GSoC 2017
Sat Mar 4 01:28:04 UTC 2017
On Fri, Mar 3, 2017 at 5:40 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Mar 3, 2017 9:47 PM, "Gedare Bloom" <gedare at rtems.org> wrote:
> On Fri, Mar 3, 2017 at 12:57 PM, punit vara <punitvara at gmail.com> wrote:
>> Hi
>> On Fri, Mar 3, 2017 at 9:45 PM, aditya upadhyay <aadit0402 at gmail.com>
>> wrote:
>>> Hello all,
>>> I am trying to implement pthread_condattr_getclock() in pthread.h in
>>> POSIX
>>> directory. but i am not able to understand where and which location(files
>>> and directories) these changes would require.As there are 3 pthread.h
>>> files
>>> and i think implementation of this function is done at this location
>>> (/home/aditya/development/rtems/4.12/sparc-rtems4.12/include/). I have
>>> used
> Gedare.. is this method implemented already or have I just thought about it
> so much I think it is.
https://git.rtems.org/rtems/tree/cpukit/posix/src/condattrgetclock.c#n24
>> This location is not the actual RTEMS kernel location. Whenever you
>> want to implement something you should add in actual source code.
>> Which should be look like :
>> https://github.com/RTEMS/rtems
>> Here Posix directory is
>> /rtems/cpukit/posix/src
>> @Gedare Correct me if I am wrong ? I think we guys add POSIX function
>> in this directory only right ?
> POSIX stuff goes there, or in newlib. See also
> https://devel.rtems.org/ticket/2833
>>> FREEBSD and NETBSD as a reference.Would you please help me so that i can
>>> proceed.
>>> Regards,
>>> Aditya
> devel mailing list
> devel at rtems.org
