[PATCH 19/44] leon, grspw_pkt: allow user controlled DMA intr
Daniel Hellstrom daniel at gaisler.com
Fri Mar 3 14:56:52 UTC 2017
The user has already the power to control which DMA buffer
will generate interrupt, but no clean way to enable RX/TX
interrupts on DMA channel. Without this patch the user had
to init DMA config rx/tx_irq_en_cnt to a very large value.
 c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h | 12 +++++++++++-
 c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c     | 12 +++++++-----
 2 files changed, 18 insertions(+), 6 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h b/c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h
index 1bab68b..995d8bd 100644
--- a/c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h
+++ b/c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h
@@ -261,9 +261,19 @@ struct grspw_core_stats {
 #define DMAFLAG_STRIP_PID	0x0008	/* See HW doc DMA-CTRL SP bit */
 #define DMAFLAG_RESV2		0x0010	/* HAS NO EFFECT */
 #define DMAFLAG_MASK	(DMAFLAG_NO_SPILL|DMAFLAG_STRIP_ADR|DMAFLAG_STRIP_PID)
+/* grspw_dma_config.flags misc options (not shifted internally) */
+#define DMAFLAG2_TXIE	0x00100000	/* See HW doc DMA-CTRL TI bit.
+					 * Used to enable TX DMA interrupt
+					 * when tx_irq_en_cnt=0.
+#define DMAFLAG2_RXIE	0x00200000	/* See HW doc DMA-CTRL RI bit.
+					 * Used to enable RX DMA interrupt
+					 * when rx_irq_en_cnt=0.
+#define DMAFLAG2_MASK	(DMAFLAG2_TXIE | DMAFLAG2_RXIE)
 struct grspw_dma_config {
-	int flags;		/* DMA config flags, see DMAFLAG_* options */
+	int flags;		/* DMA config flags, see DMAFLAG1&2_* options */
 	int rxmaxlen;		/* RX Max Packet Length */
 	int rx_irq_en_cnt;	/* Enable RX IRQ every cnt descriptors */
 	int tx_irq_en_cnt;	/* Enable TX IRQ every cnt descriptors */
diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c b/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
index 048f7d1..9f9a31a 100644
--- a/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
+++ b/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
@@ -2301,7 +2301,7 @@ int grspw_dma_config(void *c, struct grspw_dma_config *cfg)
 	if (dma->started || !cfg)
 		return -1;
-	if (cfg->flags & ~DMAFLAG_MASK)
+	if (cfg->flags & ~(DMAFLAG_MASK | DMAFLAG2_MASK))
 		return -1;
 	/* Update Configuration */
@@ -2398,9 +2398,9 @@ int grspw_dma_start(void *c)
 		(dma->cfg.flags & DMAFLAG_MASK) << GRSPW_DMACTRL_NS_BIT;
 	if (dma->core->dis_link_on_err & LINKOPTS_DIS_ONERR)
 		ctrl |= GRSPW_DMACTRL_LE;
-	if (dma->cfg.rx_irq_en_cnt != 0)
+	if (dma->cfg.rx_irq_en_cnt != 0 || dma->cfg.flags & DMAFLAG2_RXIE)
 		ctrl |= GRSPW_DMACTRL_RI;
-	if (dma->cfg.tx_irq_en_cnt != 0)
+	if (dma->cfg.tx_irq_en_cnt != 0 || dma->cfg.flags & DMAFLAG2_TXIE)
 		ctrl |= GRSPW_DMACTRL_TI;
 	SPIN_LOCK_IRQ(&dma->core->devlock, irqflags);
 	ctrl |= REG_READ(&dma->regs->ctrl) & GRSPW_DMACTRL_EN;
@@ -2540,9 +2540,11 @@ static void grspw_work_dma_func(struct grspw_dma_priv *dma)
 	} else if (ctrl & (GRSPW_DMACTRL_PR | GRSPW_DMACTRL_PS)) {
 		/* DMA has finished a TX/RX packet */
 		ctrl &= ~GRSPW_DMACTRL_AT;
+		    (dma->cfg.flags & DMAFLAG2_RXIE))
+		    (dma->cfg.flags & DMAFLAG2_TXIE))
 		REG_WRITE(&dma->regs->ctrl, ctrl);
 		SPIN_UNLOCK_IRQ(&priv->devlock, irqflags);
2.7.4
