[GSoC] RTEMS Tester Improvements
Mon Mar 13 17:52:33 UTC 2017
On Mon, Mar 13, 2017 at 1:44 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Mon, Mar 13, 2017 at 11:30 AM, Gedare Bloom <gedare at rtems.org> wrote:
>> On Mon, Mar 13, 2017 at 11:50 AM, Tanu Hari Dixit <tokencolour at gmail.com>
>> wrote:
>> > Hello all,
>> > I am interested in applying for GSoC under RTEMS. I am interested in the
>> > idea RTEMS Tester Improvements (https://devel.rtems.org/ticket/2919). I
>> > have
>> > used rtems-tester in the past and also have a working knowledge of
>> > python.
>> What platforms have you run tester on?
>> > I have a few questions and will be grateful if they are answered.
>> > 1) Which simulator recipes need to be added?
>> The first place to look is to compare what is supported in tester
>> versus what we have scripts for in the older rtems-testing.git repo
>> under sim-scripts/
>> https://git.rtems.org/rtems-testing/tree/sim-scripts
>> I personally would also be interested to add simulator recipes for the
>> gem5 (gem5.org) simulator. I made a start at this a long time ago and
>> got it to work reasonably well, but appear to have misplaced the
>> actual changes. Related to this would be adding complementary recipes
>> for building simulators in the RSB. I have run rtems under gem5 for
>> the sparc64/usiii and arm/realview_pbx_a9_qemu BSPs in the past and
>> would be able to help with simulator setup to get you to the point of
>> transitioning from manual/shell-scripted steps into python automation.
>> > 2) What are the improvements that need to be done? I couldn't find the
>> > appropriate tickets or pointers.
>> I believe it is primarily to increase the range of simulators that are
>> supported. Perhaps Chris has other ideas for infrastructure
>> improvements, e.g. there is almost always improvements that can be
>> made to report usability such as visualizing aggregated testing
>> results, tracking down failed tests quicker, and so forth.
> There is also the issue of the coverage testing which used to be
> done by scripts in rtems-testing git repo but now partially supported
> by rtems-tester. Some work was done by a previous student.
> Although my response is short, the work is important. :)
Relevant info at
https://devel.rtems.org/wiki/Developer/Projects/Open/PythonCoverageReporting
>> > 3) Do I need to start a Google doc for the proposal or is there some
>> > other
>> > platform, I need to write on? Is there a template, I should be aware of?
>> There is a template of a Google doc linked from the GSoC 2017 Tracking
>> Page (start https://devel.rtems.org/wiki/GSoC and navigate your way
>> around). Ultimately you need to submit a PDF to the GSoC site for an
>> official submission.
>> > 4) Is the implementation of this idea in general interest of the
>> > community?
>> Yes.
>> > 5) Will this be enough work for the GSoC term or will I have to club
>> > this
>> > with another idea (maybe the one where we have to design simple examples
>> > (different from tests) for user documentation so that it is easy for
>> > users
>> > to see how to use a call.) or will that be a stretch goal?
>> I suggest you focus on one specific area and make your stretch goals
>> be "deep" in that area. It is hard to say for sure what may be a
>> stretch, it depends on your individual performance. You will
>> definitely need to define a reasonably large number of tasks that we
>> believe you can be kept busy all summer. I have provided a few ideas
>> above that should help you to flesh out a fully-scoped project around
>> the Tester infrastructure.
>> > Thank you,
>> > Tanu Hari Dixit.
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
