[PATCH 1/7] dosfs: Fix fat_file_write()
Tue Mar 14 13:43:26 UTC 2017
Remove forced overwrite which leads to file data corruption.  The logic
to determine a forced overwrite was fundamentally broken.  For simplity,
disable this feature.
Update #2622.
 cpukit/libfs/src/dosfs/fat.c             | 15 +++++----------
 cpukit/libfs/src/dosfs/fat.h             |  3 +--
 cpukit/libfs/src/dosfs/fat_file.c        | 23 +++++------------------
 testsuites/fstests/fsdosfswrite01/init.c | 26 ++++++++++++++++++++------
 4 files changed, 31 insertions(+), 36 deletions(-)
diff --git a/cpukit/libfs/src/dosfs/fat.c b/cpukit/libfs/src/dosfs/fat.c
index 2176ff3..a0475d4 100644
--- a/cpukit/libfs/src/dosfs/fat.c
+++ b/cpukit/libfs/src/dosfs/fat.c
@@ -200,13 +200,12 @@ _fat_block_read(
 static ssize_t
- fat_block_write(
+fat_block_write(
     fat_fs_info_t                        *fs_info,
     const uint32_t                        start_blk,
     const uint32_t                        offset,
     const uint32_t                        count,
-    const void                           *buf,
-    const bool                            overwrite_block)
+    const void                           *buf)
     int                 rc             = RC_OK;
     uint32_t            bytes_to_write = MIN(count, (fs_info->vol.bytes_per_block - offset));
@@ -215,8 +214,7 @@ static ssize_t
     if (0 < bytes_to_write)
-        if (   overwrite_block
-            || (bytes_to_write == fs_info->vol.bytes_per_block))
+        if (bytes_to_write == fs_info->vol.bytes_per_block)
             rc = fat_buf_access(fs_info, sec_num, FAT_OP_TYPE_GET, &blk_buf);
@@ -399,7 +397,6 @@ _fat_block_release(fat_fs_info_t *fs_info)
  *     offset             - offset inside cluster 'start'
  *     count              - count of bytes to write
  *     buff               - buffer provided by user
- *     overwrite_cluster  - true if cluster can get overwritten, false if cluster content must be kept
  * RETURNS:
  *     bytes written on success, or -1 if error occured
@@ -411,8 +408,7 @@ fat_cluster_write(
     const uint32_t                        start_cln,
-    const void                           *buff,
-    const bool                            overwrite_cluster)
+    const void                           *buff)
     ssize_t             rc               = RC_OK;
     uint32_t            bytes_to_write   = MIN(count, (fs_info->vol.bpc - offset));
@@ -436,8 +432,7 @@ fat_cluster_write(
           cur_blk,
           ofs_blk,
           c,
-          &buffer[bytes_written],
-          overwrite_cluster);
+          &buffer[bytes_written]);
       if (c != ret)
         rc = -1;
       else
diff --git a/cpukit/libfs/src/dosfs/fat.h b/cpukit/libfs/src/dosfs/fat.h
index 8fcd17f..1cbf9a7 100644
--- a/cpukit/libfs/src/dosfs/fat.h
+++ b/cpukit/libfs/src/dosfs/fat.h
@@ -503,8 +503,7 @@ fat_cluster_write(fat_fs_info_t                    *fs_info,
                     uint32_t                          start_cln,
                     uint32_t                          offset,
                     uint32_t                          count,
-                    const void                       *buff,
-                    bool                              overwrite_cluster);
+                    const void                       *buff);
 ssize_t
 fat_sector_write(fat_fs_info_t                        *fs_info,
diff --git a/cpukit/libfs/src/dosfs/fat_file.c b/cpukit/libfs/src/dosfs/fat_file.c
index af71ee2..cbc0ab3 100644
--- a/cpukit/libfs/src/dosfs/fat_file.c
+++ b/cpukit/libfs/src/dosfs/fat_file.c
@@ -403,20 +403,18 @@ static bool
  *     start            - offset(in bytes) to write from
  *     count            - count
  *     buf              - buffer provided by user
- *     file_cln_initial - initial current cluster number of the file
  * RETURNS:
  *     number of bytes actually written to the file on success, or -1 if
  *     error occured (errno set appropriately)
 static ssize_t
- fat_file_write_fat32_or_non_root_dir(
+fat_file_write_fat32_or_non_root_dir(
      fat_file_fd_t                        *fat_fd,
      const uint32_t                        start,
-     const uint8_t                        *buf,
-     const uint32_t                        file_cln_initial)
+     const uint8_t                        *buf)
     int            rc = RC_OK;
     uint32_t       cmpltd = 0;
@@ -426,35 +424,27 @@ static ssize_t
     uint32_t       ofs_cln = start - (start_cln << fs_info->vol.bpc_log2);
     uint32_t       ofs_cln_save = ofs_cln;
     uint32_t       bytes_to_write = count;
-    uint32_t       file_cln_cnt;
     ssize_t        ret;
     uint32_t       c;
-    bool           overwrite_cluster = false;
     rc = fat_file_lseek(fs_info, fat_fd, start_cln, &cur_cln);
     if (RC_OK == rc)
-        file_cln_cnt = cur_cln - fat_fd->cln;
         while (   (RC_OK == rc)
                && (bytes_to_write > 0))
             c = MIN(bytes_to_write, (fs_info->vol.bpc - ofs_cln));
-            if (file_cln_initial < file_cln_cnt)
-                overwrite_cluster = true;
             ret = fat_cluster_write(fs_info,
                                       cur_cln,
                                       ofs_cln,
                                       c,
-                                      &buf[cmpltd],
+                                      &buf[cmpltd]);
             if (0 > ret)
               rc = -1;
             if (RC_OK == rc)
-                ++file_cln_cnt;
                 bytes_to_write -= ret;
                 cmpltd += ret;
                 save_cln = cur_cln;
@@ -509,7 +499,6 @@ fat_file_write(
     uint32_t       byte;
     uint32_t       c = 0;
     bool           zero_fill = start > fat_fd->fat_file_size;
-    uint32_t       file_cln_initial = fat_fd->map.file_cln;
     uint32_t       cln;
@@ -543,8 +532,7 @@ fat_file_write(
                                       cln,
                                       byte,
                                       count,
-                                      buf,
-                                      false);
+                                      buf);
             if (0 > ret)
               rc = -1;
             else
@@ -556,8 +544,7 @@ fat_file_write(
                                                        fat_fd,
                                                        start,
                                                        count,
-                                                       buf,
-                                                       file_cln_initial);
+                                                       buf);
             if (0 > ret)
               rc = -1;
             else
diff --git a/testsuites/fstests/fsdosfswrite01/init.c b/testsuites/fstests/fsdosfswrite01/init.c
index 9ca1a2a..ba72507 100644
--- a/testsuites/fstests/fsdosfswrite01/init.c
+++ b/testsuites/fstests/fsdosfswrite01/init.c
@@ -125,7 +125,7 @@ static void test_normal_file_write(
   const char *mount_dir,
   const char *file_name )
-  static const rtems_blkdev_stats complete_block_stats = {
+  static const rtems_blkdev_stats complete_existing_block_stats = {
     .read_hits            = 0,
     .read_misses          = 0,
     .read_ahead_transfers = 0,
@@ -135,14 +135,24 @@ static void test_normal_file_write(
     .write_blocks         = 1,
     .write_errors         = 0
-  static const rtems_blkdev_stats new_block_stats = {
-    .read_hits            = 8,
+  static const rtems_blkdev_stats complete_new_block_stats = {
+    .read_hits            = 3,
     .read_misses          = 2,
     .read_blocks          = 2,
     .read_errors          = 0,
     .write_transfers      = 1,
-    .write_blocks         = 4,
+    .write_blocks         = 3,
+    .write_errors         = 0
+  static const rtems_blkdev_stats partial_new_block_stats = {
+    .read_hits            = 3,
+    .read_misses          = 3,
+    .read_ahead_transfers = 0,
+    .read_blocks          = 3,
+    .read_errors          = 0,
+    .write_transfers      = 1,
     .write_errors         = 0
@@ -174,17 +184,21 @@ static void test_normal_file_write(
   num_bytes = write( fd, cluster_buf, cluster_size );
   rtems_test_assert( (ssize_t) cluster_size == num_bytes );
-  check_block_stats( dev_name, mount_dir, &complete_block_stats );
+  check_block_stats( dev_name, mount_dir, &complete_existing_block_stats );
   reset_block_stats( dev_name, mount_dir );
+  /* Write a complete cluster into a new file space */
+  check_block_stats( dev_name, mount_dir, &complete_new_block_stats );
+  reset_block_stats( dev_name, mount_dir );
   /* Write a new partial cluster into a new file space */
   num_bytes = write( fd, cluster_buf, 1 );
   rtems_test_assert( num_bytes == 1 );
-  check_block_stats( dev_name, mount_dir, &new_block_stats );
+  check_block_stats( dev_name, mount_dir, &partial_new_block_stats );
   rv = close( fd );
   rtems_test_assert( 0 == rv );
1.8.4.5
