[PATCH 3/3] c-user/rate_monotonic_manager.rst: Use Latex math for utilization formulas
Sat Mar 11 01:49:02 UTC 2017
Hi Joel,
The subject is misleading, Latex maybe used if generating a PDF while
mathjax is used for HTML. To be precise we use ReST's `math` support
which translates to the appropriate format implementation. :)
On 11/03/2017 08:29, Joel Sherrill wrote:
>  c-user/rate_monotonic_manager.rst | 14 ++++++--------
>  1 file changed, 6 insertions(+), 8 deletions(-)
> diff --git a/c-user/rate_monotonic_manager.rst b/c-user/rate_monotonic_manager.rst
> index 05eb59f..1309a88 100644
> --- a/c-user/rate_monotonic_manager.rst
> +++ b/c-user/rate_monotonic_manager.rst
> @@ -267,21 +267,19 @@ Processor Utilization Rule
>  The Processor Utilization Rule requires that processor utilization be
>  calculated based upon the period and execution time of each task.  The fraction
> -of processor time spent executing task index is ``Time(index) /
> -Period(index)``.  The processor utilization can be calculated as follows:
> +of processor time spent executing task index is ``Time(i) / Period(i)``.
> +The processor utilization can be calculated as follows:
> -.. code-block:: c
> +.. math::
> -    Utilization = 0
> -    for index = 1 to maximum_tasks
> -        Utilization = Utilization + (Time(index)/Period(index))
> +    Utilization = \sum_{i=1}^{maximumTasks} Time_i/Period_i
>  To ensure schedulability even under transient overload, the processor
>  utilization must adhere to the following rule:
> -.. code-block:: c
> +.. math::
> -    Utilization = maximum_tasks * (2**(1/maximum_tasks) - 1)
> +    maximumUtilization = maximumTasks * (2^{\frac{1}{maximumTasks}} - 1)
>  As the number of tasks increases, the above formula approaches ln(2) for a
>  worst-case utilization factor of approximately 0.693.  Many tasks sets can be
