RTEMS 4.11.2 milestone date
Thu Mar 16 20:22:25 UTC 2017
On 17/03/2017 01:06, Joel Sherrill wrote:
> On Thu, Mar 16, 2017 at 4:43 AM, Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     If you have anything you would like in the release please make sure you
>     have created a ticket and assigned it to the milestone.
> Are the 4.11 tools buildable on the newer hosts that you and I
> have had troubles with the 4.12 tools? I think specifically
> qemu and gdb are troublesome.
Good point, I am not sure. I will check FreeBSD 11.0 and raise a ticket
if there is a problem.
Thanks for raising this.
