[PATCH 2/5] csb350/clock/clockdrv.c: Remove unneeded printk()
Thu Mar 9 22:18:17 UTC 2017
 c/src/lib/libbsp/mips/csb350/clock/clockdrv.c | 3 ---
 1 file changed, 3 deletions(-)
diff --git a/c/src/lib/libbsp/mips/csb350/clock/clockdrv.c b/c/src/lib/libbsp/mips/csb350/clock/clockdrv.c
index 537bf7e..53e7559 100644
--- a/c/src/lib/libbsp/mips/csb350/clock/clockdrv.c
+++ b/c/src/lib/libbsp/mips/csb350/clock/clockdrv.c
@@ -71,7 +71,6 @@ void au1x00_clock_init(void)
     tick_interval = 32768 * rtems_configuration_get_microseconds_per_tick();
     tick_interval = tick_interval / 1000000;
-    printk("tick_interval = %d\n", tick_interval);
     last_match = AU1X00_SYS_TOYREAD(AU1X00_SYS_ADDR);
     AU1X00_SYS_TOYMATCH2(AU1X00_SYS_ADDR) = last_match + (50*tick_interval);
@@ -84,8 +83,6 @@ void au1x00_clock_init(void)
      au1x00_clock_init(); \
   } while(0)
 #define Clock_driver_support_shutdown_hardware()
 #define CLOCK_DRIVER_USE_DUMMY_TIMECOUNTER
1.8.3.1
