GSoC 2017
punit vara punitvara at gmail.com
Fri Mar 3 17:57:47 UTC 2017
Hi
On Fri, Mar 3, 2017 at 9:45 PM, aditya upadhyay <aadit0402 at gmail.com> wrote:
> Hello all,
> I am trying to implement pthread_condattr_getclock() in pthread.h in POSIX
> directory. but i am not able to understand where and which location(files
> and directories) these changes would require.As there are 3 pthread.h files
> and i think implementation of this function is done at this location
> (/home/aditya/development/rtems/4.12/sparc-rtems4.12/include/). I have used
This location is not the actual RTEMS kernel location. Whenever you
want to implement something you should add in actual source code.
Which should be look like :
https://github.com/RTEMS/rtems
Here Posix directory is
/rtems/cpukit/posix/src
@Gedare Correct me if I am wrong ? I think we guys add POSIX function
in this directory only right ?
> FREEBSD and NETBSD as a reference.Would you please help me so that i can
> proceed.
> Regards,
> Aditya
