[PATCH 15/44] leon, grspw_pkt: fixed and improved RX/TX wait
Daniel Hellstrom daniel at gaisler.com
Fri Mar 3 14:56:48 UTC 2017
 c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h |  6 +-
 c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c     | 99 +++++++++++++----------
 2 files changed, 61 insertions(+), 44 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h b/c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h
index 17bbee8..0bc749f 100644
--- a/c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h
+++ b/c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h
@@ -487,7 +487,7 @@ extern void grspw_dma_tx_count(void *c, int *send, int *sched, int *sent);
 #define GRSPW_OP_AND 0
 #define GRSPW_OP_OR 1
-/* Block until ready_cnt or fewer packets are Queued in "Send and Scheduled" Q,
+/* Block until send_cnt or fewer packets are Queued in "Send and Scheduled" Q,
  * op (AND or OR), sent_cnt or more packet "have been sent" (Sent Q) condition
  * is met.
  * If a link error occurs and the Stop on Link error is defined, this function
@@ -504,6 +504,7 @@ extern void grspw_dma_tx_count(void *c, int *send, int *sched, int *sent);
  *  0    Returing to caller because specified conditions are now fullfilled
  *  1    DMA stopped
  *  2    Timeout, conditions are not met
+ *  3    Another task is already waiting. Service is Busy.
 extern int grspw_dma_tx_wait(void *c, int send_cnt, int op, int sent_cnt, int timeout);
@@ -565,7 +566,7 @@ extern void grspw_dma_rx_count(void *c, int *ready, int *sched, int *recv);
  * the other conditions. If timeout is zero, the function will wait forever
  * until the condition is satisfied.
- * NOTE: if IRQ of TX descriptors are not enabled conditions are never
+ * NOTE: if IRQ of RX descriptors are not enabled conditions are never
  *       checked, this may hang infinitely unless a timeout has been specified
  * Return Code
@@ -573,6 +574,7 @@ extern void grspw_dma_rx_count(void *c, int *ready, int *sched, int *recv);
  *  1    DMA stopped
 extern int grspw_dma_rx_wait(void *c, int recv_cnt, int op, int ready_cnt, int timeout);
diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c b/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
index ce4012b..359b1ac 100644
--- a/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
+++ b/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
@@ -1926,7 +1926,7 @@ static inline int grspw_tx_wait_eval(struct grspw_dma_priv *dma)
 	struct grspw_dma_priv *dma = c;
-	int ret, rc;
+	int ret, rc, initialized = 0;
 	if (timeout == 0)
 		timeout = RTEMS_NO_TIMEOUT;
@@ -1941,15 +1941,15 @@ check_condition:
 	/* Check so that no other thread is waiting, this driver only supports
 	 * one waiter at a time.
-	if (dma->tx_wait.waiting) {
-		ret = -1;
-		goto out;
+	if (initialized == 0 && dma->tx_wait.waiting) {
+		ret = 3;
+		goto out_release;
-	/* Stop if link error or similar, abort */
+	/* Stop if link error or similar (DMA stopped), abort */
 	if (dma->started == 0) {
 		ret = 1;
-		goto out;
+		goto out_release;
 	/* Set up Condition */
@@ -1959,6 +1959,7 @@ check_condition:
 	if (grspw_tx_wait_eval(dma) == 0) {
 		/* Prepare Wait */
+		initialized = 1;
 		dma->tx_wait.waiting = 1;
 		/* Release DMA channel lock */
@@ -1970,27 +1971,34 @@ check_condition:
 		rc = rtems_semaphore_obtain(dma->tx_wait.sem_wait, RTEMS_WAIT,
 						timeout);
 		if (rc == RTEMS_TIMEOUT) {
-			dma->tx_wait.waiting = 0;
-			return 2;
+			ret = 2;
+			goto out;
 		} else if (rc == RTEMS_UNSATISFIED ||
 		           rc == RTEMS_OBJECT_WAS_DELETED) {
-			return 1; /* sem was flushed/deleted, means DMA stop */
-		} else if (rc != RTEMS_SUCCESSFUL)
-		    	return -1;
+			ret = 1; /* sem was flushed/deleted, means DMA stop */
+			goto out;
+		} else if (rc != RTEMS_SUCCESSFUL) {
+			/* Unknown Error */
+			ret = -1;
+			goto out;
+		} else if (dma->started == 0) {
+			ret = 1;
+			goto out;
 		/* Check condition once more */
 		goto check_condition;
-	} else {
-		/* No Wait needed */
 	ret = 0;
-out:
+out_release:
 	/* Unlock DMA channel */
 	rtems_semaphore_release(dma->sem_dma);
+out:
+	if (initialized)
+		dma->tx_wait.waiting = 0;
 	return ret;
@@ -2132,7 +2140,7 @@ static inline int grspw_rx_wait_eval(struct grspw_dma_priv *dma)
-	int ret, rc;
 	if (timeout == 0)
@@ -2147,15 +2155,15 @@ check_condition:
-	if (dma->rx_wait.waiting) {
-		ret = -1;
-		goto out;
+	if (initialized == 0 && dma->rx_wait.waiting) {
+		ret = 3;
+		goto out_release;
-	/* Stop if link error or similar (MDA stopped) */
 		ret = 1;
-		goto out;
+		goto out_release;
@@ -2165,6 +2173,7 @@ check_condition:
 	if (grspw_rx_wait_eval(dma) == 0) {
 		/* Prepare Wait */
+		initialized = 1;
 		dma->rx_wait.waiting = 1;
 		/* Release channel lock */
@@ -2176,27 +2185,34 @@ check_condition:
 		rc = rtems_semaphore_obtain(dma->rx_wait.sem_wait, RTEMS_WAIT,
 		                           timeout);
-			dma->rx_wait.waiting = 0;
-			return 2;
+		    	ret = 2;
+			goto out;
-		    	return -1;
+			goto out;
+			ret = -1;
+			goto out;
+			ret = 1;
+			goto out;
-	} else {
 	ret = 0;
-out:
+out_release:
+out:
+	if (initialized)
+		dma->rx_wait.waiting = 0;
 	return ret;
@@ -2398,8 +2414,8 @@ static void grspw_work_shutdown_func(struct grspw_priv *priv)
 	int i;
 	/* Link is down for some reason, and the user has configured
-	 * that we stop all DMA channels and throw out all blocked
-	 * threads.
+	 * that we stop all (open) DMA channels and throw out all their
+	 * blocked threads.
 	for (i=0; i<priv->hwsup.ndma_chans; i++)
 		grspw_dma_stop(&priv->dma[i]);
@@ -2422,6 +2438,10 @@ static void grspw_work_dma_func(struct grspw_dma_priv *dma)
 		return;
+	/* If closing DMA channel or just shut down */
+	if (dma->started == 0)
+		goto out;
 	/* Look at cause we were woken up and clear source */
 	SPIN_LOCK_IRQ(&priv->devlock, irqflags);
 	ctrl = REG_READ(&dma->regs->ctrl);
@@ -2448,26 +2468,21 @@ static void grspw_work_dma_func(struct grspw_dma_priv *dma)
 			/* Check to see if condition for waking blocked USER
 		 	 * task is fullfilled.
+			if (dma->rx_wait.waiting)
 				rx_cond_true = grspw_rx_wait_eval(dma);
-				if (rx_cond_true)
 		if (ctrl & GRSPW_DMACTRL_PS) {
 			/* Do TX Work */
 			dma->stats.tx_work_cnt++;
 			grspw_tx_process_scheduled(dma);
 			dma->stats.tx_work_enabled += grspw_tx_schedule_send(dma);
+			if (dma->tx_wait.waiting)
 				tx_cond_true = grspw_tx_wait_eval(dma);
-				if (tx_cond_true)
 	} else
 		SPIN_UNLOCK_IRQ(&priv->devlock, irqflags);
+out:
 	/* Release lock */
2.7.4
