[PATCH 5/7] dosfs: Add and use msdos_lfn_checksum()
Tue Mar 14 13:43:30 UTC 2017
Update #2929.
 cpukit/libfs/src/dosfs/msdos.h      |  2 ++
 cpukit/libfs/src/dosfs/msdos_dir.c  | 10 ++--------
 cpukit/libfs/src/dosfs/msdos_misc.c | 35 +++++++++++++++++++++--------------
 3 files changed, 25 insertions(+), 22 deletions(-)
diff --git a/cpukit/libfs/src/dosfs/msdos.h b/cpukit/libfs/src/dosfs/msdos.h
index d5c48d7..abfede8 100644
--- a/cpukit/libfs/src/dosfs/msdos.h
+++ b/cpukit/libfs/src/dosfs/msdos.h
@@ -482,6 +482,8 @@ int msdos_get_dotdot_dir_info_cluster_num_and_offset(
 int msdos_sync(rtems_libio_t *iop);
+uint8_t msdos_lfn_checksum(const void *entry);
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/libfs/src/dosfs/msdos_dir.c b/cpukit/libfs/src/dosfs/msdos_dir.c
index b10ed9e..577dc4d 100644
--- a/cpukit/libfs/src/dosfs/msdos_dir.c
+++ b/cpukit/libfs/src/dosfs/msdos_dir.c
@@ -281,14 +281,8 @@ msdos_dir_read(rtems_libio_t *iop, void *buffer, size_t count)
                 if (lfn_start != FAT_FILE_SHORT_NAME)
-                    uint8_t  cs = 0;
-                    uint8_t* p = (uint8_t*) entry;
-                    int      i;
-                    for (i = 0; i < 11; i++, p++)
-                        cs = ((cs & 1) ? 0x80 : 0) + (cs >> 1) + *p;
-                    if (lfn_entries || (lfn_checksum != cs))
+                    if (lfn_entries ||
+                        lfn_checksum != msdos_lfn_checksum(entry))
                         lfn_start = FAT_FILE_SHORT_NAME;
                     eno = (*convert_handler->utf16_to_utf8) (
diff --git a/cpukit/libfs/src/dosfs/msdos_misc.c b/cpukit/libfs/src/dosfs/msdos_misc.c
index 464c981..5c16f4a 100644
--- a/cpukit/libfs/src/dosfs/msdos_misc.c
+++ b/cpukit/libfs/src/dosfs/msdos_misc.c
@@ -55,6 +55,23 @@
 const char *const MSDOS_DOT_NAME    = ".          ";
 const char *const MSDOS_DOTDOT_NAME = "..         ";
+uint8_t
+msdos_lfn_checksum(const void *entry)
+    const uint8_t *name;
+    uint8_t        cs;
+    int            i;
+    name = (const uint8_t *) MSDOS_DIR_NAME(entry);
+    cs = 0;
+    for (i = 0; i < MSDOS_SHORT_NAME_LEN; ++i) {
+        cs = ((cs & 1) ? 0x80 : 0) + (cs >> 1) + name[i];
+    return cs;
 /* msdos_is_valid_name_char --
  *     Routine to check the character in a file or directory name.
  *     The characters support in the short file name are letters,
@@ -1535,14 +1552,8 @@ msdos_find_file_in_directory (
                     if (entry_matched)
-                        uint8_t  cs = 0;
-                        uint8_t* p = (uint8_t*) MSDOS_DIR_NAME(entry);
-                        int      i;
-                        for (i = 0; i < MSDOS_SHORT_NAME_LEN; i++, p++)
-                        if (lfn_entry || (lfn_checksum != cs))
+                        if (lfn_entry ||
                             entry_matched = false;
                         else if (filename_size_remaining == 0) {
                             filename_matched = true;
@@ -1561,7 +1572,7 @@ msdos_find_file_in_directory (
 #if MSDOS_FIND_PRINT
                         printf ("MSFS:[9.2] checksum, entry_matched:%i, lfn_entry:%i, lfn_checksum:%02x/%02x\n",
-                                entry_matched, lfn_entry, lfn_checksum, cs);
+                                entry_matched, lfn_entry, lfn_checksum, msdos_lfn_checksum(entry));
 #endif
                     } else {
                         bytes_in_entry = MSDOS_SHORT_NAME_LEN + 1;
@@ -1670,11 +1681,7 @@ msdos_add_file (
     if (fat_entries)
-        uint8_t* p = (uint8_t*) MSDOS_DIR_NAME(name_dir_entry);
-        int      i;
-            lfn_checksum =
-                ((lfn_checksum & 1) ? 0x80 : 0) + (lfn_checksum >> 1) + *p;
+        lfn_checksum = msdos_lfn_checksum(name_dir_entry);
1.8.4.5
