[PATCH 32/44] leon, grpci2: latency timer user configurable (default 64)
Daniel Hellstrom daniel at gaisler.com
Fri Mar 3 14:57:05 UTC 2017
 c/src/lib/libbsp/sparc/shared/include/grpci2.h |  4 ++++
 c/src/lib/libbsp/sparc/shared/pci/grpci2.c     | 16 ++++++++++++++++
 2 files changed, 20 insertions(+)
diff --git a/c/src/lib/libbsp/sparc/shared/include/grpci2.h b/c/src/lib/libbsp/sparc/shared/include/grpci2.h
index 624191e..c356b56 100644
--- a/c/src/lib/libbsp/sparc/shared/include/grpci2.h
+++ b/c/src/lib/libbsp/sparc/shared/include/grpci2.h
@@ -36,6 +36,10 @@ extern void grpci2_register_drv(void);
  * Name="byteTwisting", Type=INT, Enable/Disable Bytetwisting by hardware
+ * PCI Latency timer
+ * Name="latencyTimer", Type=INT, Set the latency timer
  * PCI Host's Target BARs setup
  * The Host's BARs are not configured by the configuration routines, by default
diff --git a/c/src/lib/libbsp/sparc/shared/pci/grpci2.c b/c/src/lib/libbsp/sparc/shared/pci/grpci2.c
index 7fca3cd..be459cc 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/grpci2.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/grpci2.c
@@ -57,6 +57,9 @@
 /* If defined to 1 - byte twisting is enabled by default */
 #define DEFAULT_BT_ENABLED 0
+/* If defined to 64 - Latency timer is 64 by default */
+#define DEFAULT_LATENCY_TIMER 64
 /* Interrupt assignment. Set to other value than 0xff in order to
  * override defaults and plug&play information
@@ -237,6 +240,7 @@ struct grpci2_priv {
 	char				irq_mode; /* IRQ Mode from CAPSTS REG */
 	char				bt_enabled;
 	unsigned int			irq_mask;
+	unsigned int			latency_timer;
 	struct grpci2_pcibar_cfg	*barcfg;
@@ -696,6 +700,12 @@ static int grpci2_hw_init(struct grpci2_priv *priv)
 	data |= (PCIM_CMD_MEMEN | PCIM_CMD_BUSMASTEREN);
 	grpci2_cfg_w32(host, PCIR_COMMAND, data);
+	/* set latency timer */
+	grpci2_cfg_r32(host, PCIR_CACHELNSZ, &data);
+	data &= ~0xff00;
+	data |= ((priv->latency_timer & 0xff) << 8);
+	grpci2_cfg_w32(host, PCIR_CACHELNSZ, data);
 	/* Enable Error respone (CPU-TRAP) on illegal memory access */
 	regs->ctrl = CTRL_ER | CTRL_PE;
@@ -733,6 +743,7 @@ static int grpci2_init(struct grpci2_priv *priv)
 	priv->regs = (struct grpci2_regs *)apb->start;
 	priv->bt_enabled = DEFAULT_BT_ENABLED;
 	priv->irq_mode = (priv->regs->sts_cap & STS_IRQMODE) >> STS_IRQMODE_BIT;
+	priv->latency_timer = DEFAULT_LATENCY_TIMER;
 	/* Calculate the PCI windows
 	 *  AMBA->PCI Window:                       AHB SLAVE AREA0
@@ -791,6 +802,11 @@ static int grpci2_init(struct grpci2_priv *priv)
 	else
 		priv->barcfg = grpci2_default_bar_mapping;
+	/* User may override DEFAULT_LATENCY_TIMER */
+	value = drvmgr_dev_key_get(priv->dev, "latencyTimer", DRVMGR_KT_INT);
+	if (value)
+		priv->latency_timer = value->i;
 	/* This driver only support HOST systems, we check that it can act as a
 	 * PCI Master and that it is in the Host slot. */
 	if ((priv->regs->sts_cap&STS_HOST) || !(priv->regs->sts_cap&STS_MST))
2.7.4
