[PATCH] arm: Remove legacy execption support
Tue Mar 7 13:33:44 UTC 2017
 c/src/lib/libbsp/arm/Makefile.am                 |   3 -
 c/src/lib/libbsp/arm/csb336/Makefile.am          |   2 -
 c/src/lib/libbsp/arm/csb336/start/start.S        |  55 ++++----
 c/src/lib/libbsp/arm/csb336/startup/bspstart.c   |   6 -
 c/src/lib/libbsp/arm/csb337/Makefile.am          |   2 -
 c/src/lib/libbsp/arm/csb337/start/start.S        |  55 ++++----
 c/src/lib/libbsp/arm/csb337/startup/bspstart.c   |   6 -
 c/src/lib/libbsp/arm/edb7312/Makefile.am         |   2 -
 c/src/lib/libbsp/arm/edb7312/start/start.S       |  70 +++++-----
 c/src/lib/libbsp/arm/edb7312/startup/bspstart.c  |   6 -
 c/src/lib/libbsp/arm/gumstix/Makefile.am         |   2 -
 c/src/lib/libbsp/arm/gumstix/start/start.S       |  55 ++++----
 c/src/lib/libbsp/arm/gumstix/startup/bspstart.c  |   2 -
 c/src/lib/libbsp/arm/rtl22xx/Makefile.am         |   2 -
 c/src/lib/libbsp/arm/rtl22xx/start/start.S       |  97 ++++---------
 c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c  |   6 -
 c/src/lib/libbsp/arm/shared/abort/abort.c        | 145 --------------------
 c/src/lib/libbsp/arm/shared/abort/abort.h        |  52 -------
 c/src/lib/libbsp/arm/shared/abort/simple_abort.c | 146 --------------------
 c/src/lib/libbsp/arm/smdk2410/Makefile.am        |   2 -
 c/src/lib/libbsp/arm/smdk2410/start/start.S      |  55 ++++----
 c/src/lib/libbsp/arm/smdk2410/startup/bspstart.c |   6 -
 cpukit/score/cpu/arm/Makefile.am                 |   2 -
 cpukit/score/cpu/arm/arm_exc_handler_high.c      | 127 -----------------
 cpukit/score/cpu/arm/arm_exc_handler_low.S       | 166 -----------------------
 cpukit/score/cpu/arm/rtems/score/cpu.h           |   6 -
 26 files changed, 182 insertions(+), 896 deletions(-)
 delete mode 100644 c/src/lib/libbsp/arm/shared/abort/abort.c
 delete mode 100644 c/src/lib/libbsp/arm/shared/abort/abort.h
 delete mode 100644 c/src/lib/libbsp/arm/shared/abort/simple_abort.c
 delete mode 100644 cpukit/score/cpu/arm/arm_exc_handler_high.c
 delete mode 100644 cpukit/score/cpu/arm/arm_exc_handler_low.S
diff --git a/c/src/lib/libbsp/arm/Makefile.am b/c/src/lib/libbsp/arm/Makefile.am
index 9783354..a567a2c 100644
--- a/c/src/lib/libbsp/arm/Makefile.am
+++ b/c/src/lib/libbsp/arm/Makefile.am
@@ -18,9 +18,6 @@ EXTRA_DIST =
 EXTRA_DIST += shared/comm/uart.h
 EXTRA_DIST += shared/comm/uart.c
-# abort
-EXTRA_DIST += shared/abort/simple_abort.c
 include $(srcdir)/preinstall.am
 include $(top_srcdir)/../../../automake/subdirs.am
 include $(top_srcdir)/../../../automake/local.am
diff --git a/c/src/lib/libbsp/arm/csb336/Makefile.am b/c/src/lib/libbsp/arm/csb336/Makefile.am
index 27d159f..09bc358 100644
--- a/c/src/lib/libbsp/arm/csb336/Makefile.am
+++ b/c/src/lib/libbsp/arm/csb336/Makefile.am
@@ -38,8 +38,6 @@ libbsp_a_SOURCES += ../../shared/cpucounterread.c
 libbsp_a_SOURCES += ../../shared/cpucounterdiff.c
 # console
 libbsp_a_SOURCES += console/uart.c
-# abort
-libbsp_a_SOURCES += ../shared/abort/abort.c
 # IRQ
 include_bsp_HEADERS += ../../shared/include/irq-generic.h \
 	../../shared/include/irq-info.h
diff --git a/c/src/lib/libbsp/arm/csb336/start/start.S b/c/src/lib/libbsp/arm/csb336/start/start.S
index 1935ded..ce452f5 100644
--- a/c/src/lib/libbsp/arm/csb336/start/start.S
+++ b/c/src/lib/libbsp/arm/csb336/start/start.S
@@ -132,28 +132,35 @@ _hang:  b       _hang
  * of 16 words (64 bytes)
 vector_block:
-        ldr     pc, Reset_Handler
-        ldr     pc, Undefined_Handler
-        ldr     pc, SWI_Handler
-        ldr     pc, Prefetch_Handler
-        ldr     pc, Abort_Handler
+        ldr    pc, handler_addr_reset
+        ldr    pc, handler_addr_undef
+        ldr    pc, handler_addr_swi
+        ldr    pc, handler_addr_prefetch
+        ldr    pc, handler_addr_abort
         nop
-        ldr     pc, IRQ_Handler
-        ldr     pc, FIQ_Handler
-Reset_Handler:          b       bsp_reset
-Undefined_Handler:      b       Undefined_Handler
-SWI_Handler:            b       SWI_Handler
-Prefetch_Handler:       b       Prefetch_Handler
-Abort_Handler:          b       Abort_Handler
-                        nop
-IRQ_Handler:            b       IRQ_Handler
-FIQ_Handler:            b       FIQ_Handler
-.globl Reset_Handler
-.globl Undefined_Handler
-.globl SWI_Handler
-.globl Prefetch_Handler
-.globl Abort_Handler
-.globl IRQ_Handler
-.globl FIQ_Handler
+        ldr    pc, handler_addr_irq
+        ldr    pc, handler_addr_fiq
+handler_addr_reset:
+        .word  bsp_reset
+handler_addr_undef:
+        .word  _ARMV4_Exception_undef_default
+handler_addr_swi:
+        .word  _ARMV4_Exception_swi_default
+handler_addr_prefetch:
+        .word  _ARMV4_Exception_pref_abort_default
+handler_addr_abort:
+        .word  _ARMV4_Exception_data_abort_default
+handler_addr_reserved:
+        .word  _ARMV4_Exception_reserved_default
+handler_addr_irq:
+        .word  _ARMV4_Exception_interrupt
+handler_addr_fiq:
+        .word  _ARMV4_Exception_fiq_default
diff --git a/c/src/lib/libbsp/arm/csb336/startup/bspstart.c b/c/src/lib/libbsp/arm/csb336/startup/bspstart.c
index 0a134ba..8970dfb 100644
--- a/c/src/lib/libbsp/arm/csb336/startup/bspstart.c
+++ b/c/src/lib/libbsp/arm/csb336/startup/bspstart.c
@@ -55,12 +55,6 @@ static void bsp_start_default( void )
   MC9328MXL_AITC_NIMASK = 0x1f;
-   * Init rtems exceptions management
-  /* FIXME: Use shared start.S */
-  rtems_exception_init_mngt();
    * Init rtems interrupt management
   bsp_interrupt_initialize();
diff --git a/c/src/lib/libbsp/arm/csb337/Makefile.am b/c/src/lib/libbsp/arm/csb337/Makefile.am
index 018bf67..f4bcd35 100644
--- a/c/src/lib/libbsp/arm/csb337/Makefile.am
+++ b/c/src/lib/libbsp/arm/csb337/Makefile.am
@@ -75,8 +75,6 @@ libbsp_a_SOURCES += ../../shared/src/irq-shell.c
 if ENABLE_LCD
 libbsp_a_SOURCES += console/sed1356.c console/fbcons.c
 endif
-# abort
 # umon
 if ENABLE_UMON
 libbsp_a_SOURCES += ../../shared/umon/umonrtemsglue.c  \
diff --git a/c/src/lib/libbsp/arm/csb337/start/start.S b/c/src/lib/libbsp/arm/csb337/start/start.S
index 1c77d99..f88cf41 100644
--- a/c/src/lib/libbsp/arm/csb337/start/start.S
+++ b/c/src/lib/libbsp/arm/csb337/start/start.S
@@ -118,28 +118,35 @@ _hang:  b       _hang
 vector_block:
         nop
-                        nop
-.globl SWI_Handler
-.globl IRQ_Handler
-.globl FIQ_Handler
+        .word  bsp_reset
+handler_addr_swi:
+handler_addr_irq:
+handler_addr_fiq:
diff --git a/c/src/lib/libbsp/arm/csb337/startup/bspstart.c b/c/src/lib/libbsp/arm/csb337/startup/bspstart.c
index 75c8fd7..a471985 100644
--- a/c/src/lib/libbsp/arm/csb337/startup/bspstart.c
+++ b/c/src/lib/libbsp/arm/csb337/startup/bspstart.c
@@ -54,12 +54,6 @@ static void bsp_start_default( void )
   bsp_usart_init();
diff --git a/c/src/lib/libbsp/arm/edb7312/Makefile.am b/c/src/lib/libbsp/arm/edb7312/Makefile.am
index fae2c5f..ff0fa67 100644
--- a/c/src/lib/libbsp/arm/edb7312/Makefile.am
+++ b/c/src/lib/libbsp/arm/edb7312/Makefile.am
@@ -47,8 +47,6 @@ libbsp_a_SOURCES += console/uart.c ../../shared/console.c \
     ../../shared/console_read.c ../../shared/console_write.c
 # timer
 libbsp_a_SOURCES += timer/timer.c
-# abort
 # irq
diff --git a/c/src/lib/libbsp/arm/edb7312/start/start.S b/c/src/lib/libbsp/arm/edb7312/start/start.S
index e1af00d..e03707b 100644
--- a/c/src/lib/libbsp/arm/edb7312/start/start.S
+++ b/c/src/lib/libbsp/arm/edb7312/start/start.S
@@ -37,44 +37,38 @@
 Vector_Init_Block:
-	LDR	PC, Reset_Addr
-	LDR	PC, Undefined_Addr
-	LDR	PC, SWI_Addr
-	LDR	PC, Prefetch_Addr
-	LDR	PC, Abort_Addr
-	NOP
-	LDR	PC, IRQ_Addr
-	LDR	PC, FIQ_Addr
-	.globl Reset_Addr
-Reset_Addr:	.long   _start
-Undefined_Addr:	.long	Undefined_Handler
-SWI_Addr:	.long	SWI_Handler
-Prefetch_Addr:	.long	Prefetch_Handler
-Abort_Addr:	.long	Abort_Handler
-		.long	0
-IRQ_Addr:	.long	IRQ_Handler
-FIQ_Addr:	.long	FIQ_Handler
-/* The following handlers do not do anything useful */
-	.globl Undefined_Handler
-Undefined_Handler:
-        B       Undefined_Handler
-	.globl SWI_Handler
-SWI_Handler:
-        B       SWI_Handler
-	.globl Prefetch_Handler
-Prefetch_Handler:
-        B       Prefetch_Handler
-	.globl Abort_Handler
-Abort_Handler:
-        B       Abort_Handler
-	.globl IRQ_Handler
-IRQ_Handler:
-        B       IRQ_Handler
-	.globl FIQ_Handler
-FIQ_Handler:
-        B       FIQ_Handler
+        nop
+        .word  _start
+handler_addr_swi:
+handler_addr_irq:
+handler_addr_fiq:
 	.globl	_start
 _start:
diff --git a/c/src/lib/libbsp/arm/edb7312/startup/bspstart.c b/c/src/lib/libbsp/arm/edb7312/startup/bspstart.c
index 31aff8c..0f9c64d 100644
--- a/c/src/lib/libbsp/arm/edb7312/startup/bspstart.c
+++ b/c/src/lib/libbsp/arm/edb7312/startup/bspstart.c
@@ -33,12 +33,6 @@ static void bsp_start_default( void )
   *EP7312_INTMR2 = 0;
diff --git a/c/src/lib/libbsp/arm/gumstix/Makefile.am b/c/src/lib/libbsp/arm/gumstix/Makefile.am
index 708a75b..68fb9ce 100644
--- a/c/src/lib/libbsp/arm/gumstix/Makefile.am
+++ b/c/src/lib/libbsp/arm/gumstix/Makefile.am
@@ -49,8 +49,6 @@ libbsp_a_SOURCES += ../../shared/src/irq-info.c
 libbsp_a_SOURCES += ../../shared/src/irq-legacy.c
 libbsp_a_SOURCES += ../../shared/src/irq-server.c
-#abort
 # Cache
 libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
diff --git a/c/src/lib/libbsp/arm/gumstix/start/start.S b/c/src/lib/libbsp/arm/gumstix/start/start.S
index 123d2d7..dccc999 100644
--- a/c/src/lib/libbsp/arm/gumstix/start/start.S
+++ b/c/src/lib/libbsp/arm/gumstix/start/start.S
@@ -122,28 +122,35 @@ _hang:  b       _hang
 vector_block:
         nop
-                        nop
-.globl SWI_Handler
-.globl IRQ_Handler
-.globl FIQ_Handler
+        .word  bsp_reset
+handler_addr_swi:
+handler_addr_irq:
+handler_addr_fiq:
diff --git a/c/src/lib/libbsp/arm/gumstix/startup/bspstart.c b/c/src/lib/libbsp/arm/gumstix/startup/bspstart.c
index cfbb122..f86bf3d 100644
--- a/c/src/lib/libbsp/arm/gumstix/startup/bspstart.c
+++ b/c/src/lib/libbsp/arm/gumstix/startup/bspstart.c
@@ -30,8 +30,6 @@ static void bsp_start_default( void )
   /* disable interrupts */
   XSCALE_INT_ICMR = 0x0;
 } /* bsp_start */
diff --git a/c/src/lib/libbsp/arm/rtl22xx/Makefile.am b/c/src/lib/libbsp/arm/rtl22xx/Makefile.am
index fd5255f..18eaf62 100644
--- a/c/src/lib/libbsp/arm/rtl22xx/Makefile.am
+++ b/c/src/lib/libbsp/arm/rtl22xx/Makefile.am
@@ -51,8 +51,6 @@ libbsp_a_SOURCES += ../../shared/src/irq-info.c
-# simple_abort
-libbsp_a_SOURCES += ../shared/abort/simple_abort.c
 # debugio
diff --git a/c/src/lib/libbsp/arm/rtl22xx/start/start.S b/c/src/lib/libbsp/arm/rtl22xx/start/start.S
index 0afd3ff..90b2425 100644
--- a/c/src/lib/libbsp/arm/rtl22xx/start/start.S
+++ b/c/src/lib/libbsp/arm/rtl22xx/start/start.S
@@ -123,80 +123,35 @@ _hang:  b       _hang
 vector_block:
-	LDR	PC, SWI_Addr
-	NOP
-	LDR	PC, IRQ_Addr
-	LDR	PC, FIQ_Addr
-	.globl Reset_Addr
-		.long	0
-Undefined_Handler:
-SWI_Handler:
-        B       SWI_Handler
-Prefetch_Handler:
-Abort_Handler:
-        B       Abort_Handler
-IRQ_Handler:
-        B       IRQ_Handler
-FIQ_Handler:
-        B       FIQ_Handler
+        nop
+        .word  _sart
+handler_addr_swi:
- * This is the exception vector table and the pointers to
- * the functions that handle the exceptions. It's a total
- * of 16 words (64 bytes)
-vector_block:
-        nop
-                        nop
-.globl SWI_Handler
-.globl IRQ_Handler
-.globl FIQ_Handler
+handler_addr_irq:
+handler_addr_fiq:
diff --git a/c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c b/c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c
index c10308c..fa128d9 100644
--- a/c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c
+++ b/c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c
@@ -72,12 +72,6 @@ static void bsp_start_default( void )
   UART0_Ini();
diff --git a/c/src/lib/libbsp/arm/shared/abort/abort.c b/c/src/lib/libbsp/arm/shared/abort/abort.c
deleted file mode 100644
index 657b2f4..0000000
--- a/c/src/lib/libbsp/arm/shared/abort/abort.c
+++ /dev/null
@@ -1,145 +0,0 @@
- *  ARM CPU Dependent Source
- *  If you want a small footprint RTEMS, pls use simple_abort.c
- *  COPYRIGHT (c) 2007 Ray Xu.
- *  mailto: Rayx at gmail dot com
- *  COPYRIGHT (c) 2000 Canon Research Centre France SA.
- *  Emmanuel Raguet, mailto:raguet at crf.canon.fr
- *  Copyright (c) 2002 Advent Networks, Inc
- *      Jay Monkman <jmonkman at adventnetworks.com>
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#include <rtems/system.h>
-#include <rtems.h>
-#include <rtems/bspIo.h>
-#include "abort.h"
-uint32_t g_data_abort_cnt = 0;
-/*this is a big overhead for MCU only got 16K RAM*/
-uint32_t g_data_abort_insn_list[1024];
-char *_print_full_context_mode2txt[0x20]={
-  [0x0]="user",  /* User */
-  [0x1]="fiq",   /* FIQ - Fast Interrupt Request */
-  [0x2]="irq",   /* IRQ - Interrupt Request */
-  [0x3]="super", /* Supervisor */
-  [0x7]="abort", /* Abort */
-  [0xb]="undef", /* Undefined */
-  [0xf]="system" /* System */
-void _print_full_context(uint32_t spsr)
-    char *mode;
-    uint32_t prev_sp,prev_lr,cpsr,arm_switch_reg;
-    int i;
-    printk("active thread thread 0x%08x\n", rtems_task_self());
-    mode=_print_full_context_mode2txt[spsr&0x1f];
-    if(!mode) mode="unknown";
-    __asm__ volatile (ARM_SWITCH_TO_ARM
-              "	MRS  %[cpsr], cpsr \n"
-              "	ORR  %[arm_switch_reg], %[spsr], #0xc0 \n"
-              "	MSR  cpsr_c, %[arm_switch_reg] \n"
-              "	MOV  %[prev_sp], sp \n"
-              "	MOV  %[prev_lr], lr \n"
-              "	MSR  cpsr_c, %[cpsr] \n"
-	      ARM_SWITCH_BACK
-              : [arm_switch_reg] "=&r" (arm_switch_reg), [prev_sp] "=&r" (prev_sp), [prev_lr] "=&r" (prev_lr),
-		[cpsr] "=&r" (cpsr)
-              : [spsr] "r" (spsr)
-              : "cc");
-    printk("Previous sp=0x%08x lr=0x%08x and actual cpsr=%08x\n",
-           prev_sp, prev_lr, cpsr);
-    for(i=0;i<48;){
-        printk(" 0x%08x",((uint32_t*)prev_sp)[i++]);
-        if((i%6) == 0)
-            printk("\n");
-/* This function is supposed to figure out what caused the
- * data abort, do that, then return.
- * All unhandled instructions cause the system to hang.
-void do_data_abort(
-  uint32_t insn,
-  uint32_t spsr,
-  Context_Control *ctx
-    /* Clarify, which type is correct, CPU_Exception_frame or Context_Control */
-    uint8_t               decode;
-    uint8_t               insn_type;
-    rtems_interrupt_level level;
-    g_data_abort_insn_list[g_data_abort_cnt & 0x3ff] = ctx->register_lr - 8;
-    g_data_abort_cnt++;
-    decode = ((insn >> 20) & 0xff);
-    insn_type = decode & INSN_MASK;
-    switch(insn_type) {
-    case INSN_STM1:
-        printk("\n\nINSN_STM1\n");
-        break;
-    case INSN_STM2:
-        printk("\n\nINSN_STM2\n");
-        break;
-    case INSN_STR:
-        printk("\n\nINSN_STR\n");
-        break;
-    case INSN_STRB:
-        printk("\n\nINSN_STRB\n");
-        break;
-    case INSN_LDM1:
-        printk("\n\nINSN_LDM1\n");
-        break;
-    case INSN_LDM23:
-        printk("\n\nINSN_LDM23\n");
-        break;
-    case INSN_LDR:
-        printk("\n\nINSN_LDR\n");
-        break;
-    case INSN_LDRB:
-        printk("\n\nINSN_LDRB\n");
-        break;
-    default:
-        printk("\n\nUnrecognized instruction\n");
-        break;
-    printk("data_abort at address 0x%x, instruction: 0x%x,   spsr = 0x%x\n",
-           ctx->register_lr - 8, insn, spsr);
-    _print_full_context(spsr);
-    /* disable interrupts, wait forever */
-    rtems_interrupt_disable(level);
-    (void) level; /* avoid set but unused warning */
-    while(1) {
-        continue;
diff --git a/c/src/lib/libbsp/arm/shared/abort/abort.h b/c/src/lib/libbsp/arm/shared/abort/abort.h
index 6d8704f..0000000
--- a/c/src/lib/libbsp/arm/shared/abort/abort.h
+++ /dev/null
@@ -1,52 +0,0 @@
-#ifndef _BSPABORT_H
-#define _BSPABORT_H
-#include <rtems.h>
-#define INSN_MASK         0xc5
-#define INSN_STM1         0x80
-#define INSN_STM2         0x84
-#define INSN_STR          0x40
-#define INSN_STRB         0x44
-#define INSN_LDM1         0x81
-#define INSN_LDM23        0x85
-#define INSN_LDR          0x41
-#define INSN_LDRB         0x45
-#define GET_RD(x)         ((x & 0x0000f000) >> 12)
-#define GET_RN(x)         ((x & 0x000f0000) >> 16)
-#define GET_U(x)          ((x & 0x00800000) >> 23)
-#define GET_I(x)          ((x & 0x02000000) >> 25)
-#define GET_REG(r, ctx)      (((uint32_t   *)ctx)[r])
-#define SET_REG(r, ctx, v)   (((uint32_t   *)ctx)[r] = v)
-#define GET_OFFSET(insn)     (insn & 0xfff)
- * Prototypes
-void _print_full_context(uint32_t);
-void do_data_abort(uint32_t, uint32_t, Context_Control *);
-#endif /* _BSPABORT_H */
diff --git a/c/src/lib/libbsp/arm/shared/abort/simple_abort.c b/c/src/lib/libbsp/arm/shared/abort/simple_abort.c
index e721323..0000000
--- a/c/src/lib/libbsp/arm/shared/abort/simple_abort.c
+++ /dev/null
@@ -1,146 +0,0 @@
- *  mailto: Rayx.cn at gmail dot com
- *  This is a simple implement of abort
-#include <rtems.h>
-#include "abort.h"
-char *_print_full_context_mode2txt[0x10]={
-  char *mode;
-  int i, j;
-  mode=_print_full_context_mode2txt[(spsr&0x1f)-0x10];
-    ARM_SWITCH_TO_ARM
-    "mrs %[cpsr], cpsr\n"
-    "orr %[arm_switch_reg], %[spsr], #0xc0\n"
-    "msr cpsr_c, %[arm_switch_reg]\n"
-    "mov %[prev_sp], sp\n"
-    "mov %[prev_lr], lr\n"
-    "msr cpsr_c, %[cpsr]\n"
-    ARM_SWITCH_BACK
-    : [prev_sp] "=&r" (prev_sp), [prev_lr] "=&r" (prev_lr),
-      [cpsr] "=&r" (cpsr), [arm_switch_reg] "=&r" (arm_switch_reg)
-    : "cc"
-  printk(
-    "Previous sp=0x%08x lr=0x%08x and actual cpsr=%08x\n",
-     prev_sp,
-     prev_lr,
-     cpsr
-  j=0;
-  for(i=0;i<48;) {
-      j++;
-      /*try not to use % because it introduces hundreds of byte overhead*/
-      if((j-6)==0) {
-          printk("\n");
-        j=0;
-  uint32_t         insn,
-  uint32_t         spsr,
-  uint8_t               decode;
-  case INSN_STM1:
-    break;
-  case INSN_STM2:
-    break;
-  case INSN_STR:
-    break;
-  case INSN_STRB:
-    break;
-  case INSN_LDM1:
-    break;
-  case INSN_LDM23:
-    break;
-  case INSN_LDR:
-    break;
-  case INSN_LDRB:
-    break;
-  default:
-    break;
-  (void)level;
-  while(1) {
-    continue;
-  return;
diff --git a/c/src/lib/libbsp/arm/smdk2410/Makefile.am b/c/src/lib/libbsp/arm/smdk2410/Makefile.am
index 7ded721..7cf25e1 100644
--- a/c/src/lib/libbsp/arm/smdk2410/Makefile.am
+++ b/c/src/lib/libbsp/arm/smdk2410/Makefile.am
@@ -57,8 +57,6 @@ libbsp_a_SOURCES += ../../shared/src/irq-info.c
-# abort
 # smc
 libbsp_a_SOURCES += smc/smc.c
 libbsp_a_SOURCES += smc/smc.h
diff --git a/c/src/lib/libbsp/arm/smdk2410/start/start.S b/c/src/lib/libbsp/arm/smdk2410/start/start.S
index f5f8891..95d781c 100644
--- a/c/src/lib/libbsp/arm/smdk2410/start/start.S
+++ b/c/src/lib/libbsp/arm/smdk2410/start/start.S
@@ -171,28 +171,35 @@ _hang:  b       _hang
 vector_block:
         nop
-                        nop
-.globl SWI_Handler
-.globl IRQ_Handler
-.globl FIQ_Handler
+        .word  bsp_reset
+handler_addr_swi:
+handler_addr_irq:
+handler_addr_fiq:
diff --git a/c/src/lib/libbsp/arm/smdk2410/startup/bspstart.c b/c/src/lib/libbsp/arm/smdk2410/startup/bspstart.c
index 5002e57..c70de1f 100644
--- a/c/src/lib/libbsp/arm/smdk2410/startup/bspstart.c
+++ b/c/src/lib/libbsp/arm/smdk2410/startup/bspstart.c
@@ -71,12 +71,6 @@ static void bsp_start_default( void )
   rTCFG0 = (cr | (0<<0));
diff --git a/cpukit/score/cpu/arm/Makefile.am b/cpukit/score/cpu/arm/Makefile.am
index 33372a2..6e98ed5 100644
--- a/cpukit/score/cpu/arm/Makefile.am
+++ b/cpukit/score/cpu/arm/Makefile.am
@@ -23,8 +23,6 @@ libscorecpu_a_SOURCES += arm-context-validate.S
 libscorecpu_a_SOURCES += arm-context-volatile-clobber.S
 libscorecpu_a_SOURCES += arm_exc_abort.S
 libscorecpu_a_SOURCES += arm_exc_interrupt.S
-libscorecpu_a_SOURCES += arm_exc_handler_low.S
-libscorecpu_a_SOURCES += arm_exc_handler_high.c
 libscorecpu_a_SOURCES += arm-exception-frame-print.c
 libscorecpu_a_SOURCES += arm-exception-default.c
 libscorecpu_a_SOURCES += armv4-exception-default.S
diff --git a/cpukit/score/cpu/arm/arm_exc_handler_high.c b/cpukit/score/cpu/arm/arm_exc_handler_high.c
index 493d993..0000000
--- a/cpukit/score/cpu/arm/arm_exc_handler_high.c
+++ /dev/null
@@ -1,127 +0,0 @@
- * @file
- * @ingroup ScoreCPU
- * @brief ARM exception support implementation.
- *  Copyright (c) 2007 Ray xu <rayx.cn at gmail.com>
- *  Moved from file 'cpukit/score/cpu/arm/cpu.c'.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems.h>
-#include <rtems/score/isr.h>
-#include <rtems/score/wkspace.h>
-#include <rtems/score/thread.h>
-#include <rtems/score/percpu.h>
-#include <rtems/score/cpu.h>
-#include <inttypes.h>
-#ifdef ARM_MULTILIB_ARCH_V4
-static void _defaultExcHandler (CPU_Exception_frame *ctx)
-    printk("\n\r");
-    printk("----------------------------------------------------------\n\r");
-#if 1
-    printk("Exception 0x%x caught at PC 0x%" PRIxPTR
-           " by thread 0x%" PRIx32 "\n",
-           ctx->vector, (uintptr_t) ctx->register_lr - 4,
-           _Thread_Executing->Object.id);
-#endif
-    printk("Processor execution context at time of the fault was  :\n\r");
-#if 0
-    printk(" r0  = %8x  r1  = %8x  r2  = %8x  r3  = %8x\n\r",
-           ctx->register_r0, ctx->register_r1,
-           ctx->register_r2, ctx->register_r3);
-    printk(" r4  = %8x  r5  = %8x  r6  = %8x  r7  = %8x\n\r",
-           ctx->register_r4, ctx->register_r5,
-           ctx->register_r6, ctx->register_r7);
-    printk(" r8  = %8x  r9  = %8x  r10 = %8x\n\r",
-           ctx->register_r8, ctx->register_r9, ctx->register_r10);
-    printk(" fp  = %8x  ip  = %8x  sp  = %8x  pc  = %8x\n\r",
-           ctx->register_fp, ctx->register_ip,
-           ctx->register_sp, ctx->register_lr - 4);
-#endif
-    if (_ISR_Nest_level > 0) {
-         * In this case we shall not delete the task interrupted as
-         * it has nothing to do with the fault. We cannot return either
-         * because the eip points to the faulty instruction so...
-        printk("Exception while executing ISR!!!. System locked\n\r");
-        while(1);
-    else {
-        printk("*********** FAULTY THREAD WILL BE DELETED **************\n\r");
-        rtems_task_delete(_Thread_Executing->Object.id);
-typedef void (*cpuExcHandlerType) (CPU_Exception_frame*);
-cpuExcHandlerType _currentExcHandler = _defaultExcHandler;
-extern void _Exception_Handler_Undef_Swi(void);
-extern void _Exception_Handler_Abort(void);
-extern void _exc_data_abort(void);
-/* FIXME: put comments here */
-void rtems_exception_init_mngt(void)
-        ISR_Level level;
-      _CPU_ISR_Disable(level);
-      _CPU_ISR_install_vector(ARM_EXCEPTION_UNDEF,
-                              _Exception_Handler_Undef_Swi,
-                              NULL);
-      _CPU_ISR_install_vector(ARM_EXCEPTION_SWI,
-                              NULL);
-      _CPU_ISR_install_vector(ARM_EXCEPTION_PREF_ABORT,
-                              _Exception_Handler_Abort,
-                              NULL);
-      _CPU_ISR_install_vector(ARM_EXCEPTION_DATA_ABORT,
-                              _exc_data_abort,
-                              NULL);
-      _CPU_ISR_install_vector(ARM_EXCEPTION_FIQ,
-                              NULL);
-      _CPU_ISR_install_vector(ARM_EXCEPTION_IRQ,
-                              NULL);
-      _CPU_ISR_Enable(level);
-#endif /* ARM_MULTILIB_ARCH_V4 */
diff --git a/cpukit/score/cpu/arm/arm_exc_handler_low.S b/cpukit/score/cpu/arm/arm_exc_handler_low.S
index e7ce507..0000000
--- a/cpukit/score/cpu/arm/arm_exc_handler_low.S
+++ /dev/null
@@ -1,166 +0,0 @@
- * @file
- *  Copyright (c) 2007 by Ray Xu, <Rayx.cn at gmail.com>
- *          Thumb support added.
- *  Copyright (c) 2002 by Advent Networks, Inc.
- *  Moved from file 'cpukit/score/cpu/arm/cpu_asm.S'.
-#endif
-#include <rtems/asm.h>
-#include <rtems/score/cpu_asm.h>
-        .text
-/* FIXME:       _Exception_Handler_Undef_Swi is untested */
-DEFINE_FUNCTION_ARM(_Exception_Handler_Undef_Swi)
-/* FIXME: This should use load and store multiple instructions */
-	sub     r13,r13,#SIZE_REGS
-	str     r4,  [r13, #REG_R4]
-	str     r5,  [r13, #REG_R5]
-	str     r6,  [r13, #REG_R6]
-	str     r7,  [r13, #REG_R7]
-	str     r8,  [r13, #REG_R8]
-	str     r9,  [r13, #REG_R9]
-	str     r10, [r13, #REG_R10]
-	str     r11, [r13, #REG_R11]
-	str     sp,  [r13, #REG_SP]
-	str     lr,  [r13, #REG_LR]
-	mrs	r0,  cpsr		/* read the status */
-	and	r0,  r0,#0x1f		/* we keep the mode as exception number */
-	str	r0,  [r13, #REG_PC]     /* we store it in a free place */
-	mov	r0,  r13		/* put frame address in r0 (C arg 1) */
-	ldr	r1, =SWI_Handler
-	ldr     lr, =_go_back_1
-	ldr	pc,[r1]				/* call handler  */
-_go_back_1:
-	ldr     r4,  [r13, #REG_R4]
-	ldr     r5,  [r13, #REG_R5]
-	ldr     r6,  [r13, #REG_R6]
-	ldr     r7,  [r13, #REG_R7]
-	ldr     r8,  [r13, #REG_R8]
-	ldr     r9,  [r13, #REG_R9]
-	ldr     r10, [r13, #REG_R10]
-	ldr     r11, [r13, #REG_R11]
-	ldr     sp,  [r13, #REG_SP]
-	ldr     lr,  [r13, #REG_LR]
-	add     r13,r13,#SIZE_REGS
-	movs	pc,r14			/* return  */
-/* FIXME:       _Exception_Handler_Abort is untested */
-DEFINE_FUNCTION_ARM(_Exception_Handler_Abort)
-	str     sp,  [r13, #REG_R11]
-	str     lr,  [r13, #REG_SP]
-	mov	r0,  r13		/* put frame address in ro (C arg 1) */
-	ldr	r1, =_currentExcHandler
-	ldr     lr, =_go_back_2
-_go_back_2:
-	ldr     sp,  [r13, #REG_R11]
-	ldr     lr,  [r13, #REG_SP]
-#ifdef  __thumb__
-	subs	r11, r14,#4
-	bx	r11
-	nop
-#else
-	subs	pc,r14,#4			/* return */
-#endif
-#define ABORT_REGS_OFFS 32-REG_R4
-#define ABORT_SIZE_REGS SIZE_REGS+ABORT_REGS_OFFS
-DEFINE_FUNCTION_ARM(_exc_data_abort)
-	sub	sp, sp, #ABORT_SIZE_REGS	/* reserve register frame */
-	stmia	sp, {r0-r11}
-	add	sp, sp, #ABORT_REGS_OFFS	/* the Context_Control structure starts by CPSR, R4, ... */
-	str	ip, [sp, #REG_PC]		/* store R12 (ip) somewhere, oh hackery, hackery, hack */
-	str	lr, [sp, #REG_LR]
-	mov	r1, lr
-	ldr	r0, [r1, #-8]			/* r0 = bad instruction */
-	mrs	r1, spsr			/* r1 = spsr */
-	mov	r2, r13				/* r2 = exception frame of Context_Control type */
-#if defined(__thumb__)
-	.code 32
-	/*arm to thumb*/
-	adr	r5, to_thumb + 1
-	bx	r5
-	.code 16
-to_thumb:
-#endif
-	bl	do_data_abort
-/*back to arm*/
-	.code 16
-thumb_to_arm:
-	.align 2
-	adr r5, arm_code
-	bx	r5
-	nop
-	.code 32
-arm_code:
-#endif
-	ldr	lr, [sp, #REG_LR]
-	ldr	ip, [sp, #REG_PC]		/* restore R12 (ip) */
-	sub	sp, sp, #ABORT_REGS_OFFS
-	ldmia	sp, {r0-r11}
-	add	sp, sp, #ABORT_SIZE_REGS
-#ifdef  __thumb__
-	subs	r11, r14, #4			/* return to the instruction */
-	bx      r11
-	nop
-#else
-	subs	pc, r14, #4
-#endif
-						/* _AFTER_ the aborted one */
diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h b/cpukit/score/cpu/arm/rtems/score/cpu.h
index 9f321ac..b10bc71 100644
--- a/cpukit/score/cpu/arm/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
@@ -704,12 +704,6 @@ void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
 void _ARM_Exception_default( CPU_Exception_frame *frame );
- * FIXME: In case your BSP uses this function, then convert it to use
- * the shared start.S file for ARM.
-void rtems_exception_init_mngt( void );
 #ifdef __cplusplus
1.8.4.5
