[PATCH 1/5] Adding modified FREEBSD headers to sync RTEMS termios with FREEBSD
Kirspel, Kevin Kevin-Kirspel at idexx.com
Tue Mar 14 13:54:27 UTC 2017
I tested it against xilinx_zynq_a9_qemu.  I'm not sure it exists, but if there is a way to compile the patch against every (or most) BSP then we could ensure no BSP is broken.
Kevin Kirspel
Electrical Engineer - Sr. Staff
Idexx Roswell
235 Hembree Park Drive
Roswell GA 30076
Tel: (770)-510-4444 ext. 81642
Direct: (770)-688-1642
Fax: (770)-510-4445
-----Original Message-----
From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
Sent: Tuesday, March 14, 2017 9:42 AM
To: Kirspel, Kevin <Kevin-Kirspel at idexx.com>; devel at rtems.org
Subject: Re: [PATCH 1/5] Adding modified FREEBSD headers to sync RTEMS termios with FREEBSD
The patch set looks good after a rough review. I will check this in in two or three days if nobody objects.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
