[PATCH 13/44] leon, grspw_pkt: Manual handling of link status events
Daniel Hellstrom daniel at gaisler.com
Fri Mar 3 14:56:46 UTC 2017
Added functionality for manual handling of link status events,
configurable via grspw_link_ctrl.
Added statistics counter for disconnect error.
 c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h | 12 +++++++++++-
 c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c     | 17 +++++++++++++++--
 2 files changed, 26 insertions(+), 3 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h b/c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h
index ea0ae9a..17bbee8 100644
--- a/c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h
+++ b/c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h
@@ -184,6 +184,7 @@ struct grspw_core_stats {
 	int err_eeop;
 	int err_addr;
 	int err_parity;
+	int err_disconnect;
 	int err_escape;
 	int err_wsync; /* only in GRSPW1 */
@@ -216,6 +217,15 @@ struct grspw_core_stats {
 					  * channels.
+#define LINKSTS_CE		0x002	/* Credit error */
+#define LINKSTS_ER		0x004	/* Escape error */
+#define LINKSTS_DE		0x008	/* Disconnect error */
+#define LINKSTS_PE		0x010	/* Parity error */
+#define LINKSTS_WE		0x040	/* Write synchonization error (GRSPW1 only) */
+#define LINKSTS_IA		0x080	/* Invalid address */
+#define LINKSTS_EE		0x100	/* Early EOP/EEP */
+#define LINKSTS_MASK		0x1de
 /* grspw_tc_ctrl() options */
 #define TCOPTS_EN_RXIRQ	0x0001	/* Tick-Out IRQ */
@@ -325,7 +335,7 @@ extern spw_link_state_t grspw_link_state(void *d);
  *  bits 7..0  : Clock Div RUN (only run-state)
  *  bits 15..8 : Clock Div During Startup (all link states except run-state)
-extern void grspw_link_ctrl(void *d, int *options, int *clkdiv);
+extern void grspw_link_ctrl(void *d, int *options, int *stscfg, int *clkdiv);
 /* Read the current value of the status register */
 extern unsigned int grspw_link_status(void *d);
 /* Clear bits in the status register */
diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c b/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
index 1827fbd..22fcda3 100644
--- a/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
+++ b/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
@@ -472,6 +472,9 @@ struct grspw_priv {
 	/* Bit mask representing events which shall cause link disable. */
 	unsigned int dis_link_on_err;
+	/* Bit mask for link status bits to clear by ISR */
+	unsigned int stscfg;
 	/* "Core Global" Statistics gathered, not dependent on DMA channel */
 	struct grspw_core_stats stats;
@@ -538,6 +541,7 @@ void *grspw_open(int dev_no)
 	priv->tcisr_arg = NULL;
 	priv->icisr = NULL;
 	priv->icisr_arg = NULL;
+	priv->stscfg = LINKSTS_MASK;
 	grspw_stats_clr(priv);
@@ -745,7 +749,7 @@ static inline int grspw_is_irqsource_set(unsigned int ctrl, unsigned int icctrl)
 /* options and clkdiv [in/out]: set to -1 to only read current config */
-void grspw_link_ctrl(void *d, int *options, int *clkdiv)
+void grspw_link_ctrl(void *d, int *options, int *stscfg, int *clkdiv)
 	struct grspw_priv *priv = d;
 	struct grspw_regs *regs = priv->regs;
@@ -782,6 +786,12 @@ void grspw_link_ctrl(void *d, int *options, int *clkdiv)
 		SPIN_UNLOCK_IRQ(&priv->devlock, irqflags);
 		*options = (ctrl & GRSPW_LINK_CFG) | priv->dis_link_on_err;
+	if (stscfg) {
+		if (*stscfg != -1) {
+			priv->stscfg = *stscfg & LINKSTS_MASK;
+		*stscfg = priv->stscfg;
 /* Generate Tick-In (increment Time Counter, Send Time Code) */
@@ -2494,7 +2504,7 @@ STATIC void grspw_isr(void *data)
 	/* Get Status from Hardware */
 	stat = REG_READ(&priv->regs->status);
-	stat_clrmsk = stat & (GRSPW_STS_TO | GRSPW_STAT_ERROR);
+	stat_clrmsk = stat & (GRSPW_STS_TO | GRSPW_STAT_ERROR) & priv->stscfg;
 	/* Make sure to put the timecode handling first in order to get the
 	 * smallest possible interrupt latency
@@ -2550,6 +2560,9 @@ STATIC void grspw_isr(void *data)
 		if (stat & GRSPW_STS_PE)
 			priv->stats.err_parity++;
+		if (stat & GRSPW_STS_DE)
+			priv->stats.err_disconnect++;
 		if (stat & GRSPW_STS_ER)
 			priv->stats.err_escape++;
2.7.4
