[PATCH 4/5] shared/clock/clockdrv.c: Remove unneeded printk()
Thu Mar 9 22:18:19 UTC 2017
 c/src/lib/libbsp/mips/shared/clock/clockdrv.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/c/src/lib/libbsp/mips/shared/clock/clockdrv.c b/c/src/lib/libbsp/mips/shared/clock/clockdrv.c
index 8b178bb..cb9debb 100644
--- a/c/src/lib/libbsp/mips/shared/clock/clockdrv.c
+++ b/c/src/lib/libbsp/mips/shared/clock/clockdrv.c
@@ -39,7 +39,6 @@ static uint32_t mips_timer_rate = 0;
     mips_timer_rate = rtems_configuration_get_microseconds_per_tick() * \
       bsp_clicks_per_microsecond; \
     mips_set_timer( mips_timer_rate ); \
-    printk("Clock_mask: %x\n", CLOCK_VECTOR_MASK ); \
     mips_enable_in_interrupt_mask(CLOCK_VECTOR_MASK); \
   } while(0)
1.8.3.1
