[PATCH 38/44] leon, grspw_pkt: add missing GRSPW1 IP-core support
Daniel Hellstrom daniel at gaisler.com
Fri Mar 3 14:57:11 UTC 2017
 c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c | 23 +++++++++++++++++++++++
 1 file changed, 23 insertions(+)
diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c b/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
index 6b5390f..aa83524 100644
--- a/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
+++ b/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
@@ -3010,6 +3010,20 @@ void grspw_initialize_user(void *(*devfound)(int), void (*devremove)(int,void*))
+/* Get a value at least 6.4us in number of clock cycles */
+static unsigned int grspw1_calc_timer64(int freq_khz)
+	unsigned int timer64 = (freq_khz * 64 + 9999) / 10000;
+	return timer64 & 0xfff;
+/* Get a value at least 850ns in number of clock cycles - 3 */
+static unsigned int grspw1_calc_discon(int freq_khz)
+	unsigned int discon = ((freq_khz * 85 + 99999) / 100000) - 3;
+	return discon & 0x3ff;
 /******************* Driver manager interface ***********************/
 /* Driver prototypes */
@@ -3111,9 +3125,18 @@ static int grspw2_init3(struct drvmgr_dev *dev)
 		priv->hwsup.strip_adr = 1; /* All GRSPW2 can strip Address */
 		priv->hwsup.strip_pid = 1; /* All GRSPW2 can strip PID */
 	} else {
+		unsigned int apb_hz, apb_khz;
 		/* Autodetect GRSPW1 features? */
 		priv->hwsup.strip_adr = 0;
 		priv->hwsup.strip_pid = 0;
+		drvmgr_freq_get(dev, DEV_APB_SLV, &apb_hz);
+		apb_khz = apb_hz / 1000;
+		REG_WRITE(&priv->regs->timer,
+			((grspw1_calc_discon(apb_khz) & 0x3FF) << 12) |
+			(grspw1_calc_timer64(apb_khz) & 0xFFF));
 	/* Probe width of SpaceWire Interrupt ISR timers. All have the same
2.7.4
