Issue with 'rtems_shell_wait_for_input' function
vivek kukreja vivekkukreja5 at gmail.com
Fri Mar 3 22:50:00 UTC 2017
Hello all,
I made few changes to the fileio test to run NFS using libbsd. The test compiles and when i run it on qemu NFS is initialised.
The test starts with the 'rtems_shell_wait_for_input' function which returns RTEMS_UNSATISFIED so the test quits as soon as it begins. I read this means the terminal related attributes could not be set. When i bypass this function to directly start the test it works fine. Im not sure this is a bug or some problem with my configuration. Any help with this issue is appreciated!
Regards,
Vivek
