[PATCH 22/44] leon, grspw_pkt: fix stscfg cfg TimeCode Int clr
Daniel Hellstrom daniel at gaisler.com
Fri Mar 3 14:56:55 UTC 2017
Without this patch time code interrupts was never cleared
in the STATUS register.
 c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c b/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
index 60aa68f..5f40853 100644
--- a/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
+++ b/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
@@ -2666,7 +2666,8 @@ STATIC void grspw_isr(void *data)
 	/* Get Status from Hardware */
 	stat = REG_READ(&priv->regs->status);
-	stat_clrmsk = stat & (GRSPW_STS_TO | GRSPW_STAT_ERROR) & priv->stscfg;
+	stat_clrmsk = stat & (GRSPW_STS_TO | GRSPW_STAT_ERROR) &
+			(GRSPW_STS_TO | priv->stscfg);
 	/* Make sure to put the timecode handling first in order to get the
 	 * smallest possible interrupt latency
2.7.4
