RTEMS 4.11.2 milestone date
Thu Mar 16 23:22:15 UTC 2017
On 17/03/2017 07:48, Joel Sherrill wrote:
> On Thu, Mar 16, 2017 at 3:22 PM, Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 17/03/2017 01:06, Joel Sherrill wrote:
>         On Thu, Mar 16, 2017 at 4:43 AM, Chris Johns <chrisj at rtems.org
>         <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>> wrote:
>             If you have anything you would like in the release please
>         make sure you
>             have created a ticket and assigned it to the milestone.
>         Are the 4.11 tools buildable on the newer hosts that you and I
>         have had troubles with the 4.12 tools? I think specifically
>         qemu and gdb are troublesome.
>     Good point, I am not sure. I will check FreeBSD 11.0 and raise a
>     ticket if there is a problem.
> FWIW assuming qemu on the master is the same as on 4.11, it built find
> on a new CentOS 7 install.
I do not know if they are the same. I will check what there is in 4.11
on FreeBSD 10.3 and 11.0.
> But that's still at gcc 4.8. Something with a new
> enough gcc will have trouble.
If tickets are raised and patches supplied in time they may make RC1
otherwise they will have to wait for the next release.
> And you have the gdb powerpc issue on FreeBSD which might occur.
Is there a ticket for this? I am struggling to remember what the problem
is. I do not use any PPC devices and it is not a primary focus for me.
> I don't know of any code issues. We all are good at filing those. :)
I would like to package and release what we have at the set dates rather
than hold the release while everything possible is fixed.
