == GAISLER_CANAHB) && (pnp->info.vendor == VENDOR_GAISLER) ) {
-		struct drvmgr_dev *newdev;
+	if ( (pnp->info.device == GAISLER_CANAHB) &&
+	     (pnp->info.vendor == VENDOR_GAISLER) ) {
+		struct drvmgr_dev *newdev, *devs_to_register[8];
 		struct amba_dev_info *pnpinfo;
 		int subcores;
 		int core;
+		devs_to_register[0] = dev;
 		subcores = (pnp->info.ahb_slv->ver & 0x7) + 1;
 		for(core = 1; core < subcores; core++) {
 			drvmgr_alloc_dev(&newdev, sizeof(*pnpinfo));
@@ -480,10 +486,14 @@ static int ambapp_dev_fixup(struct drvmgr_dev *dev, struct amba_dev_info *pnp)
 			pnpinfo->info.irq += core;
 			newdev->businfo = (void *)pnpinfo;
-			/* Register device */
-			drvmgr_dev_register(newdev);
+			devs_to_register[core] = newdev;
-	} else if ( (pnp->info.device == GAISLER_GPIO) && (pnp->info.vendor == VENDOR_GAISLER) ) {
+		/* Register all CAN devices */
+		for(core = 0; core < subcores; core++)
+			drvmgr_dev_register(devs_to_register[core]);
+		return 1;
+	} else if ( (pnp->info.device == GAISLER_GPIO) &&
 		/* PIO[N] is connected to IRQ[N]. */
 		pnp->info.irq = 0;
@@ -583,10 +593,8 @@ static void ambapp_core_register(
 	/* Connect device with PnP information */
-	ambapp_dev_fixup(newdev, pnpinfo);
-	/* Register New Device */
+	if ( ambapp_dev_fixup(newdev, pnpinfo) == 0 )
+		drvmgr_dev_register(newdev); /* Register New Device */
 /* Register one AMBA device */
2.7.4
