IoT Protocol in RTEMS
punit vara punitvara at gmail.com
Tue Mar 14 15:22:09 UTC 2017
Can I port MQTT from here ?
https://github.com/zephyrproject-rtos/zephyr/tree/master/subsys/net/lib/mqtt
It has Apache licence. Where do I possibly need to add files ?  Any suggestion ?
-- PV
On Tue, Mar 14, 2017 at 7:50 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Mar 14, 2017 at 8:56 AM, Gedare Bloom <gedare at rtems.org> wrote:
>> On Tue, Mar 14, 2017 at 1:26 AM, punit vara <punitvara at gmail.com> wrote:
>> > Hi
>> > I think RTEMS don't have any IoT protocol so I propose we should
>> > implement at least two important IoT protocols
>> > 1. MQTT (http://docs.oasis-open.org/mqtt/mqtt/v3.1.1/mqtt-v3.1.1.html)
>> > 2. CoAP  (http://coap.technology/)
>> Why are these 2 important?
>> The problem to avoid is adopting a network protocol too early, because
>> there is always a bunch of competing ones, and in the end only a
>> handful will survive in the long term.
> MQTT is an OASIS standard which is a good sign. It also has multiple
> implementations
> already with this one from the Eclipse Foundation looking very promising and
> appropriate for RTEMS.
> https://www.eclipse.org/paho/clients/c/embedded/
> CoAP also looks promising since it has an RFC. And promising implementations
> to investigate.
> http://coap.technology/impls.html
> https://github.com/obgm/libcoap is dual licensed as GPL and BSD (why?).
>> > What's your opinion on this ? :)
>> This may be a good idea. What is the state of industry and of
>> standardization in this space? Are there open-source reference
>> implementations with a useful (BSD/MIT) license?
> I think those two are worth porting. There are already other ports to
> embedded
> environments so RTEMS should join the list.
> The effort would have to get the RTEMS specific configuration and adaptation
> code upstream, add RSB recipes, and examples with documentation. I would
> honestly expect the ports to be easy enough where more work needs to be
> identified. :)
> --joel
>> Gedare
>> > Regards
>> > Punit Vara
